What Is the Connection Between Energy, Potential, and Work?
  • Context: High School
  • Thread starter Thread starter nouveau_riche
    Energy Work
The discussion revolves around the concepts of energy, potential energy, and work, exploring their definitions, interrelations, and implications in various contexts. Participants engage in clarifying these terms, examining their meanings in physics, and discussing conventions related to positive and negative energy.
  • Some participants define energy as the capacity to do work, questioning the nature of potential energy in this context.
  • One participant suggests that potential energy encompasses all forms of energy that are not kinetic energy.
  • There is a discussion about the conservation of energy, with some noting that the actual value of energy may not be important in many situations.
  • Participants mention that energy can be positive or negative, with some attributing this to conventions regarding work and reference levels.
  • Several participants express the need for clearer definitions of energy and work, questioning circular definitions that rely on the concept of energy itself.
  • One participant highlights that the precise meaning of energy may vary across different branches of physics, such as classical mechanics, quantum mechanics, and thermodynamics.
  • Another participant points out that potential energy can be defined in relation to charge, and emphasizes that only differences in energy are physically significant.
  • There is a mention of the total energy being the sum of kinetic and potential energies, with a focus on the importance of considering all types of energy in a system.
Participants express a variety of views on the definitions and implications of energy and work, with no consensus reached on a singular definition or understanding. Disagreements persist regarding the nature of potential energy and the conventions surrounding energy values.
Some definitions and explanations provided by participants may depend on specific contexts or branches of physics, and there are unresolved questions about the adequacy of definitions offered.
  • #31
I wouldn't say that the potential energy is in the charge, I would say that it is in the system. Then what gives the system the energy is the configuration of the different parts of the system.
  • #32
so how would justify that configuration for a particle say electron?
  • #33
An electron, by itself, doesn't have a potential energy.
  • #34
but have the potential to give potential energy
so how does electron gets this potential?
  • #35
Its all about the system man. For example - if we had two massive bodies, then the gravitational potential energy is a property of the system. It isn't a property of one body or the other.
If we had an electron in some external electromagnetic field, then the potential energy is dependent on both the electromagnetic field and the electron.
Another way of thinking is like this: a charged particle gains some kinetic energy. So this energy must have come from somewhere. We realize that it came from the potential energy of the system.
  • #36
Again, not by itself, only as part of a system. Then it is the configuration of the whole system that determines the potential energy.
  • #37
well if that is true then the charge of an electron should be the property of system not some constant value like 1.6x10^-19
  • #38
Why is that? I don't get your logic here. Potential energy is not a property of a particle, but why would that lead you to believe that charge is not a property of a particle?
  • #39
I think he means that an electron has an electric field around it. This is what the potential is. Inserting another charge into the field gives the particle potential energy, at the expense of another form. You can't just pop energy into existence(That would make the existence of energy impossible, though. But unless you're doing some uber-crazy mad scientist on meth type of stuff that hasn't been thought of yet, energy will not change. That's not the point though). I don't think work is the ability to use the energy. I believe it means that energy is transferred from one form/place to another, high to low.
Back to the second charge. It's now in the electric field. But it took work to move it there, as given by the equation W = Fd. Since work is a change in energy between two differing sources, it therefore requires a transfer of energy.
Think of it like a scifi forcefield that you can penetrate if you push hard enough. If you don't push, you don't get through, or maybe even pushed back. But if you push hard enough, and perform work, you can get closer to the source.
If you're wondering about the definition of energy, I don't think there is a perfect answer to it. I just consider it "stuff" that is existence. Without energy, there is no existence. So perhaps one could define it as existence.
  • #40
Defining energy looks like it should be simple but is not. The best way to understand the concept “energy” is to get familiar with it in many different contexts (often by solving homework problems or doing labs). Once you are familiar with the concept of energy you can then appreciate a nice tidy definition of energy. That said, I will take a whack at defining energy.
The first clue to the answer is to realize that energy is not a separate entity; it is property of an entity. (Therefore, you should not imagine little blobs of energy.) In order to avoid the circular definitions pointed out above, you might define energy this way:
energy: a property of entities that makes things happen.
Of course, if you were not already familiar with the concept energy in the real world you would ask, “Wait! Make what happen?” By "happen" I mean to move a thing or change the state of a thing. This is where you need real world experience so you can imagine examples, “Ah, yes, I can move a block and compress a piston.”
In summary, do not worry too much about a tidy definition of “energy” at the beginning; that is putting the cart before the horse. It is better to get familiar with the concept of energy in real world examples in the beginning. Leave the tidy definition to the end.
  • #41
It is simple. In Newtonian mechanics, "Energy is the capacity to do work." Easy, done.
I don't know why people think that energy is so difficult. See:
https://www.physicsforums.com/showthread.php?t=507345
https://www.physicsforums.com/showthread.php?t=498497
Both threads were locked, and both resulted in the ban of one or more of the participants. By going through the existing threads you can probably find the information you need without risking getting banned yourself.
  • #42
I agree this is a good start. The difficulty comes when the new student is told, "Work is the amount of energy transferred to a body."
  • #43
That doesn't seems too bad. Energy is the ability to do something. Work is the amount of something done.
Think of it like this:
A job is an ability to earn money. A wage/salary is merely a measure of how much one earns.
Change it to:
Energy is the ability to change something. Work is merely a measure of the amount of change.
  • #44
it is not about an easy or difficult definition,it's about the unclear context
suppose there is wall i am trying to push,it requires 20 N of force to displace it,i push it with 10 N for the first time,according to you there will be no energy in this case(it will be better if you for a moment will put aside the perception of seeing me,u can only perceive the wall)
so at the end you will not take me in existence(considering you cannot see me)
but 2 seconds later you find that the wall is moving(this time i applied the force of 30N)
so you count my existence
  • #45
There should still be energy at the 10 Newton mark. There just won't be any work done.
Work = Force x distance. In order to perform work, you need energy. Admittedly, there is no work done in the example. However, if the wall were to stop exerting the force on you(I mean not move as a result,it will always exert an equal and opposite reactionary force), the wall would then move. The impeding forces are generally from things like friction and being bolted down. So if the impeding force is eliminated, then the wall would move, and thus work would be done, meaning energy has been exchanged.
Energy must be present if a force is to be applied. I don't know about the things like the strong and weak forces, though, but just in general, a force requires energy.
  • #46
i guess you didn't read what i was saying,i told you to forget about the perception of seeing me,how will you say there is energy?
  • #47
I agree. Often, when solving homework problems or understanding what awriter means by 'energy', the context is not well spelled out. Do you think you understand what energy is now or do you still have any unresolved questions?
FYI- I found a wonderful discussion of energy here:
http://www.ftexploring.com/energy/energy.html
  • #48
No!
  • #49
What you wrote - and what your point in this thread is- is very unclear.
  • #50
I can ignore see you, but you still exert a force. IF you weren't there at all, there wouldn't be a force, anyway, aside from the obvious like air pressure and gravitational. I suppose since I am only a freshman at college, I'm not an expert to back my ideas up. If a comparison can be made where a compressed gas cylinder is pushed against the wall instead of you, it may be easier to explain.
The compressed gas cylinder is held up against the wall. The cylinder has a piston on the wall side that will enable it to push out when it has higher than outside pressure inside it(kind of like those things under chairs than enable the height to be changed). The piston, because the pressure is higher inside the cylinder, pushes on the wall with 10 N of force. This is the same situation as before, except the compressed gas cylinder has replaced you. The cylinder does indeed have energy(potential energy) stored in the compressed gas. Allowing the piston to pull out is the same as doing work. W = p[itex]\Delta[/itex]v, where W is work, p is pressure, and v is volume. The +/- change in the volume matters, too.
If the piston is to push the wall out, it must have energy stored in the compressed gas. Say we compress it to the point it pushes out at 30 N. It will make the wall move, work happens, and energy is transferred. Now say we only compress it to the point it exerts 10 N. The gas doesn't provide enough force to push the piston to make the wall move. BUT it does still have potential energy. I believe this is what you were trying to say it doesn't have.
Forces result when an object with high energy has the ability to transfer it to one with low energy if the conditions are met. Your arm has the high energy in the arm/wall example above. However, it is not high enough to overcome other forces resulting from high/low imbalances. Friction is an electromagnetic force. The electric part repels the atoms if they get too close, unless they're bonding. But because the surface is all uneven, they sometimes have to get closer to other atoms, or go around them entirely by going backwards.This takes energy to overcome. If an insufficient amount of energy is supplied by the object, it can't overcome the friction, and doesn't move.
If we still disagree, I'm going to assume that either one of us is wrong but just can't figure it out, or we're having a communication difficulty. We should probably get a more experienced person to help decide this, then.
  • #51
russ_watters said:
No!
Hmmmm... I was sure it was. Is it necessary for general forces, like pushing or pulling physically? I suppose it could be possible in some higher up thing, maybe even one or two of the fundamental forces. I'm thinking electromagnetism would be a good bet, since it repels by existing. But I don't really understand why the charges repel/attract, either. Could you explain which forces don't need energy to operate, please? I haven't reached higher up classes in my college yet, so I wouldn't have done it in class.
  • #52
If a force is applied to a particle that is perpendicular to the particle's motion, then the particle doesn't gain any kinetic energy.
For example, an electron in a constant magnetic field will go round in a circle, but won't get an increase in energy.
Edit: P.S. I'm talking about the electron as a classical particle here.
  • #53
I wouldn't tell a student that. Work is f.d
  • #54
That is a weird example, but sure. If you exert 10 N over a distance of 0 m then the work is 0 J, and if you exert 30 N over a distance of x m then the work is 30x J. What in any of that is at all unclear?
  • #55
russ_watters said:
No!
i knew someone will pick this line
okay give me an example justifying your "no"
  • #56
i don't know why you are finding this unclear
it is simple in every aspect
in the example i gave you ,just give the way by which you can count my presence considering the fact that you can only do the same by seeing the motion in wall?
  • #57
it's just that you are finding it hard to connect it
  • #58
If there is no motion, there is no energy requirement, as per w=fd. If d=0, w=0, regardless of what f is.
  • #59
Obviously we cannot "count" your presence if we are only allowed to infer your presence due to motion of the wall and you do not move the wall. So what? That is entirely due to the restriction that we are only allowed to infer your presence from the motion of the wall, and has nothing directly to do with energy.
Why do you consider that at all relevant or important to a discussion on energy?
  • #60
You should be self-aware enough to accept that when multiple people have trouble with your use of a pretty basic concept, it's probably not everyone else who has the problem, but you.
  • · Replies 54 ·
  • · Replies 31 ·
  • · Replies 48 ·
  • · Replies 55 ·
