FireStorm000 said:
Um, no. By that I mean I took a year of calculus based physics, one semester of mechanics, and one semester of E&M. As well as a separate one year format calculus one course. Both of which show up on my college transcript. No need to be condescending.
Unintentional - (limitations of text) - I need to know where to start from and the only clues I have are the ones you tell me. I just couldn't tell from what you'd written for sure if you'd actually attended college. In one place you said you did "a course" and in another you said it was a High-School accelerated course which provided college credit.
Despite my limited formal training, I have a fair idea of how to work with differential equations; I've done a lot of looking into it on my own, I just need a little help putting all the pieces together.
OK - no worries.
The biggest problem I have with this stuff is that I never got to work in anything but two dimensional space; as such, I struggle sometimes extending things into that 3rd dimension, most importantly, in integrating equations which involve more than two variables. I can start to picture how one might go about doing that kind of integration, but again, not well enough to actually pull it off.
Usually we find ways to reduce the 3D integrals and so on to just one or two - so most of the examples (almost all) will involve that sort of trick.
The concept of a double integral should work if you consider the area between two curves, f and g, in 2D - you know the result is just to do A=∫(f-g)dx but I want to demonstrate, formally, how this works:
You divide the region between the limits a and b into lots od small squares width dx and height dy. the area of one of them is dA=dxdy - now you have to count up all the little areas.
Each column of squares at position x starts at y=g(x) as the lowest point and y=f(x) as the highest. The x position starts at a and ends at b.
so we need to sum all the little dA's within those limits - which we write
[tex]A = \int_{x}\int_{y} dA = \int_{a}^{b} \int_{g(x)}^{f(x)} dy.dx[/tex]... evaluate them from the inside out - the indefinite integral of dy is just y+c, which evaluates to f-g because of the limits.
The answer is so easy that we don't normally bother with the double integral.
If you put g(x)=0, this will give you the regular integral you were first taught - the area between the function and the x axis.
So have I got the right pitch for your level yet?
I want to be sure before going into 3D.
I think the best thing at this point would be if anyone knew of some online resources that would help me put all of the pieces together; I can't help but feel I'm close and just missing a few little things.
... and you'll want a physics one rather than a math one.
Hyperphysics can be a useful quick-start, though it tends to be conceptual.
Mathinsight has some useful examples. It's difficult to know what to suggest, but after a bit of to-and-fro we should settle on something.
