What is the Formula for Sizing a Shaft at 150,000rpm?
  • Thread starter Thread starter max11
    Shaft Sizing
The discussion focuses on sizing a shaft for a turbocharger operating at 150,000rpm, requiring a torque transmission of 9Nm and a length of 200mm, with a shear stress limit of 457MPa. The initial formula used was D = 1.72 (Tmax/σmax)^(1/3), which yielded an impractical diameter of 0.46mm. A correction by another participant provided a more realistic diameter of 4.65mm, indicating the importance of accurate calculations in mechanical design.
  • Understanding of torsion and shear stress in materials
  • Familiarity with mechanical engineering principles
  • Knowledge of the formula for shaft diameter calculation
  • Experience with turbocharger mechanics
  • Research the impact of rotational speed on shaft design
  • Learn about material selection for high-stress applications
  • Explore advanced shaft design formulas and methodologies
  • Study the effects of torque on shaft integrity and performance
Mechanical engineers, automotive engineers, and anyone involved in the design and analysis of high-speed rotating machinery, particularly in turbocharger applications.
max11
Hiya
I was hoping that somebody would be able to help me.
I need to size a shaft coming from a turbocharger spinning at 150,000rpm the shaft needs to transmit 9Nm and 200mm in length, the shear stress of the material is 457MPa.
I need to size the diameter of the shaft and know that it is going to be very small but can't seem to find a formula that gives me a sensible answer, right now I am using a formula from engineering toolbox (http://www.engineeringtoolbox.com/torsion-shafts-d_947.html)
D = 1.72 (Tmax/σmax)1/3
But this give me a diameter of 0.46mm which seems so small that it would just twist and break.
an y help greatly appreciated.
Cheers
Hi Max. Check your work again. I'm getting 4.65 mm.
53K
