Induced voltage with coil between 2 magnets
The discussion revolves around the induced voltage in a coil positioned between two rare Earth magnets, specifically examining whether the orientation of the magnets (attracting or repelling) affects the induced voltage. The context includes practical applications in building a seismometer, with considerations of electromagnetic principles and magnetic flux changes.
  • Homework-related
  • One participant questions whether the orientation of the magnets (attracting vs. repelling) would result in different induced voltages in the coil.
  • Another participant explains that the setup of the magnets significantly affects the magnetic flux, which in turn influences the induced voltage. They suggest that configurations that allow for magnetic flux to flow (like N-S-N-S) will induce voltage, while opposing configurations (like N-S-S-N) will result in near-zero flux and thus no induced voltage.
  • There is mention of using horseshoe magnets versus rare Earth disc magnets, with a note on the availability of strong, small magnets.
  • A participant elaborates on the mechanics of the seismometer, indicating that the frame moves rather than the pendulum, which could affect the readings.
Participants generally agree that the orientation of the magnets affects the induced voltage due to changes in magnetic flux. However, there is no consensus on the specific implications or the best configurations for the seismometer design.
The discussion does not resolve the complexities of the magnetic interactions or the precise conditions under which different configurations may yield varying results. Assumptions about the movement of the coil and the magnets during seismic events are also not fully explored.
davenn
hi gang,
Just building a seismometer I have 2 x 2.5cm disc rare Earth magnets spaced far enough apart for a coil of wire to move between them.
Would you expect there to be any difference in induced voltage into a coil between 2 magnets when the magnets are orientated to attract or repel ?
I'm thinking no difference, but really have no idea
see pic for idea of what I'm doing. ignore that fact the builder of shown unit is using 4 x disc magnets, 2 top and 2 bottom.
if there is a difference between the two options ... why ?
cheers
Dave
Well.. can't see any picture. Got link to it ?
GRRR sorry about that
I posted it and saw the pic, thought nothing more of it
then after your comment in the email, I visited the page and saw the pic was missing
Should be ok now :)
cheers
Dave
I'm not very familiar with that kind of stuff.. but.. from general elekctromagnetics:
I take that magnets are on opposite sides of coil and when there is earthquake you have some coil-magnets movement, correct ?
If yes then there are significant diffrences for diffrent magnets setups. You can observe signal because there is some movement between magnets and coils. Magnetic flux changes and this induces voltage in coil. The essence here is the magnetic flux generated by magnets. If they are set up in the same side N-S-N-S (or S-N-S-N) the flux is flowing, but if You set them up like N-S-S-N (or S-N-N-S) the magnetic flux will be near zero (it's like two sources set opposite). No flux = no signal.
yes, that's correct. Some guys use horseshoe magnets. But strong and physically relatively small ones are not readily available. So the other main choice these days are to use several rare Earth disc magnets.
Just for your info... at the other end of the "red" assembly there are more magnets mounted. They have a piece of aluminium between them. This is used for dampening of the pendulum arm, so that it doesn't go into free natural oscillation. Else you are just recording the motion of the pendulum and not the earth.
Tecnically its the frame of the seismometer that is moving, not the pendulum, due to the large mass on the end of the pendulum arm. but because the pendulum isn't totally isolated from the frame it will start to oscillate as well.
Thanks for your insights :)
Dave
  • · Replies 17 ·
  • · Replies 16 ·
12K
