I'm still puzzling on relativistic masses.
I can see from wiki entries that the concept is avoided, and that there are separate parallel and transversal forms.
As it is I can distinguish 6 types of masses.
Let's say we have 4-momentum
P = (E,
p), where
p is the 3-momentum,
v is the velocity to a (distant) inertial observer.
I'm setting c=1 for ease of notation.
Let furthermore
f = d
p/dt be the 3-force.The 6 types of masses I see, are:
1. The rest mass m
0, which is also the invariant mass for a single object.
2. The invariant mass, which is the norm of the 4-momentum
P. This one is the same for all observers.
3. The energy-mass E, which is the first component of
P.
4. The momentum-speed-ratio [itex]\frac {|\boldsymbol p|} {|\boldsymbol v|} = \gamma m_0[/itex].
5. The parallel force-acceleration-ratio [itex]\frac {f_\parallel} {\dot v_\parallel}[/itex].
6. The transversal force-acceleration-ratio [itex]\frac {f_\perp} {\dot v_\perp}[/itex].Numbers 5 and 6 are messy and probably best avoided.
They can be derived from the time-derivative of the momentum.
Number 3 is ambiguous, since we saw with the box of photons, that it matters to an observer whether we are talking about a box of photons or a box of sand.
The interesting thing is that number 4, the momentum-speed-ratio, appears to match perfectly with the old relativistic mass concept, which appears to be consistent (but not the same) in all frames of reference, and which obeys the rules of classical mechanics as long as it is only being used in combination with momentum and impulse.Please correct me if I'm wrong, because I would really like to know.
