Spin a dial that has a pointer to n regions
  • Context: Graduate
  • Thread starter Thread starter lizarton
    Spin
The discussion revolves around calculating the probability that the sum of numbers obtained from spinning a dial, which can point to n equally likely regions, equals n after three spins. Participants explore the use of combinatorial methods, including binomial coefficients and compositions of integers, to approach the problem.
  • One participant suggests that the total number of outcomes when spinning the dial three times is n^3 and begins counting ordered triples for specific values of n.
  • Another participant introduces the concept of compositions of integers and provides a formula for the number of compositions for a natural number n, suggesting it relates to the problem at hand.
  • There is a discussion about whether compositions and selections are equivalent in this context, with attempts to clarify the relationship between the two.
  • Several participants propose formulas for calculating the probability, including the use of factorials and binomial coefficients, but there is uncertainty about their correctness and applicability.
  • One participant raises the issue of accounting for sums larger than n and the implications of the maximum possible sum being 3n.
  • Another participant questions the validity of the proposed formulas and suggests looking up definitions to clarify the concepts of compositions and combinations.
  • There is an ongoing effort to derive a general formula for arbitrary n, with various interpretations and calculations presented without consensus on the correct approach.
Participants express differing views on the correct approach to calculating the probability, with multiple competing models and formulas presented. The discussion remains unresolved, with no consensus reached on the final probability expression or the definitions of key terms.
Participants express uncertainty regarding the definitions of compositions and combinations, as well as the appropriate application of binomial coefficients in this context. There are also unresolved questions about the relationship between the proposed formulas and the problem's requirements.
lizarton
Consider a dial having a pointer that is equally likely to point to each of [itex]n[/itex] region numbered [itex]1,2,...,n.[/itex] When we spin the dial three times, what is the probability that the sum of the selected numbers is [itex]n[/itex]?
I have to use summations, and I'm sure binomial coefficients. I believe that this is a selection; it seems to imitate rolling an [itex]n[/itex]-sided die three times, but I even have trouble computing that problem.
The total number of outcomes is [itex]n^3[/itex] (I think)
I started counting ordered triples of some n terms...
[itex]n=3:[/itex] There is only one way, [itex]{(1,1,1)}[/itex]
[itex]n=4:[/itex] There are 3 ways, [itex]{(1,2,1),(1,1,2),(2,1,1)}[/itex]
[itex]n=5:[/itex] There are 6 ways, [itex]{(1,1,3),(1,2,2),(1,3,1),(2,1,2,),(2,2,1),(3,1,1)}[/itex]
[itex]n=6:[/itex] There are 10 ways...
[itex]n=7:[/itex] 15 ways...
For arbitrary n, you can start making ordered triples...
[itex](1,1,n-2)<br /> (1,2,n-3)<br /> (1,3,n-4)<br /> \ldots<br /> (1,n-2,1)<br /> (1,n-3,2)<br /> \ldots[/itex]
A Theorem I believe is relevant:
With repetition allowed, there are [itex]\left(\stackrel{n+k-1}{k - 1}\right)[/itex] ways to select [itex]n[/itex] objects from [itex]k[/itex] types. This also equals the number of nonnegative integer solutions to [itex]x_{1} + \ldots + x_{k} = n.[/itex]
My problem is identifying [itex]n[/itex] and [itex]k[/itex] in these problems. Any help would be greatly appreciated!
If I understand you, you want to know the probability of getting a sum = n for in k tries where n is a positive integer and the regions are the natural numbers: 1, 2, 3, ...n. This involves compositions of integers which you demonstrated. The formula for the number of compositions for any natural number n is [itex]2 ^ {n-1}[/itex]. Since you are only interested in the compositions of three integers (k=3) and are not including zero, the formula is (n-1)!/(k-1)!(n-k)!
How would you use this information to find the probability for n=9, k=3?
Thanks for replying!
Are compositions the same as selections in this context? If so, here's my attempt, provided I understand you correctly:
For [itex]n = 9[/itex] and [itex]k = 3[/itex], the total number of compositions would be [itex]2^{8}[/itex].
Then the number of favorable outcomes/compositions would be [itex]\frac{8!}{2!6!}[/itex].
So the probability that the sum of the regions equals 9 is [itex]\frac{8*7}{2^{9}}[/itex].
So then, to answer the question in general for arbitrary [itex]n[/itex], the probability is
[itex]\frac{(n-1)!}{2^{n}(n-3)!} = \frac{1}{2^{n}(n-3)(n-2)}[/itex]?
Think about it. The probability is a fraction. Both the numerator and denominator is (n-1)!/(k-1)!(n-k)!. What are n and k for the numerator and denominator respectively?
For the denominator, we would have [itex]n=k[/itex], right? The formula I wrote for arbitrary [itex]n[/itex] has been simplified; [itex](3-1)!=2[/itex], and I divided the entire quantity by [itex]2^{n-1}[/itex]. I'm not sure that I understand the relationship we draw here between [itex]2^{n-1}[/itex] and [itex]\frac{(n-1)!}{(k-1)!(n-k)!}[/itex]. Was my estimate for [itex]n=9, k=3[/itex] correct?
If I understand your problem correctly, you spin the dial just 3 times and it can stop at any number 1-9. Your question is the probability that the sum of three spins will be exactly 9. However, it's possible the dial can stop, for example, at 9 three times, no?
The dial can stop at any arbitrary natural number [itex]1..n[/itex]. The number of regions isn't specified further than that, but there are [itex]k=3[/itex] trials that we consider. The problem asks to compute the probability that the sum of the three spins will equal [itex]n[/itex]. However, your version of the problem is just a simpler case of the general problem I need to solve, I believe.
Well then, I'm not sure what you're trying to do. Just say n instead of 9. The dial can still stop at n three times, no? How do you account for sums larger than n? If I understand you, you can have sums up to n*k.
Yes, the largest possible sum would be [itex]3n[/itex].
Using my formula above, the number of ways that the 3 trials can add up to n is [itex]\left(\stackrel{n+3-1}{3 - 1}\right) = \left(\stackrel{n + 2}{2}\right)[/itex]
Does that seem right to you? Since I'm looking for the number of nonnegative integer solutions to [itex]x_{1} + x_{2} + ... + x_{k} = n[/itex], where the number of trials is [itex]k = 3[/itex].
Then the total number of outcomes is [itex]n^{k}[/itex] by the product rule.
This gives the probability as
[itex]\frac{\left(\stackrel{n + 2}{2}\right)}{n^{3}}[/itex].
Does this look correct to you?
[itex]\frac{\left(\stackrel{n + 2}{2}\right)}{n^{k}}[/itex].
No. Your problem is to find the number of compositions of length k for n and for kn. The probability then becomes the fraction of the former over the latter. The proper formula for the number of compositions of length k for n is the factorial one I gave you. I suggest you look up compositions and verify this formula for yourself before you respond.
I looked up compositions, and after some research I think you may have meant to say that we seek combinations, the number of ways of picking [itex]k[/itex] unordered outcomes from [itex]n[/itex] possibilities. I have not dealt with either of these terms in my class, so I apologize for not recognizing them off-hand.
If my reckoning of the number of ways this can happen (all the way at the top) is correct with [itex]n=3,4,5,6,7[/itex], then the coefficient that will give me the number of ways this can happen for arbitrary [itex]n[/itex] is [itex]\left(\stackrel{n-1}{2}\right) = \frac{1}{2} (n-2)(n-1)[/itex].
The probability is this quantity divided by the total number of outcomes.
Thanks for your help.
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 100 ·
13K
