So I need to make a superconducting tube.
The discussion focuses on creating a superconducting tube using YBCO (Yttrium Barium Copper Oxide) or BSCCO (Bismuth Strontium Calcium Copper Oxide) with liquid nitrogen as the cooling medium. The user considers purchasing YBCO powder and shaping it through pressing or using a binder, while expressing concerns about structural integrity and superconductivity. An alternative suggestion is to use palladium hydride, which becomes superconducting at liquid nitrogen temperatures. The conversation highlights the possibility of sintering YBCO using a high-temperature furnace with MoSi2 elements.
  • Understanding of superconductivity principles
  • Familiarity with YBCO and BSCCO materials
  • Knowledge of sintering techniques
  • Experience with high-temperature furnaces
  • Research YBCO powder sourcing and processing techniques
  • Learn about sintering methods for superconductors
  • Investigate the properties and applications of palladium hydride
  • Explore high-temperature furnace specifications and operation
Researchers, materials scientists, and engineers interested in superconductivity, particularly those looking to fabricate superconducting materials or conduct experiments involving YBCO and BSCCO.
TimDubya
Preferably YBCO or BSCCO as I only have liquid nitrogen at my disposal. The issue I'm running into is that no HTS producer makes superconductors in this configuration. I was thinking of just buying the YBCO powder and then either pressing it into the desired shape or mixing in a binder of some kind. The problem with pressing would be structural integrity and the problem with a binder is it might inhibit some aspects of the materials superconductivity. The dimensions don't really matter for this tube as the experiment I'm doing can be scaled, just so long as the length is like 5 or more ID's.
Any assistance would be greatly appreciated.
You could try using palladium hydride, which is basically palladium supersaturated with hydrogen. It becomes super conducting at LN temperatures
I'm surprised that none of the companies out there would be willing to cast a YBCO tube and sinter it to whatever your specifications are. Perhaps you haven't gotten in touch with the right people.
Anyway, as long as you have access to a high temperature furnace (MoSi2 elements would suffice) you can sinter YBCO yourself.
  • · Replies 19 ·
11K
  • · Replies 19 ·
13K
11K
