Stephen Tashi said:
Ashu2912's confusion about the algebra of limits appears to justified!
I don't know whether modern calculus texts provide any formal axioms for "the extended real numbers". The one's I have (from 20 years ago) do not. They merely had a set of verbal statements that said when particular algebraic rules applied and in some rules they allowed terms to be limits equal to [itex]\infty[/itex] or [itex]- \infty[/itex]. You had to read the fine print to see what was going on. You couldn't memorize any simple set of guidelines and assume they applied to all the rules.
In mathematics you have to read the fine print. I suspect most people don't memorize the fine print about the laws of limits. Instead, they form a good intuition about how limits behave and use that in place of remembering what their text said years ago.
There are formal definitions for [itex]\lim_{x \rightarrow a}f(x) = \infty[/itex] and [itex]\lim_{x \rightarrow \infty} f(x) = \infty[/itex] and so forth. These don't entail all the ways that a limit can fail to exist as a finite limit. A function can oscillate "infinitely fast". Or a function can simply be undefined in an entire interval around where you are trying to take the limit. For example, you can define a function f(x) to be equal to 6 on all real numbers where |x| > 1 and leave it undefined elsewhere. Then [itex]lim_{x \rightarrow 0} f(x)[/itex] doesn't exist.
My old calculus books often used phrases like "if the limits exist or are infinite" to describe the restrictions that applied to a rule. They considered an "infinite" limit to be a special case of a limit not existing.
As to l'Hospital's rule, I remember hunting down proofs for all the cases and reading them. There are a few cases of it that are hard to prove and weren't easy to find in books. Now that you have the web, I think you should have no trouble. However, don't expect to find a proof that treats each case ( [itex]0/0, \infty/\infty,...[/itex] etc.in the same fashion. The cases are fundamentally different situations.
^ this.
depending on what meaning you assign to the symbol "∞" you can have one of the following 3 outcomes:
(a) [itex]\lim_{x \to 0} \frac{1}{x} \text{ is undefined.}[/itex]
(b) [itex]\lim_{x \to 0} \frac{1}{x} \text{ does not exist.}[/itex]
(c) [itex]\lim_{x \to 0} \frac{1}{x} = \infty[/itex].
i believe that is not useful, for a "first look" at calculus, to allow "infinite limits". yes, we can extend the real number system to include non-finite quantities, but doing so "muddies the waters". R U {-∞,∞} is no longer a field, and R U {∞} (the projective reals) is no longer an ordered field (or even an ordered ring).
it is still possible to assign meanings to:
[itex]\lim_{x \to a} = \infty[/itex] and [itex]\lim_{x \to \infty} = L[/itex], but for such statements to be meaningful within the context of the real ordered field of real numbers, we have to state them SOLELY in terms of real numbers. in this view of things "∞" is not, and does not become, a real number, or any "extension" of a real number, but a SHORTHAND, for certain statements
about real numbers.
why is such caution prudent? because "intutive" notions about "infinity" (as conceived by inductive reasoning from finite numbers) simply do not hold. while it is certainly possible to create an axiom system that allows for "extending the real numbers to include infinity", that axiom system is certainly more complicated that the axioms for an ordered field, and one has to separate out the "infinite cases from the non-infinite cases" (this becomes particularly important with the projective reals and any theorem involving inequalities).
that is, before one starts messing around with "improper limits", one should have a firm grasp of "proper limits", that is, when a limit is a real number, AT a real number.
