Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #10,831
AtomicWombat said:
Are the AO valves fail-open or fail-shut?
The AO valves would be fail-shut.
In figure Figure IV-2-13 Overview of PCV Venting Facility (Unit 1) on page 154 of your linked document there is only one MO (manually operated) valve in the path to the stack and one rupture disk - presumably set near the wet-well maximum operating pressure.
Yes, that all seems consistent with the testimony/evidence of the reports.
At 9-11 minutes into this video David Lochbaum says that the operators manually openned the hardened vent valve.
http://vimeo.com/26231562"
I get from the testimony, that the operators on preparation of the vent procedure found that the MO-valve (Motor Operated) was designed such that it was possible to operate it manually, whereas the AO valves (Air Operated) could be operated only remotely using air pressure, not manually. In order to make a functioning vent line, they needed to open the MO valve, while keeping open either or both of the two AO valves. Once this configuration had been lined up, and as long as it could be kept lined up, actual venting would be triggered at the set value of the rupture disc.
  • #10,832
Thanks MD, I've lost track of events. Do you have a link for the testimony?
Is it known if the "hardened vent" is still open?
  • #10,833
SpunkyMonkey said:
Perhaps the red-brown stains and http://www.tepco.co.jp/en/news/110311/images/110802_1.jpg":
And there are signs that the reddish-brown gunk was splattered around the base of the stack
Perhaps there's a filter within the stack and was clogged up with cesium-vapor residue and a recent 'belch' from the containment blew out the filter contents. In fact, just after the last 6.5 earthquake there was a small drop in Unit 1 http://www.houseoffoust.com/edano/1pre.bmp" . Then within a day or two this new highest-dose location was discovered. Perhaps that marks the 'belch' that relieved some pressure, dropped the temperature and blew out a congested filter.
I'm sorry, that stuff still looks like rust to me. The horizontal pipe running right below the brown pipe elbow looks clean closest to the most stained portion of the elbow. That does not look like a high pressure cesium leak to me.
If you look at a http://www.tepco.co.jp/en/news/110311/images/110805_1.jpg", it looks like it was wrapped with some kind of tape, perhaps to protect it against corrosion. The brown stuff seems to have leaked out from underneath the tape. Perhaps the tape trapped moisture, allowing rust to fester underneath. The vertical brown lines are consistent with rust getting washed down by rain.
Below where the elbow connects to the stack is where the brown colour is the deepest. There should have been a lot of condensation at the bottom of the stack, with air from inside two buildings containing pools getting vented through here, especially when it's cold outside. Who knows how far the corrosion went there... The deepest stain may have been where runoff from the outside of the rounded pipe collected.
If the air-operated valve is fail-shut then it would only have staid open if compressed air had been fed to it for 4 1/2 months. So I wouldn't have thought so, unless something malfunctioned.
  • #10,834
It really needs a chemical, elemental & isotopic analysis to resolve the issue. As TEPCO is in charge...
  • #10,835
MadderDoc said:
(http://www.ansn-elibrary.org/images/c/ca/Boiling_Water_Reactor_Power_Plant.pdf" )
afaik this system may have rather low throughput and could not be used in the event of serious emergency. But that may depend to particular reactor.
  • #10,836
http://www3.nhk.or.jp/news/genpatsu-fukushima/20110807/index.html The Areva system chemical pump was restarted after 3 and a half hours. Tepco says the pump tripped because a high viscosity increased the load, but is still clueless about why the backup pump did not start. Concerning the pump that stopped at the Kurion system, the recovery is nowhere in sight. The NISA has requested Tepco to write a report on the causes of the water treatment facility troubles.
http://mainichi.jp/select/jiken/news/20110808ddm003040141000c.html Tepco decided to reduce the chemical pump's flow rate, while increasing the frequency of chemical injections. Without evaporation systems, the desalinating facility produces 1.5 times more high concentration salty water than freshwater. The two evaporation systems that were launched yesterday can bring this rate down to 30%.
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110808_01-e.pdf "Diagram of Desalination System"
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110808_02-e.pdf "Leakage detected between cable duct for starting transformer and control building Unit 3, Fukushima Daiichi Nuclear Power Station"
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110808_03-e.pdf (page 2) From 10:03 to 10:43 AM on 8 August, unit 5 reactor cooling was stopped to enable the switching of power supply for RHRS pump (C).
  • #10,837
Yes, in all likelihood the venting systems used by the operators were not the Emergency Gas Treatment Systems, but rather the retrofitted hardened vents we have been talking about. Here's the unit 1/2/3 diagrams of the hardened vent lines cropped from the report of the Japanese governement to the IAEA (see attachments for better rendering):
  • #10,838
Concerning the source of the high radiation readings, maybe the following information from http://www.world-nuclear-news.org/RS_Second_high_radiation_reading_308112.html is of interest:Second high radiation reading
03 August 2011
Another radiation hotspot has been found at the Fukushima Daiichi site - again in part of the emergency venting and filtration system.
Yesterday an extremely high reading of 10,000 millisieverts per hour was announced as having been found in pipework leading to an exhaust stack. Today that was followed by a reading of over 5000 millisieverts per hour inside one of the buildings.
Both of the readings were taken from parts of the Standby Gas Treatment System (SGTS), through which steam was vented to relieve reactor pressure during the accident in March. In that sense, it is highly likely that Tokyo Electric Power Company will make several more findings of radiation hotspots as it conducts stabilisation work inside the power plant buildings.
The first hotspot was detected in a part of the SGTS pipework immediately before the exhaust stack shared by units 1 and 2. The latest one is on the second floor of unit 1's turbine building, near the entrance to a room related to the SGTS.
Each reactor building has an SGTS which maintains slightly lower air pressure during normal operation to reduce the possiblity that potential contamination could exit the plant building through any tiny holes. It has air intakes and components on several floors. Should contamination be present in the buildings for any reason, the SGTS is there to filter the air before release through the stack. It also provides the filtered route for venting from the reactor system, as used during the accident.
The radiation levels indicated by these off-the-scale readings mean that no worker can approach to within a few metres of the areas to take detailed manual measurements. Instead, levels were estimated using gamma cameras mounted on robots.
  • #10,839
The SGTS in unit 1 has two units capable of filtering 1800 m3/h each, capturing > 97% of iodine. In unit 2 and 3 there are also two units, capable of filtering 2700 m3/h each, capturing > 99.9% of iodine (source: http://fukushima.grs.de/sites/default/files/NISA-IAEA-Fukushima_2011-06-08.pdf -- page IV-15).
It's a good system except you can't use it when you really need it, because it needs power for its electric blowers and dehumidifiers and can't cope with high temperatures or pressures or very rapid releases.
The weight of 1800 m3 of steam at 100 deg C and 1 bar is just about a single ton of water. You can see how this was not designed to clean up vent gases from a boiling suppression chamber holding thousands of tons of water.
  • #10,840
http://channel6newsonline.com/2011/08/report-japans-fukushima-reactor-possibly-melted-twice/
  • #10,841
So if this insight is put together with the earlier recognition by the NRC that a 24 hr SBO meant a meltdown,
the basis for the US governments recommendation for a 50 mile evacuation zone becomes quite clear.
It also does suggest very strongly that nuclear facilities should have belt, suspenders and a girdle, just in case.
Certainly the current designs do not appear to fail at all gracefully if the emergency venting is just flushed through the stack. That just maximizes the problem. What is the rationale for such a design?
  • #10,842
I think the rationale is the mistaken assumption that extended station blackouts do not happen in the first place. It's a "beyond design base" condition.
However, venting from the wet well air space as in unit 1 does still seem the lesser evil compared to an uncontrolled containment failure from over-pressure as may have happened in unit 2, which is assumed to have released a lot more contamination than unit 1 (think Iitate-mura). At least the vented gas has been scrubbed to some extent by first bubbling it through the pool water in the torus. With a cracked containment all bets are off what gets released.
The hardened vent path was mostly designed with hydrogen releases in mind. The Areva report by Dr. Braun estimate H2 production from the Zirconium-steam reaction in unit 1 as 300-600 kg and 300-1000 kg in units 2 and 3.
At 100 deg C the density of H2 is about 0.065 g/L, or 15 m3 per kg. Therefore to release the non-condensable hydrogen from the air space of the torus would have involved a release of 4500-9000 m3 in unit 1 and 4500-15000 m3 in the other units, not counting the steam also accumulated there or allowing for temperatures beyond 100 deg C.
  • #10,843
Perhaps, but to me it looks like a water-carried distribution of the similar-colored dark stuff splattered around and heaped at the base of the same pipe. And because that heap of red-brown gunk is extremely radioactive and associated with a ventilation/filtration system, it may well be (largely) cesium-vapor residue, which is also dark red-brown.
What we can say for sure is that the stain lines are consistent with some red-brown substance washed down with rain. But that does not entail that it's rust.
Yes I see the tape, it's obvious, but what kind of tape allows rust to fester as you suggest? I don't see why the tape increases the likelihood of the staining being rust. Maybe it's to stop corrosion as you suggest, or then maybe to reduce the escape of cesium-vapor residue in the event of a filtration-system rupture. It might be there for a number of reasons. I doubt we can infer much from the tape being there.
  • #10,844
When it rains hard, as it has recently in the Fukushima area, what happens to all the water that falls down the ventilation stack? After rinsing down the inner walls of the stack, it then hits the bottom, and what? Does anyone know if there is an automatic drain mechanism? Knowing that heavy rain is common here, I'm certain that something has been done to address this issue, but I don't remember reading about it. I'm curious where rain water and condensate goes after reaching the bottom of the stack.
  • #10,845
I agree with joewein.
As I take it, the rationale behind the hardened wet well vents is as a last ditch attempt to prevent a hydrogen explosion or primary containment over-pressurisation, on the basis that either event would release more radioactivity (due to catastrophic failure of the containment) than direct venting of the torus to the environment.
See:
http://www.gereports.com/venting-systems-in-mark-i-reactors/
http://www.nrc.gov/reading-rm/doc-collections/gen-comm/gen-letters/1989/gl89016.html
Ironically all 3 operating units experienced hydrogen explosions and the hardened vents did nothing to prevent these. It appears that in at least one case (unit 1) the hardened vent was operated as well, created the worst of both worlds.
  • #10,846
I have a nasty suspicion that the rain water simply is passed to the normal storm water system and then to the ocean and/or ground water. The rationale being that on the "design basis" only filtered gases are exhausted through the stack. Remember that the hardened vent was a retrofit.
  • #10,847
joewein said:
snip >
<snip.
This document appears to indicate the operators aligned the venting from both drywell AND S\C. No scrubbing from the drywell venting.
The document also indicates very high dose rates in the buildings and onsite well before the venting even took place. To my laybrain that seems odd - was there containment failure before they even got to vent?
source : http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110618e15.pdf"
On the SGTS\HVS contamination - why the high dose rates in the Unit 1 Turbine building early on? And why does SGTS even go into the turbine building? Why does the SGTS appear to be HEAVILY contaminated, it shouldn't have even been possible for it to be working after loss of power. So SGTS just opens itself up on loss of power? WTF. The more I read about the design of these systems the less I want to know, kind of.
  • #10,848
Let me suggest these possible flow patterns that seem to be both logico-physically intuitive and empirically observed:
By stalagmatic accumulation I refer to the process slow water-carrier driven http://en.wikipedia.org/wiki/Stalagmite" .
Moreover, the same rust-colored stain (that I propose is http://iangoddard.com/journal/fukushima/cesiumCOLOR.jpg" .
  • #10,849
If the RPV steam from the pressure release valves is always released into the wetwell, the air space there should be much more contaminated than the nitrogen in the drywell. The drywell would get more severely contaminated later on, once the RPV melts through or the seals around it start leaking, but initially all the good stuff ends up in the torus.
There may be some exchange of pressure via the downcomer tubes between the two if there is a large pressure differential (will water get pushed up the tubes if pressure gets too high in the torus, opening a path for contaminated gas to leak from the torus into the drywell?), but my understanding is that until the RPV gets damaged by excessive temperatures the wetwell would be the more contaminated of the two spaces.
It says they prohibited entry to R/B 1 at 21:51 on 2011-03-11 because of radiation (about seven hours after the quake). Tepco estimates that fuel was exposed five hours after the quake because the water level had fallen too far. So by the time they prohibited entrance, the meltdown had been in progress for about two hours. I don't know what the containment pressure was like by then, but 4 hours later, at 02:00 JST it was 0.6 MPa and at 05:30 it was at 0.82 MPa. The containment may already have been near or at design pressure (0.42 MPa = 4.2 bar) when the radiation went up.
For radiation levels inside the building to go up without venting there must have been some leaks. But in a way it is not surprising that the unit 1 containment was leaking in 2011 (when it was 40 years old and stressed to the max by a melting core) when it had already leaked unacceptably in 1992 during routine inspections when tested at 3 bar:
Faked pressure test
Yet in the most serious case of all, Tepco officials are alleged to have faked a pressure test designed to test the integrity of the containment building. The test involves pumping nitrogen gas into the building to increase the pressure to about three times atmospheric pressure, then taking pressure readings to measure the leak rate.
Regulations state that the leak rate must be less than 0.45% per day. However, at Fukushima I-1 in 1992, the company conducted its own tests before the government inspectors turned up, and discovered that the building might not pass the test. One source quoted in the Daily Yomiuri said that leak rates fluctuated from 0.3% to 2.5% per day.
Documents found at Hitachi by Tepco’s own investigative team describe a method to fake the test by secretly pumping in extra air from the main steam isolation valve. At the time, Hitachi had a contract to check Tepco equipment. It is alleged that Tepco officials followed this procedure when the government inspectors were checking the leak rate.
http://www.klimaatkeuze.nl/wise/monitor/574/5441
2.5% of several thousand cubic meters of nitrogen at 3 bar is several hundred cubic meters that would have leaked per day.
Probably because most of the pipes coming out or going into the containment go next door to the turbine building. It's like the belly button of the reactor. The turbine hall is also more spacious.
  • #10,850
That is a very interesting question. Note that the guy who measured the radiation with a 3 meter long pole (and took a 40 mSv hit) http://www.tepco.co.jp/en/news/110311/images/110802_1.jpg" inside the structural frame of the stack pipe.
  • #10,851
Faked pressure test
The following NISA report, written in December 2002, contains a time-line. Here are a few translated excerpts :
September 25 (Wednesday). The Yomiuri Shimbun evening edition reports that fraud took place, during leak rate tests conducted in 1992.
November 06 (Wednesday). Start of legally required on-site inspection regarding the leak rate of the concerned unit.
November 29 (Friday). A one-year shut-down of the concerned unit is ordered.
December 05 (Thursday). Tepco announces that, regarding the concerned unit, it obtained a leak rate measurement result of 0.092% / day which satisfies the standard criteria.
http://www.meti.go.jp/report/downloadfiles/g21224d0122j.pdf p. 15-16
The 28 May 2004 Tepco press release announces the following :
28 May (Friday) 10:00~16:00 : 0.122% / day (below the 0.348% / day standard criteria)
27 May (Thursday) 10:00~16:00 : 0.123% / day (below the 0.348% / day standard criteria)
http://www.tepco.co.jp/fukushima1-np/bi4509-j.html
The 15 December 2010 press release about regular inspection No. 26 (March 2010 -December 2010) says :
13 July 08:00~14:00 : 0.166% / day※ (below the 0.4% / day standard criteria) (※ 95% confidence limit - upper limit)
http://www.tepco.co.jp/nu/f1-np/press_f1/2010/pdfdata/bi0c06-j.pdf page 5 (pdf page number 7)
http://www.tepco.co.jp/nu/f1-np/press_f1/2009/pdfdata/bi9714-j.pdf (page 5) 17 February 2009 : 0.176%
http://www.tepco.co.jp/nu/f1-np/press_f1/2007/pdfdata/bi8116-j.pdf (page 7) 12-13 September 2007 (24 hour test) : 0.101%
  • #10,852
An interesting (1) theory is proposed to explain the March 20~24 radiation peak in the Kanto area:
A second meltdown likely occurred in the No. 3 reactor at the Fukushima No. 1 nuclear power plant, a scenario that could hinder the current strategy to end the crisis, a scientist said.
One factor used by Tanabe in speculating that a second meltdown occurred is the increase in radiation levels from the morning of March 21 in areas downwind from the Fukushima No. 1 plant, such as the Fukushima No. 2 nuclear power plant as well as the Kanto region municipalities of Kita-Ibaraki, Takahagi and Mito.
Initially, officials of the Nuclear and Industrial Safety Agency explained that the higher radiation levels were caused by radioactive materials falling to the ground with the rain.
But there is also the possibility that additional radioactive materials emitted from the second meltdown may have been blown by the wind.
Between 1 a.m. and 3 a.m. on March 21, the pressure within the pressure vessel of the No. 3 reactor core increased sharply to about 110 atmospheres, likely caused by an explosion within the pressure vessel due to a lack of cooling of the fuel. That was probably the start of the second meltdown, Tanabe said.
http://www.asahi.com/english/TKY201108080276.html "Report suggests second meltdown at reactor at Fukushima plant" by Tomooki Yasuda staff writer
See also the diagrams on the Japanese language article page : http://www.asahi.com/national/update/0807/TKY201108070330.html
(1) I discussed the 21 March radiation peak in Mito City in April on https://www.physicsforums.com/showthread.php?p=3258064&highlight=Mito#post3258064 and again in May in relation with the 21 March 8~12 MPa unit 3 pressure data on https://www.physicsforums.com/showthread.php?p=3308800&highlight=Mito#post3308800
http://www.nikkei.com/news/category...39797E3E2E2E2;at=DGXZZO0195165008122009000000 The unit 1 SFP cooling system will be launched on 10 August. The remote-controlled construction of the steel frame of unit 1's cover structure will be achieved by mid-September. SARRY will be launched next week.
  • #10,853
Thank you, tsutsuji!
From 0.101% to 2.5% leakage per day seems like a huge spread. I wonder what measures they took to reduce the leakage and if this is tested while the reactor is in cold shutdown or powered up. Temperatures could hugely alter tolerances due to thermal expansion and contraction.
I checked the operating records and for example the 2007 figure for unit 1 was measured more than 6 weeks before the reactor went on the grid again and after 9 months of shutdown.
The Mark I containment in unit 1 seems to have a free volume (dry+wet) of 5800 m3, of which 2100 m3 is water in the suppression chamber and 3700 m3 is space for nitrogen. A permitted leak of 0.4% per day of 3700 m3 is 14,800 liters of containment gas per bar of internal pressure. In a station blackout the SGTS could not take care of cleaning up any contamination from that.
  • #10,854
You're welcome, Joewein. Note also the 0.092% rate I mentioned above, measured by Tepco 15 days after the 20 November 2002 shutdown.
joewein said:
I wonder [...] if this is tested while the reactor is in cold shutdown or powered up.
Sealing tests are usually carried out at the last phase of government inspections
http://www.thefreelibrary.com/Agency+begins+probe+into+TEPCO+data+manipulation+case.-a093437939
Which perhaps leaves plenty of time if the company wants to perform its own informal tests beforehand. So It seems that the tests are usually performed during cold shutdown. Wouldn't it be dangerous to perform tests while the plant is in full operation ?
  • #10,855
I think the brown/red stuff is from rainwater that gets between the insulation and the outside of the pipe itself that is flowing to the bottom and out the gaps as rust.
You can see similar deposits near that railing and this facility is bordering the ocean which causes things to rust at unbelievable rates.
  • #10,856
or you could go and look at some drawings of say Oyster Creek as an example that show the sump pumps in the base of their stack are indeed fed to rad waste treatment.
http://pbadupws.nrc.gov/docs/ML0522/ML052220603.pdf"
Even when things are normal at these plants the stack emissions are still not 100% clean by any measure so it would be a given any fluid in the stack sump\s should be sent to treatment not to normal stormwater.
  • #10,857
http://mainichi.jp/select/today/news/20110810k0000m040046000c.html Struck by a lightning at 8:20 PM on 8 August, the water treatment facility was shut down for two hours as a wrong signal was emitted by some storage tank's water level gauge and a fuse was blown at another tank. The facility is not equipped with lightning countermeasures. Junichi Matsumoto said "if long term use is considered, countermeasures are needed".
http://www.nikkei.com/news/category...39797E3E2E2E2;at=DGXZZO0195165008122009000000 The utilization rate for the 3 August - 9 August week is 77%. This is short of the 90% goal for August. Tepco admits that the plan to treat all the accumulated water by the end of the year will be "a little delayed". On the one hand, the bypass lines which have been used since 4 August have enabled to greatly recover from the flow rate decline, but on the other hand, the facility stopped for 7 and a half hours on 7 August. A gas sample from unit 2 containment vessel was analysed, finding a radiation level lower than expected, and Xe and Kr among the radioactive substances.
http://www.tepco.co.jp/cc/press/betu11_j/images/110810g.pdf 3 August - 9 August water treatment weekly report (Japanese)
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110810_03-e.pdf "Results of Gas Sampling inside the Primary Containment Vessel of Unit 2 Fukushima Daiichi Nuclear Power Station"
http://www.tepco.co.jp/en/press/corp-com/release/11081003-e.html [unit 1] "At 9:00 am on August 10, we started to assemble steel frame for the Reactor Building Cover"
http://www.tepco.co.jp/cc/press/betu11_j/images/110810l.pdf Update of the worker radiation exposure statistics (Japanese)
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110810_02-e.pdf Water level gauge problem at the desalination facility, causing a shutdown from 1:50 to 9:35 AM.
  • #10,858
The detection of Kr-85 (if the results are correct) is interesting. As far as I am aware, Kr-85 is not produced in the long decay chains, so all of it has been around ever since the fissions stopped. If it is still found in the containment, my first impression is that either
(a) the containment has somehow been able to contain the noble gas Kr-85 ever since the fuel failures occurred in spite of the leaks and the suspected hydrogen explosion early on during the accident
(b) Kr-85 has been released to the containment atmosphere more recently, which means that some fuel rod claddings have lost their integrity only recently
  • #10,859
c) corium is still outgassing
  • #10,860
As far as I am aware, noble gas releases from fuel would have reached 100 % before it even starts to melt. Therefore, the only way I see new release of Kr possible is that part of the fuel would have not overheated to 100 % release levels (=would possible have maintained their cladding integrity and would continue to slowly release noble gases). This is exactly the point I found interesting about the results: to me it seems that either the containment is able to contain noble gases for a long period of time or part of the core must have remained unmelted.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
470K
21K
  • · Replies 763 ·
283K
  • · Replies 38 ·
17K
12K
