Is there really any such thing as an incompressible liquid?
The discussion centers on the concept of incompressible liquids, concluding that no liquid can be 100% incompressible. Using the example of lobsters in two sealed boxes at different depths, it is demonstrated that the pressure experienced by the lobsters differs due to the slight compression of the liquid in the deeper box. This contradiction highlights that even liquids deemed incompressible must exhibit some degree of compression under pressure. The conversation suggests that this topic transcends a simple homework problem, delving into philosophical implications in physics.
  • Understanding of fluid mechanics principles, specifically pressure and depth.
  • Familiarity with the equation for pressure in fluids: p = pgh.
  • Basic knowledge of compressibility and its effects on liquids.
  • Awareness of philosophical discussions in scientific contexts.
  • Research the properties of incompressible fluids in fluid dynamics.
  • Study the effects of pressure on different types of liquids and their compressibility.
  • Explore philosophical implications of scientific concepts in physics.
  • Investigate the material properties of containers and their impact on fluid behavior.
Students of physics, fluid mechanics researchers, and anyone interested in the philosophical aspects of scientific principles will benefit from this discussion.
Abu Rehan
Given- Pressure increases with depth.
We know that pressure under a depth h is given by pgh. Where p=density of liquid, g= acceleration due to gravity.
Let us take an example.
There is an ocean of a liquid which is 100% incompressible. At a depth h there is a lobster experiencing a pressure of pgh. Suppose we go deep inside the ocean and seal the lobster and the liquid in a box. Clearly, the lobster is still experiencing the same amount of pressure. We bring the sealed box above with us. We take another box, pour some water in that, put a lobster in that and seal the box.
Now observe the two boxes. If the liquid is incompressible then the two boxes are identical(apart from the compression in lobster's body). But we earlier saw that the first lobster is experiencing much more pressure than the second one. So we arrive at a contradiction. Therefore there must be something different in case of the first box i.e., it must have a little compressed liquid. The decrease in volume may be very very little but compression must be there. What is relevant is the pressure. Some liquid may apply huge amount of force by getting compressed very little while others may apply that amount of force by getting compressed a lot.
Therefore however incompressible a liquid may be, it cannot be 100% incompressible.
This doesn't appear to be a homework problem, it's more of a philosophy of science issue like light flexible strings and massless pulleys. Possibly it would be better served up in one of the general physics forums for discussion.
Also, you forgot about the compressibility/flexibility of the box material :smile:
  • · Replies 46 ·
14K
