Calculating how fast a motor can move something in horizontal motion
The discussion focuses on calculating the horizontal motion speed of an object using a Hitec HS-322 servo motor. The user applies the horsepower formula, deriving a power output of 0.0028 horsepower and subsequently calculating a velocity of 4.6 m/s for a 0.2 kg object. Key considerations include the effects of drag and friction on the motor's performance, particularly in small devices. The importance of verifying dimensions in equations is emphasized to avoid calculation errors.
  • Understanding of torque and its units (kg*cm, lb/ft)
  • Familiarity with horsepower calculations and conversions
  • Knowledge of kinetic energy equations and their application
  • Basic principles of drag and friction in motion
  • Research the effects of drag and friction on small motors in horizontal motion
  • Learn more about torque conversion and its impact on motor performance
  • Explore advanced horsepower calculations for different motor types
  • Investigate methods to optimize motor efficiency in practical applications
Engineers, robotics enthusiasts, and students working on projects involving motor-driven horizontal motion and performance optimization.
caljuice
So I need a motor for a project. The motor I'm looking at creates circular motion. I want to make the motor move some object in a horizontal motion but I want to know how fast it can move the object horizontally before getting it. How can I find out how fast the motor can move it?
Motor in mind:
http://www.servodatabase.com/servo/hitec/hs-322"
Sorry if there are unnecessary unit conversions. Seems like engines are explained in imperial units.
Using this equation to find horsepower = (Torque x Engine speed (rpm)) / 5,252 = Horsepower
Found from:http://www.howstuffworks.com/question622.htm"
Torque for engine = 3.70 kg*cm = 0.03 kg per m = 0.22 lb/ft
speed = 0.15 sec/60° (not really sure what this is? Assuming 60 degrees every .15 sec. So one revolution (360 degrees) = 0.15 sec x 6 = .90 sec. Then rpm = 66.7
Mass of object being rotated =0.2 kg
One way I thought of calculating this was converting the torque output to Power then converting power to work then to kinetic energy to velocity.
Horse power = 0.22 * 66.7 /5252 = .0028 horse power
Mechanical horse power = 33,00 lb*ft/min so (0.028 * 33,000)/60s= 1.54 lb*ft =2.09 n*m
I'll assume all work will equal KE. 2.09 J = 0.5 *0.2*v2
V= 4.6m/s.
Does it look right? Any help would be appreciated.
Think about this: you said 'horizontal' motion. What if anything limits the velocity if you continually apply a certain amount of power to a mass moving horizontally?
BTW on the rhs equation of 'mechanical horse power' the dimension is energy, not power, so I would check that. Always check dimensions on any work you do. Every single term. I find more mistakes I make that way than with any other, by a mile!
I'm guessing you mean drag and friction? Would it still affect it a lot with the device being so small? I don't think I would be able to calculate it with the information I'd have.
Sorry isn't it in energy already? 2.09 Nm is Joules.
  • · Replies 20 ·
36K
  • · Replies 31 ·
  • · Replies 18 ·
36K
