What {in,sur}jectivity of composite map implies for components
The discussion revolves around the implications of the injectivity and surjectivity of composite functions, specifically in the context of problems from Munkres' topology text. Participants explore the conditions under which the injectivity or surjectivity of the composite function \( g \circ f \) can inform the properties of the individual functions \( f \) and \( g \). The scope includes theoretical reasoning and mathematical definitions related to function composition.
  • Some participants conclude that if \( g \circ f \) is injective, then both \( f \) and \( g \) must be injective, and similarly for surjectivity.
  • Others argue that the definition of function composition in Munkres requires \( f \) to be surjective for \( g \circ f \) to be defined, leading to the conclusion that \( g \circ f \) surjective implies \( f \) is surjective.
  • One participant points out a potential confusion regarding Munkres' use of "range" versus "codomain," suggesting that this could affect interpretations of the problems.
  • Examples are provided to illustrate cases where \( g \circ f \) can be injective even if \( g \) is not, highlighting the importance of the image of \( f \) relative to the domain of \( g \).
  • Another participant notes that Munkres' definition does not stipulate that the image of \( f \) must equal the domain of \( g \), which could lead to different interpretations of function composition.
Participants express differing views on the implications of the injectivity and surjectivity of composite functions. While some agree on certain conclusions, there is no consensus on the necessity of \( f \) being surjective for \( g \circ f \) to be defined, and the discussion remains unresolved regarding the implications of Munkres' definitions.
Limitations in the discussion include varying interpretations of definitions related to function composition, particularly concerning the relationship between the image of \( f \) and the domain of \( g \). Participants also highlight the need for careful consideration of examples to test the validity of their reasoning.
Rasalhague
I'm looking at Munkres: Topology Problems 1.2.4(c), 1.2.4(e), and 1.2.5(a). Problem 1.2.4(c) asks, "If [itex]g\circ f[/itex] is injective, what can you say about the injectivity of f and g?" Problem 1.2.4(e) asks, "If [itex]g\circ f[/itex] is surjective, what can you say about the surjectivity of f and g?"
I concluded [itex]g\circ f[/itex] injective implies that both f and g are injective, and that [itex]g\circ f[/itex] surjective implies both f and g surjective.
But Problem 1.2.5(a) is worded in a way which suggests my conclusion might be too strong: "Show that if f has a left inverse, then f is injective; and if f has a right inverse, then f is surjective."
Am I mistaken?
Let [itex]f:A\rightarrow B[/itex] and [itex]g:B\rightarrow C[/itex]. According to Munkres' definition of function composition, [itex]g\circ f[/itex] is only defined if f is surjective; so clearly [itex]g\circ f[/itex] surjective implies f is surjective.
For Problem 1.2.4(c), I reasoned as follows. If [itex]g\circ f[/itex] is injective, then
[tex]f[a_1]=f[a_2][/tex]
[tex]\Rightarrow (g\circ f)[a_1]=(g\circ f)[a_2][/tex]
[tex]\Rightarrow a_1 = a_2,[/tex]
so f is 1-1 too.
And if [itex]g[b_1]=g[b_2][/itex], then
[tex](\exists a_1,a_2\in A)[(b_1=f[a_1])\&(b_2=f[a_2])][/tex]
and, for this [itex]a_1,a_2[/itex],
[tex](g\circ f)[a_1]=(g\circ f)[a_2][/tex]
[tex]\Rightarrow a_1 = a_2[/tex]
[tex]\Rightarrow b_1 = b_2,[/tex]
so g is 1-1.
For Problem 1.2.4(e), I reasoned as follows. As mentioned above, f is surjective. So for all b in B, there exists some a in A such that b = f[a]. Suppose for all c in C, there exists some a in A such that g[f[a]] = c, and let b = f[a]. Then for all c in C, there exists some b in B, namely f[a], such that g = c; so g is surjective too.
Aaaaaah, could this be what was confusing me? Munkres uses the word "range" to mean what, in my experience, is normally called "codomain". He writes, "Note that [itex]g \circ f[/itex] is only defined when the range of f equals the domain of g." Given f:A-->B and g:B-->C, he defines the composition [itex]g\circ f[/itex] as a function having a rule of the form a in A maps to c in C such that, for some b in B, b=f[a] and c=g. Specifically, he defines the rule of a function as the set of pairs of (in this case) the form (a,c) = (a,[itex]g\circ f[/itex][a]). So there must be at least one such element of B, but I don't think he's making any requirement that the domain of g equal the image set of f. I also don't see how we can conclude from his definition that the domain of g equals the codomain of f.
Elsewhere (Bishop & Goldberg: Tensor Analysis on Manifolds, 0.1.4), I've seen composition defined without even the requirement that the domain of g intersect, let alone equal, the codomain of f. If they don't intersect, the result of composition is what they call the empty function. As far as I can see, Munkres' definition in terms of pairs allows nonequality, but not non-intersection.
Am I mistaken?
so f is 1-1 too.
so g is 1-1.
f need not be surjective for [itex]g \circ f[/itex] to be defined.
consider f(x) = x2, g(x) = x+1.
note that [itex]g \circ f[/itex] makes sense for all real x, even though f never takes on any negative values.
on the other hand, if f(x) = x+1, and g(x) = √x, THEN we have a problem, for it's not clear what value to give to [itex]g \circ f(-2)[/itex].
because of this, [itex]g \circ f[/itex] might be injective, even if g isn't:
let A = {a,b,c}, B = {w,x,y,z} C = {s,t,u} with f:A→B, g:B→C
f(a) = x
f(b) = y
f(c) = z
g(w) = s <--
g(x) = s <--g not injective
g(y) = t
g(z) = u
then gof(a) = g(f(a)) = g(x) = s
gof(b) = g(f(b)) = g(y) = t
gof(c) = g(f(c)) = g(z) = u
gof is clearly injective, but g is not. why? because im(f) < dom(g).
a similar situation holds when gof is surjective, g has to be surjective, but f need not be.
Thanks, Deveno. I get it now. Good examples. I forgot that Munkres uses the word "range" to mean "codomain", and I hadn't yet thought through all those consequences.
(I guess you're implicity defining the codomain of this f to be R.)
By Bishop & Goldberg's definition, there's no problem with the composite being ill-defined in this case; for them, the domain of [itex]g \circ f[/itex] is the preimage of the intersection of the image of f with the domain of g. So in this example, negative numbers aren't in the domain of [itex]g \circ f[/itex]. Munkres' definition appears similar: "Formally [itex]g \circ f : A \rightarrow C[/itex] is the function whose rule is
[tex]\left \{ (a,c) | \text{For some }b \in B \text{, f(a)=b} \text{ and } g(b)=c \right \},[/tex]
except that he requires the domain of the composite, [itex]g \circ f[/itex], to equal the domain of the inner component, f. So, using his definition, and assuming all these functions are real-valued, the composition of a pair of functions with the rules of assignment you give in your "on the other hand" paragraph would not be defined unless the codomain of f was a subset of the positive reals.
Rereading Munkres more carefully, I see it is true he's defined composition in a way that specifiers that the codomain of f is equal to the domain of g, but now that I realize Munkres is not making any stipulation about the image of f, it seems to me that it wouldn't make much difference if this requirement was omitted from the definition, as Bishop & Goldberg do.
"Because of this" = "Because of the problem"? I don't quite follow that. But nice example. Makes me think I should play around more trying to come up with simple examples to test the reasobableness of things I'm trying to prove.
f(a) = x
f(b) = y
f(c) = z
g(w) = s <--
g(y) = t
g(z) = u
Okay, I see, so if [itex]g\circ f[/itex] is surjective, then g must be, otherwise not every element in C would be "hit" by the composite function. And if f is not surjective, then it doesn't matter; it's still possible for every element in C to be mapped to by the composite from some element in A. Thanks again for your help!
  • · Replies 0 ·
30K
