Understanding the Inverse of a Fiber Bundle Projection Map
The discussion revolves around the concepts of fiber bundles, projection maps, and their inverses, particularly focusing on the notation and implications of these mathematical structures. Participants explore the definitions and properties of fiber bundles, structure groups, and frame bundles, addressing both theoretical and conceptual aspects.
  • Some participants express confusion regarding the inverse of the projection map in fiber bundles, noting that it is generally many-to-one and questioning how an inverse can be defined.
  • Others clarify that the notation \(\pi^{-1}(U)\) refers to the preimage of a subset under the projection map, rather than an actual inverse function.
  • A participant mentions that the term "pre-image" is not consistently used in their resources, leading to misunderstandings.
  • There is a discussion about the trivial structure group of fiber bundles and whether it is necessary and sufficient for a fiber bundle to be trivial.
  • Some participants assert that a fiber bundle is trivial if and only if its structure group can be reduced to the identity.
  • Participants differentiate between frame bundles and tangent bundles, noting that frame bundles consist of ordered bases for tangent spaces, while tangent bundles consist of tangent vectors.
  • There is a discussion about the arbitrariness of choosing bases in the context of frame bundles and how this relates to the structure group GL(n).
  • Some participants mention that additional conditions can lead to a reduced frame bundle, which is distinct from the general frame bundle.
Participants generally agree on the definitions of preimages and the relationship between trivial structure groups and trivial fiber bundles. However, there are ongoing discussions about the implications of these definitions and the nature of frame bundles, indicating that some aspects remain contested or unclear.
Some participants note that the notation and terminology surrounding fiber bundles and their properties may not be consistently defined across different texts, leading to potential confusion.
Matterwave
Homework Helper
Hey guys,
I've often seen in the definition of a Fiber bundle a projection map [itex]\pi: E\rightarrow B[/itex] where E is the fiber bundle and B is the base manifold. This projection is used to project each individual fiber to its base point on the base manifold.
I then see a lot of references to the inverse of this projection map. It seems to me, that in general, this map should be many to one, since it should project a whole fiber to its base point. In this case, how can one define an inverse to this map? It seems odd to me that there can be an inverse to a many to one mapping...or have I missed something basic?
It is many-to-one in general (and that's really one of the points of this whole construction!) so it makes no sense to talk about its inverse map. Are you perhaps confusing the notation for the preimage [itex]\pi^{-1}(U) = \{ e \in E \colon \pi(e) \in U \}[/itex] of a subset U of B under [itex]\pi[/itex] with the identical notation for the image of U under the inverse of [itex]\pi[/itex] (a function that doesn't necessarily exist)?
P.S. A standard abuse of notation is to use [itex]\pi^{-1}(b)[/itex] to denote the preimage of the singleton {b}, i.e. the fiber lying over b.
That's probably it, but I haven't seen it termed "pre-image" in any of my books, maybe they are just getting a little sloppy here.
The first mention of this, my book simply says: "...which means that the bundle over any set [itex]U_j[/itex], which is just [itex]\pi^{-1}(U_j)[/itex], has a homeomorphism..."
I guess since the book didn't call it an inverse nor a preimage, I simply assumed it meant inverse and got confused.
For example, the wikipedia article: http://en.wikipedia.org/wiki/Fiber_bundle also simply just uses this notation without clarification.
Yes, that's the inverse image, and it's pretty standard notation in topology. The reason you haven't seen it explicitly defined in your books is (probably) due to the fact that books dealing with bundles tend to assume basic topology (and all the accompanying notation and terminology) as a prereq.
So it's just overloaded notation huh...that seems inconvenient...
A follow up question. My book discusses the structure group of fiber bundles and seems to imply that a trivial structure group (one where the structure group can be reduced to simply {1}) means a trivial fiber bundle (one where the fiber bundle is isomorphic to a product space).
The book isn't very explicit about this, however. I was just wondering if this condition is "necessary and sufficient"? I.e. Is a fiber bundle trivial if and only if its structure group is trivial? Or perhaps this condition is only necessary but not sufficient, or sufficient but not necessary?
Also, my book makes mention of a "frame bundle". I can't see the difference between a frame bundle and a tangent bundle other than that the frame bundle doesn't include the base element in its fibers. What's the difference? The wikipedia article is not really accessible to me.
Yes, a bundle is trivial iff its structure group can be reduced to {1}.
And re: frame bundle. The fiber at a point x in the tangent bundle is the tangent space TxM at x; the fiber at a point x in the frame bundle is the set of all ordered bases (i.e. frames) for TxM. So we're really dealing with completely different objects: the tangent bundle is a vector bundle, i.e. its fibers are vector spaces, whereas the frame bundle isn't.
Can you explain "the set of all ordered bases (i.e. frames) for TxM"? When I hear that I'm thinking of basis vectors, of which it's pretty arbitrary.
every surjection has a right inverse, and these are called sections.
How is that defined? Without much context, I'm not sure which part of my post you are referring to, or what point you wanted to make...
What's a fiber bundle over M? It's literally a bundle of fibers over M! I.e. you glue a set F (the fiber) to each point x in X. And then you require some 'niceness' conditions of this gluing.
Now, what's the frame bundle of M? It's a fiber bundle over M where the fiber glued to x consists of ordered bases for the tangent space at x. Literally a point in the frame bundle above x is an ordered basis [v_1,...,v_n] for TxM.
Hmmm...so, that seems pretty arbitrary in my choice of bases. If I can choose "all ordered bases", don't I get back Tx[\sub]M? I'm thinking "all ordered bases" would include pretty much every single vector other than the 0 vector because certainly every vector is in some arbitrary choice of bases...
After rereading your last post, i think I get it. Thanks =D
It is arbitrary indeed - up to an arbitrary transformation by an element of the group GL(n). So, the structure group of the frame bundle (a principal bundle) is GL(n).
Unless you specify that you want some additional condition, to , e.g., preserve orientation, in which case you use SL(n).
Indeed, but, in such a case, we are dealing not with the whole "frame bundle", but with "a reduced frame bundle".
Right, I missed that.
I need to go back and read this part again lol...
  • · Replies 31 ·
  • · Replies 43 ·
  • · Replies 16 ·
  • · Replies 29 ·
  • · Replies 39 ·
