Hall Effect Magnetic Flux Sensor in very Strong Magnetic Fields
The discussion revolves around the challenges of selecting a suitable Hall-effect magnetic flux sensor for use in an extremely strong magnetic field of approximately 16.5 Tesla. Participants explore various sensor options, alignment requirements, and the complexities of measuring magnetic flux variations with high accuracy.
  • One participant describes the need for a Hall-effect sensor that can be aligned with high precision (1/10 of a degree) in a strong magnetic field.
  • Another participant suggests considering Metglas as a potential material for the sensor, providing links to relevant articles.
  • A participant expresses the need for a more sophisticated device with low linearity error and high magnetic sensitivity.
  • Discussion includes the cost and specifications of the Lakeshore HGT-3030 sensor, highlighting its sensitivity and operating conditions.
  • One participant questions the physical size and specific measurements required from the apparatus, indicating a lack of experience with such strong magnetic fields.
  • Another participant emphasizes the importance of using a proper sensor given the sophisticated nature of the equipment involved, suggesting that the cost may be justified.
  • Concerns are raised about the potential impact of the measuring apparatus on the local magnetic field.
  • Participants share resources, including a recommended handbook and application notes, to aid in understanding magnetic measurements.
  • One participant expresses skepticism about the feasibility of creating a sensor from unconventional materials, while another encourages purchasing a proper sensor instead.
  • There is a query regarding the practicality and cost of generating such a high magnetic field.
Participants do not reach a consensus on the best sensor to use, with multiple competing views on the suitability of different models and approaches. The discussion remains unresolved regarding the optimal solution for the specific application.
Participants express varying levels of familiarity with strong magnetic fields and Hall-effect sensors, leading to differing opinions on the complexity and requirements of the project. There are mentions of unresolved technical details related to sensor interfacing and read-out electronics.
This discussion may be useful for individuals working with Hall-effect sensors in high magnetic fields, researchers in magnetics, and those interested in precision measurement techniques in experimental physics.
_maxim_
Dear PFs
I am facing a problem with finding a good Hall-effect magnetic flux sensor which should be fixed in the top of a probe working in a very intense magnetic field.
The probe must be aligned to a certain degree with respect to the direction of the main field. The requested alignement accuracy should be on the order of 1/10 of degree (or less even better).
The magnetic field is very strong, of the order of 16.5 Tesla (16.5 x 10^4 Gauss).
I had thought to place the sensor in parallel geometry, with its plane oriented parallel to the magnetic flux lines. Thus I expect to detect a zero voltage when the sensor is perfectly aligned to the main field, and a not-zero voltage which depends strongly on the angle between the direction of the main field and the normal to the sensor surface.
Afterwards I will try to elaborate such voltages (VH) to get a feedback for the correct alignement.
http://img692.imageshack.us/img692/5579/hallfield.png
Here's the problem: which kind of sensor can I test?
I've drawn my attention to the Lakeshore Hall device HGT-3030, but it seems to be very difficult to find.
Any experience here?
Can you suggest some commercial models with a easy schematic diagram or application note?
Thanks for your enthusiastic responses!
max
might Metglas be of any use?
here's a hobbyist article..see page 2 0f 6.
http://www.tinaja.com/glib/muse104.pdf
and
http://www.metglas.com/faq/?faq_id=24
Question:
What is the permeability of 2714A?
Answer:
Our METGLAS 2714A ribbon can achieve a permeability of 100,000. The ribbon thickness is about 18 micron and we can supply up to 50 mm (2 inch) wide ribbon.
Thanks Jim.
I think I need a more sophisticated device, as Linear Hall Effect Sensor ICs with a low linearity error and a good magnetic sensitivity.
HGT-3030 Transverse Hall generator costs $444...
Magnetic sensitivity . . . . . . . . . . 6.0 mV/kG to 10.0 mV/kG
Nominal control current . . . . . . . 100 mA
Maximum linearity error . . . . . . . ±0.30% rdg (-10 to 10 kG) ±1.25% rdg (-30 to 30 kG)
Zero field offset voltage . . . . . . . ±75 µV (max)
Operating temperature range . . . . -40 ºC to +100 ºC
Active area . . . . . . . . . . . . . . . . 1.02 mm diameter
Honestly, I was looking for an equivalent inexpensive device.
No more ideas? :(
What physical size must this apparatus be?
What is it about the field that you want to measure? Intensity, direction, variations?
I have only tinkered as a hobbyist with a fluxgate magnetometer measuring Earth's field and i don't have experience with fields as strong as you cited, which sounds like it might be in a speaker voicecoil airgap or something. I also tinkered with some LVDT position sensors (12 feet tall) at work... another story ...
My magnetometer sensed from kitchen table automobiles passing in the street, refrigerator door opening, it had surprising sensitivity. But you are looking for precise measurement of direction? Will your apparatus affect the local field?
Jack M Janicke's Magnetic Measurements Handbook is best "poor man's" introduction to the subject that i ever saw.
Here's Honeywell's introductory appnote.
http://www51.honeywell.com/aero/common/documents/Applications-of-Magnetic-Position-Sensors.pdf
Sorry - i just am not expert in that field, so shotgunned you with what i could find 'cause you asked for help and there didnt seem to be much.
I don't know your degree of familiarity so hope you aren't offended.
old jim
http://www.diodes.com/datasheets/ZMT32.pdf
Hi Jim,
as wrote at the beginning the magnetic field I need to handle is very strong, of the order of 16.5 Tesla (16.5 x 10^4 Gauss)!
Yes, my application is not trivial. I need to measure flux variations of a strong magnetic field over an area of c.a. 1mm2 with high accuracy.
The sensor will be placed inside the magnetic field, where a probe for nuclear measurements must be aligned to the lines of force.
Nice, I will have a look.
old jim
Com'on, where is the problem? :biggrin:
Thank you for your help!
It sounds fascinating and i wish i had experience to offer you.
But i'd get distracted trying to invent a new sensor out of Flint glass and Faraday effect.:rolleyes:
Best of luck to you, sir, and thanks for your kindness.
old jim
My advice would be to just buy a proper sensor. The fact that you are working with a 16T magnet means that you are using reasonably sophisticated equipment (you are obiously not doing this in your basement at home), and $400 is not much money under these circumstances.
Also, remember you will -regardless of what you end up using- need some form of reasonbly accurate read-out electronics; and good sensor will probably easier to read out, meaning you won't need a a bunch of extra kit just to compensate for the fact that your sensor is e.g. giving you a very weak signal.
Hi f95toli
:smile: In these circumstances $400 is too much when you have to pay from your own pocket...
I guess the driving of such a sensor is not trivial, and I have no experience on that.
This I know; infact I was looking for a HGT-3030 Lakeshore sensor.
In the meantime I hoped to find here peple with some experience in projecting of interfaces for Hall sensor, just to avoid lost of time fighting the silliest problems.
Perhaps another thread would be most suitable?
Thanks anyway for your input!
maxim
Get that Janicke book.
I hope he's still living - we exchanged several emails on my magnetometer.
He is very knowledgeable practical and helpful.
old jim
Hi Jim,
I've found it on Amazon. I will (re)start from that.
How are you making a 165 kilogauss field?
This high a magnetic field requires extremely expensive equipment.
It is a commercial cryomagnet made with superconductive wires working at the liquid Helium temperature (4.2 K). This has not been bought by myself, rather by the lab that asked my expertise. There is no budget saved for the project "Hall-sensor".
That's why I am looking for an unexpensive solution: this should get out of my wallet.
Unfortunately for me it seems that only (expensive) Lakeshore sensors are on the horizon...
Hi Jim,
Thanks for the tip.
ZMT32 is in stock but for applications under low field conditions, which is not the case.
I think what I would do in my case, it would be something in the middle between ZMT32 and HGT-3030
  • · Replies 0 ·
9K
  • · Replies 19 ·
