Mathematica Matrix creation help
The discussion focuses on creating a 22x10 matrix in Mathematica from multiple arrays (H1, H2, H3, etc.) using a loop. The user initially attempts to store the results using a For loop, which leads to unexpected dimensions upon importing the data. The recommended solution is to utilize the Table function instead, specifically Table[{f1[i],f2[i],..,f10[i]},{i,1,22}]>>"temp.mx", which correctly formats the output as a matrix.
  • Familiarity with Mathematica programming language
  • Understanding of matrix dimensions and data structures
  • Knowledge of the Import function in Mathematica
  • Experience with functional programming concepts, particularly Table and For loops
  • Explore advanced data manipulation techniques in Mathematica
  • Learn about the differences between For and Table functions in Mathematica
  • Investigate the Import function's various options for data formatting
  • Study best practices for matrix creation and manipulation in Mathematica
Mathematica users, data analysts, and programmers looking to efficiently create and manipulate matrices from arrays of data.
NRedacted
Hi,
I have a whole bunch of data (Arrays of the form H1, H2, H3 etc) that I want to crunch to create 10 more variables. I did:
For[i=1,i<23,i++,{f1(i),f2(i),..,f10(i)}>>>"temp.mx"]
Where fj(i)= fj(H1[],H2[],...), the functions are different functions of the numerical data I have.
Now when I try to Import "temp.mx" I get all kinds of things except a 22x10 matrix that I really badly want.
data5=Import["temp.mx","Table"]
Dimensions[data5]
This gives the result that data is 110 dimensions where each of my 10 data for each "i" is stored as 5 separate pieces of data, giving data5 a dimenion of 5*22=110
When I do
data5=Import["temp.mx"]
Dimensions[data5]
This time I get Dimension {} and all data is stored as one piece.
How can I store my calculations such that the result is a 22x10 matrix from which data can be easily extracted? This situation is driving me insane. Any help will be greatly appreciated.
Thanks
NRedacted said:
Hi,
I did:
I understand this compulsion to use For[] cannot be resisted.
The result is often problems like what you are seeing.
Try
Table[{f1,f2,..,f10},{i,1,22}]>>"temp.mx"
  • · Replies 20 ·
12K
