Magnesium-Based Stents: Testing & Controlling Corrosion Rates
  • Thread starter Thread starter jared530
The discussion focuses on the characterization of degradation behaviors of magnesium-based alloys used in stents, specifically addressing the challenges in modeling corrosion rates and exploring methods to control these rates for medical applications. Participants are examining theoretical and experimental approaches to understand the implications of corrosion in a biological environment.
  • Experimental/applied
  • One participant seeks suggestions for formulating time-dependent relationships for erosion corrosion based on ion concentration, pH, and flow velocity in COMSOL.
  • Another participant expresses skepticism about the ability of software to accurately predict corrosion rates, emphasizing the complexity of factors influencing corrosion, including alloy composition and thermal history.
  • Concerns are raised about the biocompatibility of metal ions released from magnesium-based stents, with a focus on the need for careful selection of alloy compositions.
  • Suggestions for controlling degradation rates include heat treatments of magnesium alloys and coating with biodegradable polymers.
  • Questions are posed regarding the safety of ensuring that only ions from the stent enter the bloodstream, and the potential for metal chips to cause complications.
  • Participants discuss the possibility of anodizing magnesium alloys to slow degradation, though uncertainty remains about its effectiveness.
Participants do not reach consensus on the effectiveness of modeling corrosion rates with software, the safety of magnesium implants, or the best methods to control degradation rates. Multiple competing views and uncertainties persist throughout the discussion.
The discussion highlights limitations regarding the assumptions made in modeling corrosion rates and the dependence on specific alloy compositions and treatments. The scope of the project is also noted to be focused on achieving a controlled degradation period of 6-8 months for magnesium-based stents.
jared530
Hi everyone,
Noob to the forums, but forum junkie in different hobbies. Anyways, my senior project is to identify appropriate bench test to characterize degradation behaviors of magnesium-based alloys (stents). Form of final device and complexities of an in vivo environment can impact results, so made assumptions whenever possible.
Also to identify and test options to slow/or control corrosion rates of mg-based alloys.
Currently were modeling different stent designs in COMSOL, and modeling the degradation rate(erosion corrosion) as a function of ion concentration, pH and flow velocity.
Our team is having some trouble formulating equations to plug into COMSOL.
The question is, does anyone have any suggestions on how I can arrive at a time dependent relationship for erosion corrosion of a metal as a functions of ion concentration, pH and flow velocity?
Please feel free to ask any questions.
Sorry it's not exactly your question, but...
I don't expect a software to make any decent prediction of corrosion rate.
The best human experts don't make accurate predictions. They experiment.
Corrosion rate does not relate to a limited set of parameters like pH, ion concentration and flow velocity!
If your software proposes this to deduce a corrosion rate, be sure the prediction will be meaningless.
Corrosion rate does heavily depend on the alloy composition, on its thermal history... For stainless steel, if welds are to resist corrosion, you take a variant with <0.02% C instead of <0.06% C - just as an example. But a bit of chlorine ions in water would let you choose an other alloy, with Mo.
More: in a medical implant, the release of toxic ions is more important than the corrosion rate. Do you enjoy zirconium in your patient's body? Chromium? Usual in magnesium.
I'm also surprised that people consider magnesium for an implant. Though the Mg ingots I had did not corrode quickly, you should consider that implants use very special alloys, because stainless isn't good enough for them. They have specially-designed cobalt and titanium alloys, produced only for implants.
For such a demanding use (vital, in fact) I'd never rely on a software.
Thank you so much for your reply. Your actually very right, variables that effect corrosion are essentially unlimited and it would be impossible to model the rate in any software. I guess we can use the model only as a stress-point indicator to formulate an appropriate geometry for the stent.
I realize the metal ions absorbed into the blood stream should be biocompatible. The composition were supposed to be testing wasn’t specified by the company who’s hosting this project, so I’m guessing we can alloy with what we feel appropriate. But magnesium should be the main component because the scope of the project is to control the degradation rate of Mg-based stents to 6-8 months, and after this period, should start degrading and absorbing into the blood stream. This is mainly to avoid a second surgery, which would happen if you used SS or NiTi.
Do you have any ideas on how we can control this degradation rate? Currently bare-metal magnesium degrades in a period of 1 month, and we would like to extend this to 6-8 months. Currently we have come up with the options: heat treatments of the Mg-alloy; and coating the metal with a biodegradable polymer.
Again an offroad question, sorry for that, but...
Do you have an absolutely safe means to guarantee that only ions from your stent will move in the blood? Metal chips are not desired in a patient!
Slower degradation: maybe with purer magnesium, but it should get even softer then.
Could you try to anodize your alloy? (I'm not very sure it helps with magnesium...)
The patient will experience "chunking" of metal especially w/ bare Mg because of the super fast rate.
Would anodizing result in a extremely slow degradation rate(over 10 months)? Or would the oxide even break down in the body?
11K
  • · Replies 19 ·
11K
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 19 ·
