Cyclic Fusion Reactor. Passing through each other colliding beams.
The discussion revolves around a proposed concept for a cyclic fusion reactor, focusing on the mechanics of colliding beams to achieve fusion. Participants explore the feasibility, efficiency, and theoretical underpinnings of the concept, comparing it to existing fusion technologies such as tokamaks.
  • One participant presents a new concept for a cyclic fusion reactor, suggesting it could achieve breakeven, unlike tokamaks.
  • Another participant questions the complexity of the proposed method and challenges the estimates on power usage, emphasizing the low probability of nuclei fusing per collision.
  • Concerns are raised about the energy required to confine particles while they are not fusing, which could lead to energy waste.
  • Some participants argue that the Lawson Criterion is not solely about fusion power output but also relates to the efficiency of energy conversion, suggesting that the proposed reactor's assumptions may be overly optimistic.
  • There is a discussion about the energy gain factor (Q), with one participant providing calculations that suggest a Q value greater than 10 based on energy expenses and gains from fusion events.
  • Questions are posed regarding the use of cross-section calculations in the proposed energy gain estimates.
  • Disagreement exists over the interpretation of the Lawson Criterion and its relevance to the efficiencies of fusion reactors, with some asserting that it should not be dismissed as merely optimistic.
Participants express differing views on the feasibility and efficiency of the proposed cyclic fusion reactor compared to existing technologies. There is no consensus on the validity of the Lawson Criterion's application or the assumptions made regarding energy efficiency and fusion probabilities.
Limitations in the discussion include unresolved mathematical steps regarding energy calculations and differing interpretations of the Lawson Criterion's implications for reactor efficiency.
  • #31
Drakkith said:
Again, how can you ignore the lost power during scattering events? They may eventually fuse but until then they just consume power. I don't see this in your power calculations. Those are integral in determining Q.
Power my dear is energy release of certain number of really occurred fusion events per unit of time.
So we can specified all input/output per a single occurred fusion event
  • #32
That's sorry is nonsense.
Confinement time (duration) means that to allow some certain number of paticles to fuse not in one moment.
But needs some time during which we should confine plasma.
The main thing here that invention allows particles the opportunity to participate in multiple collisions from which some will end with fusion event and if scattering then scattered particle will return back for one more time attempting to fuse.
The main thing here a new confinement concept allowing all mentioned.
Alright, this is the second time you've claimed that losses due to scattering is nonsense. As I will explain again for the last time, the longer a particle takes to fuse the more energy is consumed to confine it. You have completely ignored this point as far as I can tell. I also don't see anywhere in your power calculations where you have taken into account the power consumed to confine the particles via external magnetic and electric fields.
Input power is not. Input power is the power over time required to produce X number of fusion events. That is what you need to be looking at, not power per reaction.
If you really interested you should read text more carefully. As scattered particle will return back to the axis losing only very little part of energy.
Only that part that particle being in returning motion transferred momentum to electron gas.
Then that little loss will be compensated with acceleration by induction electric field.
I'm not talking about particles losing their energy, I am talking about power consumed to confine them.
  • #33
That's not so.
Please learn a little bit more about issue before you are discussing it.
  • #34
This is easy to take care of. Simply tell me WHY I am incorrect. Let's look at your calculation:
(300keV+1/75*33MeV+200keV+1/50*33MeV)/0.8=2MeV
Where is the power from the external magnets and electric fields used to keep the particles in place? You cannot calculate Q without them. See here:http://en.wikipedia.org/wiki/Fusion_energy_gain_factor
Also, I cannot see where you get this 80% from. Are you saying that 80% of the ions will eventually fuse by a certain point in time? If so, then you have to include all of the energy used by the confinement methods during that time period.
That's not so.
Yes it is. Look at your posts. Two times you have told me that scattering doesn't result in energy loss. This is 100% false. It slows down ions, knocks them out of place, and causes them to take extra time before they fuse. If you try to deny it then you have no idea what you are talking about. Period. It doesn't matter that they ions come back to the beam, that only lessens the loss, not stop it.
  • #35
• Bending magnetic field does not required energy for bending of beams if not considering synchrotron radiation but this is not that case.
• Elastic collisions causing scatterings also will accelerate slower moving ions decelerating faster moving ions. Ions energy losses occur only via transferring the little part of gained via scattering radial momentums before ion will return to right direction. This is not your lovely Polywell in which scattered ion does not return back and then scattered again and again. And so all energy losses for fusion.
• Concept can provide to near 100% of particles the fusing capability. But for that infinitely long confinement duration is required. But 80 % fusion will occur during acceptable time.
  • #36
Joseph Chikva said:
• Bending magnetic field does not required energy for bending if not considering synchrotron radiation but this is not that case.
Bending? Just generating the field takes power. Same with the electric fields.
• Elastic collisions causing scatterings also will accelerate slower moving ions decelerating faster moving ions. Ions energy losses occur only via transferring the little part of gained via scattering before ion will return to right direction.
Again, I am not referring solely to energy losses from the ions, but also to the increased time it takes for each ion to fuse because of these collisions.
This is not you lovely Polywell in which scattered ion does not return back then scattered again and again. And so all energy losses for fusion.
Provide me with some evidence that your device will cause ALL scattered ions to return.
• Concept can provide near 100% particles the fusing capability. But for that infinitely long confinement duration is required. But 80 % fusion will occur during acceptable time.
I see absolutely nothing that says that. You haven't provided any estimated time, you haven't calculated used power for that period of time, and you don't seem to understand the basics of the Fusion Gain Factor or the cross section. In fact, this entire thread tells me that you seriously need to go back and look at your device. I'm done wasting my time here.
  • #37
I have never read a bigger nonsense. The time has increased in comparison with what?
I can not help you if you do not know that unidirectional currents attract each others.
I think that you are wasting your time always when talking about fusion. As you have nothing to do with discussing issue.
  • #38
I missed something:
Here, my friend:
The raw estimation of energy consumptions during namely fusion process (pinch, accelerating particles for compensation of alignment of ions’ velocities and also for compensation of electron radiation losses) specified on a single fusion event – 0.7MeV.
So, the raw estimation of total energy consumption specified per a single fusion event
2MeV+0.7MeV=2.7MeV?
  • #39
Drakkith said:
Why would it be too optimistic? It's just one goal on the way to the finish line. It is a given that you must include efficiency of input and output power for a working reactor.
About Lawson criterion and some thought concerning breakeven.
Considering fusion experiments using thermal plasma e.g. Tokamak
Initial “ignition”
Tremendous energy should be spent (pumped) for achievement the required temperature (heating)
Plasma creation (discharge) and Ohmic heating.
• Initially very strong toroidal induction electric field is created
• Pulling out of some electrons from their orbits under the influence of electric field (primary ionization)
• Acceleration of electrons in one direction and ions to opposite. As electrons have much higher rate of acceleration, they gain energy faster transferring then energy to other particles finally ionizing gas and heating plasma. Initially the temperature of electron gas much higher, but then thanks to multiple collisions ions’ and electrons’ temperatures are almost equalized. For occurrence of that equalization some time is needed.
• Occurrence of Bremsstrahlung (energy loss) together with hot plasma conductivity increasing limiting the maximum achievable temperature via Ohmic heating.
RF (cyclotron resonance) heating and its energy losses.
• Efficiency of RF generators?
• Efficiency of absorption of RF radiation by plasma?
Heating via neutrals beams
• By my information only 30% of neutrals can be absorbed by plasma, remaining 70% hit walls
• Efficiency of charged particles accelerators?
• Efficiency of neutralization of those beams in neutralization chambers?
So, can anybody say that Lawson criterion considers all above mentioned?
Criterion written in 50s of past century!
And if/when Lawson criterion will be achieved how far will we be from real capability to produce net power?
As that criterion estimates only certain limit overcoming of which “self-burning” is possible.
But achieving “self-burning” capability we before should spend a lot of energy for providing above mentioned processes (heating, etc.) and also should produce some electricity.
And I am sure that TOKAMAKs as well as other experiments are very far from their purposes.
  • #40
I have altered an estimation of power balance for expressing it in more accessible form.
The raw estimation of required energy that should to be put into the beams specified on a single fusion event (initial energy consumption of a single fusion event)
In case if only 80% of nuclei will react initially we should spend per one fusion event:
The creation and further maintenance process of inducing an accelerating electric field (its loading with the proposed beams) will connect with additional energy expenses.
2MeV+0.7MeV=2.7MeV
From the other side we will have from each fusion event:
Thermal energy specified per a single fusion event:
• 14.1MeV of energy of neutron in center-of-mass frame
• about 0.1MeV of additional energy of neutron considering the non-zero velocity (4.3*10^6 m/s) of ions’ center-of-mass frame
• about 0.5MeV of X-ray radiation (have to be stopped by protection wall – energy of photons converted into thermal energy)
• 1.25*4.8MeV=6MeV of thermal energy via (n+Li6) reaction (where “1.25” is a Tritium breeding coefficient)
So, total 20.7MeV of thermal energy
Charged particles’ energy specified per a single fusion event:
• 3.5MeV of energy of He4 (alpha-particle) in center-of-mass frame
• about 0.4MeV of additional energy of He4 considering the non-zero velocity (4.3*10^6 m/s) of ions’ center-of-mass frame
• (0.2MeV+0.3MeV)*0.2=0.1MeV of energy of non-reacted ions
• (1/50+1/75)*33MeV/0.8=1.375MeV of electrons
So, total 5.375MeV of charged particles’ energy
Input/output energy balance:
input 2.7MeV vs. 20.7MeV (thermal) + 5.375MeV (charged particles) output
Energy conversion efficiency
Input
Taking into account the really achievable efficiency of beams’ generation and also the efficiency of their further maintenance – ~35%, we will have the total energy consumption specified per a single fusion event equal to:
2.7MeV/0.35=~7.72MeV
Output
Thermal cycle
In modern power plants the efficiency of 40% is achievable. And so:
20.7MeV*0.4=8.28MeV
Direct energy conversion of charged particles
Efficiency of 50% is achievable. And so:
5.375MeV*0.5=2.68MeV
Projected net power specified per a single fusion event:
8.28MeV+2.68MeV-7.72MeV=3.24MeV
  • #41
What exactly does this mean?
  • #42
This means that if you have for example 100 pairs of reacting particles:
• 100 faster moving ions with energy 300keV each
• 100 slower moving ions with energy 200keV each
and then only 80% of them will fuse, the spent energy specified per a single fusion event will be not 300+200=500keV but 500keV/0.8=625keV
  • #43
How did you come up with 80% of them will fuse?
  • #44
100 % of fusion demands the infinitely long confinement time.
While 80 % demands an order of milliseconds.
I want that repeatability of impulses will of 10 Hz order as that is technically feasible on base of today's accelerators technology.
And 80 % acceptable if gives positive energy balance.
  • #45
No I mean how did you actually determine that 80% of the ions will fuse within this time period?
  • #46
That estimated on base of following:
• Center-of-mass collision energy – 20.2 keV
• Reaction cross section – 0.4 barn
• Ions’ relative velocity – 1.8*10^6 m/s
• Ions number density – 10^22-10^23 m^-3
About millisecond.
  • #47
Is the density of the ions being reduced as more and more fuse? What kind of effect would that have? I'm assuming you don't "replenish" them during this time period. Or do you?
  • #48
Yes, during fusion the density of reacting ions reduces and so - reduces fusion rate by square of density. Nevertheless we need only an order of millisecond for mentioned initial number densities.
After each fusion cycle reaction zone should be freed for a new cycle. Or in the other words remaining charged particles should be extracted to Direct Energy Converter.
  • #49
Alright. Good luck with your device. I'm off to bed now.
  • #50
Good night.
  • #51
I just calculated energy consumption for the following parameters:
• Deuterium - 450keV
• Tritium - 300keV
• Electron - 40.6MeV
And energy consumption specified per a single fusion event is about 1.8MeV
Taking into account that collision energy in center-of-mass frame for this case is 30keV (30keV vs. 20.2keV) and so ratio between fusion and scattering sections is more attractive, we should also wait less further energy losses that for previous case estimated as 0.7MeV per each event.
  • #52
http://meetings.aps.org/Meeting/DPP11/Event/153438
- - - - > SCHEDULING NOTICE FOR:
53nd Annual Meeting of the APS Division of Plasma Physics
Co-located with the 64th Annual Gaseous Electronics Conference
November 14-18, 2011
Salt Lake City, Utah
The abstract you submitted:
(Abstract Log Number DPP11-2011-000008)
'New Fusion Concept Using Coaxial Passing Through Each Other Self-focusing Colliding Beams (Invention),'
has been accepted and scheduled for session UP9, (Poster Session VIII: C-Mod Tokamak; DIII-D II; Solar, Interplanetary, and Magnetospheric Plasma Physics; Plasma Technology; )
which will begin at 02:00 PM on Thursday, 11/17/11 in room: Hall A.
APS Meetings Department
E-mail
(301) 209-?
  • #53
Good luck! Hope it goes well for you!
  • #54
Thank you.
  • #55
Good luck with your presentation! Let me know how it goes.
  • #56
Thank you too.
  • · Replies 26 ·
  • · Replies 22 ·
  • · Replies 29 ·
  • · Replies 19 ·
10K
