Launching of a Potato (Involve kinetic and potential energy and an angle )
The discussion revolves around a physics problem involving the launch of a potato from a potato gun, incorporating concepts of kinetic and potential energy, as well as projectile motion at an angle. The problem specifies the mass of the potato, the height from which it is launched, the launch angle, and the initial speed, while neglecting air resistance.
  • Mixed
  • Participants explore the calculation of horizontal and vertical components of velocity, questioning how to handle the angle in relation to these components.
  • Some participants express confusion about the concept of horizontal velocity at maximum height and the implications of projectile motion.
  • There are attempts to calculate kinetic and potential energy, with participants seeking clarification on the role of the angle in these calculations.
  • One participant notes the distinction between straight-line motion and curved motion in the context of projectile motion.
The discussion is ongoing, with participants sharing their thoughts and calculations. Some guidance has been provided regarding the separation of horizontal and vertical motion, and there is an acknowledgment of the need for clarification on vector components. Multiple interpretations of the problem are being explored, particularly concerning the angle and its effects on calculations.
Participants mention challenges with understanding vectors and angles, indicating a potential gap in foundational knowledge that may affect their ability to solve the problem. There is also a recognition of the constraints imposed by homework rules, as participants are encouraged to work through the problem without direct solutions being provided.
bluey2014
Launching of a Potato (Involve kinetic and potential energy and an angle!)
A potato of mass 210 g is launched from a potato gun, being released from a height of 0.6 m, at an angle of 47o with respect to the horizontal, and with an initial speed of 38 m/s. Assume the effect of air resistance can be neglected.
mass = 210 g or 0.210 kg
height (initial) = 0.6 m
θ (angle) = 47 degrees
Vo (initial velocity) = 38 m/s
a. What is the horizontal component of the potato’s velocity at the time it is launched?
b. What is the speed of the potato when it is its maximum height? Hint: the answer is not 0!
c. Calculate the kinetic energy of the potato when it is launched.
d. Calculate the gravitational potential energy of the potato when it is launched.
e. Calculate the kinetic energy of the potato when it reaches its maximum height.
f. Using the principle of energy conservation (that is, a Unit 2 technique not a Unit 1 technique), determine how high above the ground the potato rises before beginning its descent.
Vectors have always been an issue for me in this class...as soon as I see an angle I get all mixed up.
Part A: I'm not really sure what is meant by "horizontal component". The potato is being launched upward so it has an x and y value. Would its vertical component be 38 m/s in the y direction? I have no clue...
Part B: This is projectile motion...the first thing I thought of is 0! Why is it not 0? Is it because the potato is still moving horizontally, just not vertically?
Part C: Okay so K = 0.5 * m * v^2
K = 0.5 * 0.210 kg * 38 m/s ^2
K = 150 J
Now there is an angle involved...I have no clue how or if that needs to be factored in...
Part D: U = mgh
U = 0.210 kg * 9.8 m/s^2 * 0.6 m
U = 1.23 J
And again with the angle...
Part E: I think once I get the angle part dealt with I'll be able to solve the rest of this...
Part F:
I know you guys don't want to do our homework for us, which I completely understand, but I really can't do this problem correctly without knowing how to handle the angle. Once that part is pointed out, I should be able to do the rest of the problem.
Thanks 1 million times to who ever can help! =]
In lower classes of Physics students only work problems where motion is in a straight line. But then in higher classes there will be problems where motion will be in a curve.
But the beautiful thing about projectiles projected under gravity is to notice that the curved motion is just made up of
a) motion in a straight line with constant velocity along the horizontal
and b) motion in a straight line with constant acceleration along the vertical.
The particle is subjected simultaneously to these two types of motion and thus goes in a curve.
The student can continue to work in straight line motion as he did in lower classes. But he has to be careful whether he is working in the horizontal or in the vertical since the conditions are different.
A) You can separate the velocity into two vectors, let's say vx and vy. The find the horizontal velocity, you simply make a triangle with the vinitial as the hypotenuse with an angle of 47 degrees. Use vinitialsin(x) to find vx (the horizontal velocity). All this is assuming there is no air friction.
The speed of the potato I interpret as the magnitude of its velocity. Since vx is 0m/s at max height we can neglect that and use vy. The answer would be visin(x), the same as your question A.
Use KE=.5mv2.
Use PE=mgh. Keep in mind that h has a non-zero value because you are not on the ground.
KE=0.
Gotta go to class! My answers might not necessarily be correct, please check them over! I'm just a student myself lol.
Consider the two figures here:
The first shows the trajectory of your projectile plotted on X-Y axes. The initial launch speed is indicated as Vo and the initial launch angle is θ. Note that a quantity with both magnitude and direction is a vector quantity. So we can call Vo with its angle the initial velocity vector.
The second drawing shows the velocity vector drawn on a set of axes that represent the vertical (y) and horizontal (x) components of a velocity. What are the projected lengths of this vector on the axes? That is, what are Vx and Vy? You'll want to use a little trigonometry.
Something to note is that while the velocity in the y-direction changes due to the acceleration due to gravity, the velocity in the x-direction is constant throughout the trajectory.
[QUOTE ... find the horizontal velocity, you simply make a triangle with the vinitial as the hypotenuse with an angle of 47 degrees. Use vinitialsin(x) to find vx (the horizontal velocity)... QUOTE]
If x is 47deg then sin must be replaced by cos.
[QUOTE ... Since vx is 0m/s at max height we can neglect that and use vy[/QUOTE]
May I correct some typos:
If v[itex]_{x}[/itex] is meant to be the horizontal component of the velocity, then vx must be replaced by vy and vy by vx.
Thanks for making the corrections :x
