Object sliding down horizontal, frictionless slope, crossing horizontal surface
The problem involves a block sliding down a frictionless ramp and subsequently crossing a surface with friction before colliding with a pendulum-like ball. The goal is to determine how high the ball rises after the collision, given specific parameters such as masses and distances.
  • The original poster attempts to calculate the speed of the block after descending the ramp using energy conservation principles and then applies friction to find the speed after crossing the surface. They also use momentum conservation to determine the speed of the ball post-collision and subsequently calculate the height it reaches.
Participants have provided feedback on the original poster's reasoning and calculations, indicating that the method appears sound. However, there is no explicit consensus on the correctness of the final answer, and some participants suggest maintaining significant digits in calculations.
The original poster expresses uncertainty about the correctness of their approach and notes discrepancies with similar problems encountered elsewhere. The discussion is framed within a practice context, emphasizing learning rather than definitive outcomes.
kapowa
block A slides down an 8 m frictionless ramp that is curved 30 degrees above the horizontal.
it then crosses a 4m surface that has a coefficient of friction that is 0.20.
it then hits a ball and continues moving at 3 m/s.
the ball is suspended from a string, kinda like a pendulum. You have to find out how high the ball goes.
mass of block a is 5kg
mass of ball a is 2.5 kg
Ek = 0.5mv^2
Eg = mgh
vf^2 = vi^2 + 2ad
Ff= μFn
p=mv
to find the speed of the block after sliding down the ramp, i simply used some the sin function to determine the vertical distance the block moved down the ramp and then used the formula E(gravity)= mgh to find out the energy it had at the top of the ramp. I then converted this energy to kinetic energy (formula E(kinetic) = 0.5mv^2) which it would have gained at the bottom of the ramp and found the speed to be around 8.85 m/s.
then to find the speed after the block crossed the 4m distance, i used the the formula for friction. To find the normal force, i used Fg = mg because gravity and normal force are the same in magnitude, and put this in the F(friction) = μFn formula and then got the negative acceleration and plugged that into the kinematics formula above to get a speed of about 7.9 m/s after crossing the 4m surface.
then i used momentum to figure out the height of the ball in the pendulum. Before the collision the momentum was mass of block (5 kg) times speed (abt 7.9 m/s). I setup the formula for the collison like this
momentum before = 5kg x (approx. 7.9m/s)
after the collision the block was moving at 3 m/s
momentum after = 5 kg x (3 m/s) + 2.5(v(of ball a))
since momentum is conserved i solved the equation to find v of ball a which was about 9 m/s. i then used the kinetic energy formula to find the energy at that point right after the collision. At this point kinetic energy was at a max and potential energy was at a minimum. I then converted the energy to potential which would have happened when the pendulum swung to one side. I used the formula Ep = mgh to finally find the height of the ball which i got to be around 5meters (4.9 something)
I am not sure if this was correct way of doing it. I saw a similar question elsewhere and saw that the answers were somewhat different. i wanted to know if i was right in the way i did it, the asnwer did seem reasonable to me.
I have not checked any of your maths calculation but I cannot find anything wrong with your method
Okay, thanks a lot. I just wanted to know if my reasoning was correct. The numbers don't really matter that much. It was just a practice question.
It looks correct. But keep at least 3 significant digits in the intermediate results .
ehild
  • · Replies 16 ·
