Why is there an induced current in a dc motor?
The discussion revolves around the concepts of induced current and opposing forces in DC motors and AC generators. Participants explore the implications of Fleming's Right and Left Hand Rules, the behavior of induced electromotive force (emf), and the distribution of forces within the armature of a generator. The scope includes theoretical explanations and conceptual clarifications related to electromagnetic principles.
  • Some participants express confusion about the direction of induced current in a DC motor and how it relates to Fleming's Right Hand Rule.
  • There is mention of an opposing emf, εback, being induced in a DC motor, which interacts with the external emf, εsupply, as described by Kirchhoff's second law.
  • Questions arise regarding whether the induced emf will be less than the external emf in a DC motor.
  • Participants discuss the forces acting on the armature of an AC generator, questioning whether the force is distributed across the armature or concentrated on one side.
  • Some participants clarify that in a simple rectangular coil generator, forces on opposite sides of the coil can cancel each other out, while others create a torque that opposes the motion.
  • There is a discussion about the role of induced current and the magnetic field in generating opposing forces, with references to Fleming's Left Hand Rule.
Participants do not reach a consensus on several points, including the behavior of induced current and the distribution of forces in the armature of a generator. Multiple competing views and uncertainties remain throughout the discussion.
Some participants note limitations in their assumptions, such as the simplifications made regarding the coil's orientation and the effects of load on the generator. The discussion also highlights the complexity of interactions between induced current, emf, and mechanical forces.
sgstudent
When I put a current into a dc motor, there will be a turning effect. But I thought as this happens, won't there the an induced current that flows in the opposite direction? Bt Fleming's Right hand rule, the current will flow in the other direction. So I'm quite confused about this.
Similarly, when I have an ac generator.won't there be a force acting opposite to your motion? By Fleming's Left Hand rule? So I'm quite confused about this too.
Lastly, when I turn the handler of the coil in the ac generator, eg with 10N. Will the force solely act at one side of three armature or will the force be divided into 2 then they will act at the 2 ends and one is upwards the other downwards?
Thanks for the help! :)
There will be an opposing emf, εback, induced. So there are two emfs acting, the external emf, εsupply and εback. There can only be one current, I, though. It is determined (using Kirchhoff's second law) by
εsupply - εback = Ir,
in which r is the resistance of the motor measured across the brushes.
This ignores complications such as field windings.
But will the emf back be lesser than the external emf? Thanks for the help!
Yes. Otherwise the current would be flowing backwards through the power supply, and, if it consisted of rechargeable batteries, you'd be recharging them, at the same time as getting mechanical work from the motor.
Thanks for the help! BTW then when I turn the ac motor'a handle, is the force only acting on one of the armature or will the forces be divided by 2 and the force will be divided by 2? Thanks for the help.
You're asking about an a.c. generator, I assume. Are you taking it to be a simple rectangular coil being turned in a uniform field? In that case, for most orientations of the coil, both pairs of opposite sides will experience equal and opposite BIL sinθ forces on their two sides. For one pair, BC and DA, the forces will simply cancel. For the other pair, AB and CD, the forces, FAB and FCD, although equal and opposite, don't act in the same straight line, and will constitute a 'couple' giving rise to the clockwise torque that opposes your turning of the axle.
Oh ok I get it. But also, won't there be opposing forces due to the new induced current and also the magnetic field? So by Fleming's left hand rule, there's an opposing force. So how so do they turnl
The current I've shown in the diagram, and which gives rise to the forces I've been talking about, IS the induced current! Remember, this is a generator: you (or some external agency) has to turn the coil – using a torque which has to be at least as large as the opposing torque due to the BIL sinθ forces due to the induced current.
[If the generator is 'open circuit' coil not connected to any load, but terminals not connected to anything, an emf will still be induced as you turn the coil, but there will be no current, nor any opposing forces.]
  • · Replies 18 ·
