U Physics 12E 7.71 Conservation of Energy: An experimental apparatus with mass
The discussion focuses on solving problem 7.71 from U Physics 12E, which involves an experimental apparatus placed on a vertical spring. The key concepts include the relationship between gravitational potential energy (Ugrav) and elastic potential energy (Uel), as well as Newton's Second Law (F=ma). The solution requires determining the spring constant (k) and the initial compression distance (x) to ensure the apparatus does not exceed its maximum acceleration (a) without sustaining damage. The participants clarify that the merger of these concepts is essential for modeling the problem effectively.
  • Understanding of Conservation of Energy principles
  • Familiarity with Newton's Second Law (F=ma)
  • Knowledge of elastic potential energy (Uel) and gravitational potential energy (Ugrav)
  • Basic algebra skills for manipulating equations
  • Explore the derivation of the spring constant (k) using Hooke's Law
  • Study the relationship between maximum acceleration and spring compression
  • Investigate the implications of energy conservation in mechanical systems
  • Learn about the effects of different spring constants on system dynamics
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators seeking to enhance their understanding of practical applications of these concepts.
NamaeKana
The question is shown below the --- or this question and answerbook is from U Physics 12E #7.71. I uploaded a JPG that can be seen at http://i43.tinypic.com/35j9jja.jpg
I don't understand this problem. I see that to solve this Conservation of Energy and N2L are merged using x, and that h from Ugrav, and a from F=ma are thus related, but why ? I understand the algebra, but how does this merger model the problem ?
An experimental apparatus with mass m is placed on a vertical spring of negligible mass and pushed down until the spring is compressed a distance x. The apparatus is then released and reaches its maximum height at a distance h above the point where it is released. The apparatus is not attached to the spring, and at its maximum height it is no longer in contact with the spring. The maximum magnitude of acceleration the apparatus can have without being damaged is a, where a > g.
(a) What should the force constant of the spring be?
(b) What distance x must the spring be compressed initially?
o.k. i get it now. we are propagating a to limit the forces so the block/animal launched doesn't break/die. so that's why we pull out x from kx^2=ma then plug x into Uel=Ug. the objective again it to limit. then after we get the final equation, we can pick a k and an x-compression that will work.
  • · Replies 22 ·
