Phase difference and path difference
The discussion revolves around the concepts of phase difference and path difference in the context of waves, particularly focusing on their definitions, implications in wave behavior, and examples illustrating these concepts. Participants explore both theoretical and practical aspects, including simple harmonic motion and wave interference.
  • One participant describes phase difference using the example of two masses on springs, noting that they are in phase when they reach maximum and minimum heights together, and out of phase by half a period when one is at the bottom and the other at the top.
  • Another participant explains that the path difference between consecutive crests of a wave is one wavelength, which is the distance the wave travels in one period.
  • A participant elaborates on the concept of path difference in the context of waves traveling different distances to a receiver, highlighting the impact of reflections and multiple paths on phase differences and interference.
  • It is noted that the phase difference can also be quantified in terms of angular measurements (e.g., 180 degrees or pi radians) and time differences (e.g., half a period).
  • One participant emphasizes that the relative path difference leads to a relative phase difference, which can result in interference effects, particularly in scenarios like double slit experiments.
Participants express various viewpoints on the definitions and implications of phase and path differences, with no consensus reached on a singular explanation or model. The discussion remains open-ended with multiple interpretations presented.
Some participants mention specific examples and applications, such as simple harmonic motion and double slit interference, but the discussion does not resolve the complexities or nuances of these concepts.
Misr
Hello,
What are phase difference and path difference?
Can you give me a simple explanation so that I could imagine
It would be great if there are some illustrations
Thanks
Science news on Phys.org
Consider two particles performing simple harmonic motion. Like two masses hanging on two different vertical springs. If the masses go to the maximum height together and go to the lowest height together, then the two particles move in phase with each other. But if when one is at the bottom, the other is at the top, then they are out of phase with each other by half a period (or by 180 degress or by pi radians).
The diagram can represent a wave going along a rope.
The two arrows at the crests are in the same direction - showing that those two parts of the rope are moving in phase with each other. The path difference between these two (consecutive) crests is one wavelength, i.e.the distance the wave travels in one period.
how?
Two points on a wave, one on a crest and the other one on a trough (which immediately follows the crest), can be distinguished by:
a) phase differece i.e. 180 degrees or pi radians;
b) time difference i.e. half a period;
c) distance difference i.e. half-wavelength.
Note that the distance between two consecutive crests is called 'wavelength'.
e.g. the frequency of a wave is the number of wavelengths going through in 1 second.
Typically when we are talking about path difference when it comes to traveling waves is that we are discussing literally the difference in the distance traveled by two different waves. Take for example if we have a source in a room where a receiver is also placed. There are multiple paths that the waves from the source can take to reach the receiver. The primary path is the direct path between the source and receiver. But there is also a possible path due to reflections from the walls of the room. You have a path where you have a single reflection, two reflections, etc. Each of these will reach the receiver but they will have relative path differences due to the different total distances travelled.
The relative path difference is important because the phase of a wave progresses as it travels over a distance. So because these waves have a relative path difference, they will also have a relative phase difference which can give rise to interference. This occurs despite the fact that when they were originally produced at the source they did not have a phase difference.
So the path difference can be taken to be the difference between the distance traveled by two different waves or it can also be taken as the phase difference that arises between two waves due to the different distances travelled.
EDIT: The double slit interference is a good visual example of interference due to the path difference. The two slits produce waves that start out with no relative phase difference. But the interference arises because the two waves usually have to travel different distances to reach a certain point.
19K
  • · Replies 37 ·
