Graph and Differential equations for hyperbolas
The discussion centers around the equation xy=c, which represents a hyperbola. Participants explore how to derive multiple graphs from this single equation and the corresponding differential equations. The conversation also touches on the relationship between hyperbolas and parabolas.
  • One participant notes that y = c/x represents a family of hyperbolas that varies with different values of c.
  • Another participant questions the relationship between the hyperbola and the equation y^2 = 4ax, suggesting both are conic sections.
  • Some participants clarify that y = c/x is equivalent to the original hyperbola equation xy = c.
  • There is a suggestion that the family of hyperbolas can be plotted by varying c, including both positive and negative values.
  • A participant raises a question about whether y = 0 can be considered a parabola, leading to further inquiry about the nature of parabolas and their definitions.
Participants generally agree on the equivalence of y = c/x and xy = c as representations of hyperbolas. However, there is some uncertainty regarding the classification of y = 0 and its relation to parabolas, indicating a lack of consensus on that point.
Participants express varying assumptions about the nature of conic sections and the implications of different values of c, but these assumptions remain unresolved.
shayaan_musta
Hello experts!
Hope all of you will be fine.
I have an equation i.e. xy=c
And we all know it is hyperbola.
Now I say "graph some of the hyperbolas xy=c". Then kindly tell me how can we extract more than 1 graph from this single equation? And you will write the differential equations for them. while here only 1 hyperbola is given i.e. xy=c.
If you have any confusion about the question the kindly tell me. I will try to clear more.
Thanks in advance.
Assuming c is some constant, you have y = c/x. This is a family of graphs, which varies based on values of c. I.E. y = 1/x, y = 2/x, ...y = c/x
Oh thanks. It is quite helpful.
y[itex]^{2}[/itex]=4ax is also a parabola & and y=[itex]\frac{c}{x}[/itex] too?
Is it?
Yes, [itex]y^2= 4ax[/itex] would be a family of parabolas, all passing through (0, 0) having different foci.
I'm not sure what your question about y= c/x is. It is the same as xy= c, your original hyperbola system.
My real question as you can see that, how can you plot some hyperbolas families from general equation i.e. xy=c?
This could be y=c/x and therefore some families will be y=1/x, y=2/x, y=3/x...so on.
Where c=any arbitrary constant.
Am I right?
Yes, that is exactly what it is saying. They will be parabolas having the x and y axes as asymptotes, passing through (1, c) and (-1, -c), for each number c. Be sure to include some values of c negative and c= 0.
As you said c=0 this implies that y=0/x or y=0
Can y=0 be a parabola? Is it so?
  • · Replies 52 ·
11K
  • · Replies 25 ·
  • · Replies 0 ·
