How to measure charging of Cockcroft Walton Multipliers?
  • Thread starter Thread starter shrinky
    Charging Measure
To measure the charging behavior of a Cockcroft-Walton multiplier, it's essential to observe the voltage over time without discharging the capacitors, which can be done using an oscilloscope with minimal loading. A differential input oscilloscope may help visualize the waveforms throughout the circuit. The user is currently unable to see the expected amplitude increase in their half-wave multi-stage setup, suggesting potential issues with the driving frequency. It's debated whether to measure voltage across the highest capacitor stage or relative to ground, with the latter being necessary if the driving source is not floating. Observing transient waveforms effectively may require a storage oscilloscope or synchronized camera for accurate results.
shrinky
How do you measure the voltage of a cockcroft walton multiplier over time to observe the charging behavior? Does measuring with oscilloscopes discharge the capacitor hence you can't observe the charging or not?
The oscilloscope doesn't impose much loading on the circuit. You are wanting to observe the actual pumping up? That will be a short term transitory waveform. Using a CRO with differential inputs might be handy, if you wish to observe all waveforms around the circuit.
Yeah. Ideally I'd like to see the oscillation with amplitude offset increasing as time goes on.
Right now I have a simple half wave multi stage multiplier set up. I can measure the rectification part, so the sine wave only goes to the positive and not negative, but I don't see the amplitude increase so that the dc offset is always zero essentially.
It could be my driving frequency isn't correct perhaps?
Rhetorical I guess but is it better to measure the voltage across the capacitor at the highest stage or measure the potential relative to ground.
Well, it's a transient, so unless you have a storage CRO or a synchronised camera, you won't see it.
Are you saying it's not working?
It shouldn't matter.
Can you post your circuit schematic?
Unless your driving source is floating, you can't connect the CRO across any ungrounded element.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
