Torque and Power required to turn a plate
  • Context: Undergrad
  • Thread starter Thread starter superman22x
    Plate Power Torque
The discussion centers on calculating the torque and power required to operate a locking Geneva mechanism for a cast iron table with a mass of 7300 kg, rotating 72 degrees in 0.5 seconds. The user calculated an angular acceleration (alpha) of 10.08 rad/s² and an inertia (I) of 612.3 kg·m², leading to a torque of 6172 Nm. However, the power requirement was calculated to be 1867 kW, which is deemed excessively high due to a miscalculation in RPM, as the correct conversion shows 5.04 rad/s equates to only 288.8 RPM, not 2888 RPM.
  • Understanding of rotational dynamics and torque calculations
  • Familiarity with the Geneva mechanism and its operation
  • Knowledge of angular acceleration and inertia formulas
  • Proficiency in unit conversions, particularly between radians and RPM
  • Review the principles of rotational dynamics and torque calculations
  • Study the mechanics of the Geneva mechanism in detail
  • Learn about energy conservation in rotating systems
  • Explore advanced power calculations for mechanical systems
Mechanical engineers, students in mechanical design courses, and anyone involved in the design and analysis of mechanical systems utilizing rotational motion.
superman22x
I have a question. I am working on a small project for class. We have locking Geneva mechanism that turns a table made of cast iron 72* in .5 seconds. The table mass is calculated to be 7300 kg (D=1.25m, h=.350m).
Based on the 72* in .5 seconds, I calculated alpha to be 10.08 rad/s^2. Using I=m*r^2/2, I calculated I to be 612.3. Torque (Nm)=alpha*I=6172N*m.
For power, I used the equation P (Kw) = (Torque*2*pi*rpm)/60,000. And I used alpha*t to solve for the RPM, which ended up being 5.04 rad/s = 2888 rpm. My power required ends up being 1867Kw which seems ridiculously high. Am I calculating this correctly?
Let me know of any other info you need.
I didn't know what a Geneva mechanism was before this thread.
http://www.brockeng.com/mechanism/Geneva.htm
5.04 rad/s is < 60 rotations per minute.
2 pi rad/s is 1 rotation/second = 60 rpm, so I don't know where you got 2888 rpm.
A bigger problem is that the continuously rotating wheel accelerates the slotted wheel for the first 0.25 seconds, but decelerates it in the next 0.25 seconds, and it will probably get most of the kinetic energy from the first 0.25 seconds back. The continuously moving wheel will than have the time that the slotted wheel is stationary to get back to its original speed.
  • · Replies 19 ·
  • · Replies 138 ·
10K
  • · Replies 24 ·
