Impulse/force in pounds for the time frame
  • Context: Graduate
  • Thread starter Thread starter waynexk8
    Frame Time
The discussion revolves around calculating the impulse force experienced by a machine lowering and lifting a weight, specifically focusing on the transition from lowering to lifting and the forces involved during acceleration and deceleration phases. The context includes both theoretical and practical considerations of force dynamics in mechanical systems.
  • Wayne presents a scenario involving a machine lowering a 100-pound weight and asks for the impulse force on the machine's components during the transition from lowering to lifting.
  • Wayne notes that the machine has a maximum force capacity of 125 pounds, suggesting that the force on the machine could exceed this limit during rapid stops.
  • Some participants emphasize that bodies in motion cannot stop instantaneously, and the impulse force depends on the time interval of deceleration.
  • There are discussions about converting units between imperial and metric systems, with Wayne acknowledging the mix of units used in his question.
  • One participant calculates the net force required to lift the weight at a constant speed and discusses the implications of acceleration on the force needed.
  • Another participant suggests that the nature of the movement affects the force calculations, proposing different scenarios for lifting and lowering the weight.
  • Wayne expresses uncertainty about the exact forces involved during the deceleration and acceleration phases and seeks clarification on how to calculate these forces.
  • There are mentions of varying force requirements during different phases of the lift, with some estimates suggesting forces could reach over 150 pounds during rapid acceleration.
Participants generally agree that the impulse force is affected by the time interval of deceleration, but there are multiple competing views on the exact forces involved and the calculations required. The discussion remains unresolved regarding the specific values of force during the transition phases.
There are limitations related to the assumptions made about the nature of the movement, the time intervals for acceleration and deceleration, and the conversion between different unit systems. The calculations presented are based on rough estimates and may not account for all variables involved.
  • #181
Wayne, do these people know that their private correspondence with you is being posted on the Internet including their name? This seems like a very bad practice unless you have their explicit permission.
  • #182
:biggrin:Those discussion are from many years ago and have been posted in more than 10 different forums around the internet(without any permission of course).The same is also true for the discussions here!
Twelve pages and so many threads for a question that can be answered in just one line!
The average force is always the weight regardless the lifting speed.
  • #183
What forces have you the slow got that can make up the propulsive forces in the studys, there are no extra force in the slow reps, are there ?
Back later to catch up on all posts.
Wayne
  • #184
Wayne,
May I suggest an experiment? Do you have access to a bathroom scale and two video cameras?
Set up one camera to record the scale reading and perform your various fast and slow exercises. Afterwards, view the recording frame by frame and plot the scale reading for each frame (like douglis' graph, but it won't look the same). Don't forget to subtract your own weight from all the readings. This will rather conclusively demonstrate the difference in forces.
Add up all the readings for a repetition (again, adjusted for your weight). Then divide by the number of frames over which the readings were observed. This will be the mathematical average and should be very close to the weight you are lifting. How close depends upon how well the experiment is performed.
The second camera is used to record the movement of the weight with a tape measure, or other suitably visible scale, in the background. Again, go through frame by frame and plot the position of the weight. This should look something like douglis' graph. Next, plot the change in position from one frame to the next (velocity). Next, plot the change of this change (acceleration) from one frame to the next. This third plot should look just like the first plot of the scale readings.
F = ma
The first plot of the scale readings is force. The last plot is acceration. Since the mass doesn't change, the two remain proportional to each other and the plots should be very similar.
The scale and cameras won't lie. If you need help decipering the results and making the appropriate plots, well, I may be busy, but there are others around who will help.
  • #185
jmmccain said:
Wayne,
F = ma
I'd advise not getting too involved with this. All your suggestions have been made many times before, in this thread and earlier threads. Wayne does not believe in the accepted ideas of Physics. He has his own models and vocabulary of Physics.
Also, your thought experiment on the bathroom scales would not show the sampled forces accurately or frequently enough to convince Wayne. There would be errors which he would jump on and claim that the experiment showed him to be right. The scales and camera would lie in practice unless a much more sophisticated system were used.
In any case, what you say would only apply to free lifts and not to exercises on machines that introduce friction. That also confuses Wayne and strengthens him in his misconceptions.
  • #186
I wish you and D. would do the same, and answer some of my questions ?
sophiecentaur said:
OK. You go from London to Bristol at an average speed of 62miles per hour. You could work that out easily enough. But how would you, Wayne, work out what your 'total speed' was? That's how daft your idea of total force is.
You got a point on that one, see what you mean, WILL think more on this one, BUT why then are you, and D. saying, the average force is the same ? I think that you have taken my maximum force from the acceleration, and then took away my minimum force from the deceleration, but “why” did/do you do this ? However ever, speed is a little different to force, take a look on this video, they measure the maximum force and minimum force, and then they calculate the average force, which will be the same, but we do NOT want this, this is what I keep ON telling D. over and over, we do not want the average force, we want all the three average force, the forces from the negative, the force when lowing the weight, the peak force, the huge peak force from the transition from negative to positive, and the positive force, the forces when lifting the weight.
NOW, if the weight was 80 pounds and my 1RM was a 100 pounds, if I start the lift from the top, lower in .5 of a second and lift in .5 of a second for the fast, and lower in 3 seconds and lift in 3 seconds.
1,
The fast,
The tension on my muscles to lower it would be just under 80, call it 79, then at the transition from eccentric to concentric, would have the maximum tensions on the muscle, say ? 140 ? Then the tensions on the muscles to accelerate the weight up would be close to 100. 79 + 140 + 100 = 319/3 = 106 over 1 second.
2,
The slow,
The tension on my muscles to lower it would be just under 80, call it 79, then at the transition from eccentric to concentric, would have the maximum tensions on the muscle, say ? 85 ? Then the tensions on the muscles to accelerate the weight up world be close to 80. 79 + 85 + 80 = 244/3 = 81 over 6 seconds.
3,
Divide the slow of 6 seconds by the fast of 1 second, 81/6 = 13 over 1 second.
Ok that’s wrong, but how would you do this please ? What if we added them up ? As in this debate/test/study, average means nothing, so it’s fast, 79 + 140 + 100 = 319 over 1 second. Slow 79 + 85 + 80 = 81 over 6 seconds, 13 over 1 second.
Take a look at this video, they say how they work out the average force on it, and they show the maximum force and minimum force, click on click to preview. What you and D. are doing, is taking to points, and taking the maximum and minimum forces and averaging them up, well of course the average force is going to be the same, but it means nothing here, you are just taking the maximum and minimum, and adding them together and averaging them out, that’s what we don’t want here, we NEED to add in the maximum acceleration force, the maximum peak force, {of the transition from negative to positive, this maximum peak force, can put up to 140 pounds of force on the muscles} and the maximum deceleration force, what you are doing is leaving out the most important, the maximum peak force from the transition, why are you leaving this force out, which put the huge tensions on the muscles, and the debate is, which puts the most over the same time frame, the most overall or total tension on the muscles.
http://webcache.googleusercontent.com/search?q=cache:Nze_pWKG-40J:www.fittech.com.au/products/ForcePlate.htm+force+plate+average+force&cd=2&hl=en&ct=clnk&gl=uk
Wayne
  • #187
sophiecentaur said:
I have read the paper an I think I can see your problem. I find little to disagree with what is written.
They are not considering the whole cycle (lift/lower) when they refer to mean force.
Right could we get to this point, as D. would not explain, could you explain on what you think they are leaving out ? as I do not get it.
sophiecentaur said:
They are not only discussing free lifts but machines that present RESISISTIVE loads. Everything changes in that case because you are not just changing gravitational potential energy in that case but work is being done in overcoming friction.
Please forget the machines, this at this moment is just about free weights.
sophiecentaur said:
If you had read what they say then you would not think they are disagreeing with established physics at all. You did not understand what you were arguing about because you insisted on giving details instead of condensing your questions into something meaningful.
I did not think they are disagreeing, or never said they were disagreeing with established physics.
What I said, was what forces do you think you have that can make up of balance out the higher propulsive forces of the fast in the studies ?
Let’s take the mean propulsive forces, slow 6.2mean in 10.9 seconds. Fast 45.3mean 2.8 seconds, now let’s divided the mean slow of 10.9 seconds by the fast 2.8 = 3.8, so now let’s divide the slow mean by 3.8 = 1.6.
Fast mean for 2.8 seconds = 45.3.
Slow mean for 2.8 seconds = 1.6.
Please what forces have I left out that the slow has to make up or balance out these ?
http://www.jssm.org/vol7/n2/16/v7n2-16pdf.pdf
Wayne
  • #188
Will get back to jmmccain and Dalespam tomorrow, funny I have two very good high definition cameras.
Wayne
  • #189
No time just now, to read the posts and answer.
Just wanted the state why average force means nothing in this debate
I lift 80 pounds at “any” speed, let’s go for 1/1, {1 second positive and 1 second negative} you all are saying that the average force for 1 repetition, and the average force for a 100 repetitions are the exact same ? However, we all know that you will exert far more total or overall force doing the 100 repetitions. You will exert a force the same as you do for 1 repetition {forgetting fatigue here} = 2 seconds, for 200 seconds, so its overall or total force output x 200 seconds.
So the question is, why does everyone keep commenting on the average force is the same, when it has no reverence in this debate ? What we are looking for, is in which repetition speed, in the same time frame, puts the most overall or/and total tensions on the muscles ?
As I have said, as you fail 50% faster using the .5/.5 to the 3/3 using 80% this does mean thet you have put more tension on the muscles faster, right ? And to put more tension on the muscles, and faster, you will have to use more force, if not please say why you think not ? PLEASE will someone try to answer this.
Are there anyone out there that thinks if you fail to lift a weight up after say 10 seconds, as you are lifting it faster, that it is not because you have put more tension on the muscles than the slow lifting, if so say why please.
Wayne
  • #190
You were the one who asked what average force was. You also asked about Total Force.
Do keep up!
  • #191
Wayne
Can you quote me a single statement, from anyone else, on this forum or in the communications with others that you have shown us, that indicates what you are talking about makes any sense in terms of the Physics? Everything I have read looks like non-committal and polite put-downs. When will you get the message?
Have you not realized that no one wants to discuss your endless, blow-by-blow descriptions of a lifting session? If you cannot be bothered to condense your questions into a digestible form then I, for one, can't be bothered to read them. I (/we all) have given you all the facts about the very straightforward Physics that relates to the process.
You haven't been prepared to accept it because it "doesn't feel right to you", somehow and you haven't been prepared even to use 'our' vocabulary. Can you be surprised that you aren't getting satisfaction?
  • #192
DaleSpam said:
Hi waynekx8, I didn't notice that you were back.
It looks like you are still confusing "work done" and "energy expended" as we discussed last year: https://www.physicsforums.com/showthread.php?p=3190515#post3190515
Hi again Dalespam,
Actually I am not confusing work done and energy expended, "unless" work done means the overall or total force used ? And we know for a fact that the fast does more work and uses more energy.
Average means nothing in this debate. What I am looking for is the higher overall or total forces used, thus more overall or total force on the muscles, just take this example.
Lift a weight up and down for 10 seconds, lift a weight up and down for 6o seconds, the average force is the same, but lifting the weight for 60 seconds WILL and DOES put more total or overall tension on the muscles, this means the total or overall force was more.
What we WANT to know is the same for lifting the weight up and down 6 times in 6 seconds, and lifting the weight up and down 1 time in 6 seconds.
Now I say without a shadow of a doubt, it’s the fast, and here is why. If you took both repetitions speeds to momentary muscular failure, meaning if you lifted the weights at the two given speeds until you could not move the weight, you would fail about 50% faster lifting the weight the fast way. This can ONLY mean one thing, you put more tension on the muscles faster, thus the muscles failed faster, thus more force must have been used in not only the same time frame, but in less time frame, you also use more energy in the fast, why ? It’s because your putting out more force and tension on the muscles, if not, why please ? As no one here is giving me a direct answer, they seem to not want to, or can't ?
Wayne
  • #193
waynexk8 said:
Hi again Dalespam,
Wayne
That statement is meaningless. There is no "debate" possible on that basis. Why not do us all a favour and use PF language?
Total force is as daft as total speed. Come to terms with that.
  • #194
waynexk8 said:
Actually I am not confusing work done and energy expended ... And we know for a fact that the fast does more work and uses more energy.
Yes, you are still confusing them. In fact, this quote proves that you are confusing them since you finish with the confused statement that the fast does more work and uses more energy.
The correct statement is that the fast does the same amount of work and uses more energy (i.e. the human machine is less efficient at doing fast work). If you were not still confusing the concepts then you would not still be making the same incorrect statements.
Let f(t) be the force exerted by the human on the weight at time t. Please define overall or total force in terms of f(t).
For example, average force from time [itex]t_i[/itex] to time [itex]t_f[/itex] is:
[tex]\overline{\mathbf{f}}=\frac{\int_{t_i}^{t_f} \mathbf{f}(t) \, dt}{t_f-t_i}[/tex]
Please provide a similar rigorous definition for total or overall force.
  • #195
@Dalespam
I see you are being drawn into this. Beware - madness lies there. :bugeye:
  • #196
sophiecentaur said:
@Dalespam
Thanks for the warning sophiecentaur, but I have worked with wayne before, same topic different thread. I will only stick around while it is fun.
  • #197
It's quite incredible how he bounces back with the same question, which, in itself, has no meaning.
  • #198
I was trying to think of weight lifting analogy to describe his behavior in terms that he could understand, but my weight lifting vocabulary is fairly limited.
Basically, I want to get across the point about how stupid I would be if I were to go to him and a bunch of other weight lifting experts and ask for their advice on a weightlifting problem and when all of them tell me the same thing I then ignore their expertise and continue doing the opposite. Particularly if they are united in their opinion and persist in their opinion after detailed questioning.
They are experts in weight lifting, I know that I am ignorant on the subject, and since they all agree with each other, and my opinion disagrees with them, the only reasonable thing to do is to recognize that my uninformed opinion is almost certainly wrong and try to understand their advice.
Also, it wouldn't be helpful for me to call a weight machine a dumb bell, nor would it be helpful for me to talk about things they have never heard of like the supercalifragilistic rep without describing in detail what I mean by that. Furthermore, if they corrected me on my incorrect use of the term weight machine and dumb bell and I continued to use it incorrectly (for years) they would reasonably become frustrated.
  • #199
Precisely. For "force" substitute "bannana" and his physics would make the same amount of sense.
  • #200
jmmccain said:
Wayne,
Hi jmmccain,
Yes,
How do I do this please ?
However, as I said, there is a problem using average force, as if you do 1 repetition at any speed, say 1/1, that’s 1 second up and 1 second down, you will get the same average force if you do 1 repetition or a 100 repetitions. So average will not tell us anything, or will it ?
1 repetition = 100 force up and 60 force down, 100 + 60 = 160/1 = 160, average force = 160.
100 repetitions, 100 x 100 = 10000, 100 x 60 = 6000, 10000 + 6000 = 16000/100 = 160.
Some the average force is the same, BUT we all know that the doing the 100 repetitions is going to use more muscle force and put more tension on the muscles
I made a thread on this and told D. this average means nothing in this debate, but he and some others still insist it does, but can’t not say ?
F = ma
This seems very interesting, and have heard of this before, but not sure this will give use the right results. PLEASE what results will this tell us, I don't understand what this will show ?
Wayne
  • #201
Do you guys know about sampling theory? To do this investigation to any satisfactory degree (to avoid misleading results) you will need a slo-mo camera, at the very least, and a set of scales with ms response times. I don't think the average bathroom scales has been designed that way. Also, you would need many samples and some good data analysis.
If it were really as trivial as you suggest, it would be an AS level Physics practical.
The last thing we would want would be a naff experiment that could yield results either way. If they went the wrong way, we could never ever convince Wayne that he's barking up the wrong tree.
And what about the 'total speed' question, Wayne? If you can't justify total speed then you can't justify total force. I await your specific and detailed response.
  • #202
I have heard of this before, but never knew how to do it, and not sure what the results will be ?
Wayne does believe in accepted ideas of Physics, I don’t understand why you say that, what I am saying, and have proven, that the avenger force can show us “nothing” unless you think is can, if so, please say what ?
I would not jump on small errors ?
You a D. have dismissed a real World EMG test, but you cannot say why, I think because it shows what I say is right, and what you cannot work out with physics, in that there HAS and IS more force in the faster repetitions in the same time frame. Or do you and D. think that I fail faster when doing the faster repetitions because there is less force output by the muscles, and less tension on the muscles ? If so please say and explain why you think that or other, the point is you do fail 50% faster, thus there can ONLY be ONE reason for this, you produce for force in the same time frame, putting more tension on the muscles, making the muscles fail faster, if you do not think this, please say why ?
This does, or cannot confuse me; I train on free weights, Nautilus machines, and round circular pulleys, and have made many of my own machines and know the effects of all of them on the muscles. This debate is basically on free weights, with a machine doing the exercise or a Human.
Wayne
  • #203
You so much do not believe in the ideas of conventional Physics, Wayne, that you even refuse to use the correct terminology.
You seem to ignore the fact that everyone agrees that the Maximum force for fast lifts must be higher because of the acceleration - that's proper Physics.
Just imagine - to change tack- that you had replaced your arms with a strong pair of springs of the appropriate stiffness. If you lifted the weights to your normal lift height and then let go, the weights would go down and up and down and up for a long time until friction became apparent. No work done at all if you recover the weights when they are at the top of their bounce. That's Physics. It's true and it just doesn't represent a good model of your muscles.
If you used a stiffer spring, the oscillations would be at a faster rate or, for a less stiff spring, the oscillations would be at a slower rate. No difference, in any of the cases, with the energy involved (total = zero).
I'm still waiting for your detailed reply about Total Speed. :zzz:
  • #204
Hi sophiecentaur, you should get this debate and what I am getting at if you read 8, you too D.
Please could you try and answer my questions, I am not interested in a mocking match, and you not answering seems to show you are unsure.
1,
You a D. have dismissed a real World EMG test, but you cannot say why ? You seem to be against RMS way, but cannot say why ??
2,
Do you agree that a muscle that if I do 10 repetitions at 1/1 = 20 seconds, and 1 repetition at 1/1 = 2 seconds. That the 10 repetitions will use more overall muscle force, more total muscle force, longer muscle force ? If and when you and D. understand this question, you will then understand my question, as from what you and D. say, I am sure you don’t understand. As I fail faster in the faster repetitions, does that not tell you anything ?
3,
I 100 physics had a debate, and did extensive tests, and all agreed I was right, would you be able to say I was right, or are you too deep in ?
4,
Do you see where/why average force means nothing in this debate ? If you do 1 repetition at any speed, say 1/1, that’s 1 second up and 1 second down, you will get the same average force if you do 1 repetition or a 100 repetitions. So average will not tell us anything, or will it ?
Do you see what I mean ?
5,
Do you and D. think that I fail faster when doing the faster repetitions because there is less force output by the muscles, and less tension on the muscles ? If so please say and explain why you think that or other, the point is you do fail 50% faster, what both use 80% on the repetitions, thus there can ONLY be ONE reason for this, you produce for force in the same time frame doing the faster repetitions, putting more tension on the muscles, making the muscles fail faster, if you do not think this, please say why ?
6,
You use more energy in the faster, why ? As immediately you move faster, using more accelerations using more force, you use more energy, are you saying you use more energy because you don’t use more force ?
7,
You move the weight 6 times further in the same time frame, you have to use more force to move a weight further in the same time frame, if not, how do you move the weight further if by not using more force/accelerations ?
I am not ignorant to that, I know it, and I know everyone else knows it, this is not the debate.
Let me try and explain again.
8,
We are the exact same strength, we are moving 80% of our 1RM, {Repetition Maximum} We are both going to move this weight until momentary muscular failure, meaning we are going to move the weight until we cannot lift it again.
I use my 100% maximum force ALL the time, which is a 100 pounds, you on the other hand only use 80% of your force all the time.
I hit momentary muscular failure about 50% faster than you do, because I am using 100%, but you are not using 100% you are using 80% yes 80%, and using 80% consistently for the exact same time as me moving the weights, {lets cal that 30 seconds} HOW can you think or claim that you ONLY using 80% consistently for the same time frame as I using 100% consistently, will use the same overall or total force output ? Or will make the same momentum/movement change ?
1,
I use 100% force for 30 seconds.
2,
You use 80% force for 30 seconds.
3,
How can using 80% of force for 30 seconds be the same as using 100 force for 30 seconds ? Please state why.
Not sure what you mean there ? Or are getting at, as I HAVE to use force and energy on the way down, or lowering the weight as well as lifting.
I answered that, is a different quantity, but if you want I will come up with a better one, please try and answer 8, and the rest, please you too D. and anyone else here.
Wayne
  • #205
Nothing more from me until you answer my 'simple' question.
  • #206
1,
2,
3,
How can using 80% of force for 30 seconds be the same as using 100 force for 30 seconds ? Please state why.[/b]
Wayne
Everyday you prove that you don't have a clue what everybody is trying to explain to you.
YOU DON'T USE 100% FORCE FOR 30 SECONDS.
You use more force than the weight when you accelerate and less force than the weight when you decelerate.For these 30 seconds...either you lift fast or slow...the average force per second is the weight.
Stop saying nonsense like "average force means nothing in this debate".It's the same average force per second and this answers EVERYTHING everything you asked.
The effect of force over time(which is what you described as "total/overall force") is identical.
  • #207
Hi DaleSpam,
he described the "total/overall force" as the effect of force over time so the ∫f(t)dt is exactly what he means.
...and of course is the same regardless the lifting speed since the average force is the weight in any case.
  • #208
Let's be accurate about this:
∫f(t)dt (a definite integral) is the impulse (change of momentum), which varies, depending which part of the lift cycle your integration extends. There is greatest impulse during sections of the fastest repetitions because the velocity change is greatest.
I wouldn't accept some cranky alternative language from douglis or dalespam so why should I accept it from Wayne?
Some of the published stuff uses terms similar to what he uses but makes it clear that it is only over the lift part. I think Wayne is over / mis interpreting a lot of it because his terminology is so inaccurate that I don't think he can be understanding the true messages.
Funny thing is that I find little to argue with in any of the references I've looked at. Yet he seems to find a great deal of support within the same texts. They obviously steer clear of making non-physics gaffs because they are not interested in Waynes "physics approach". They clearly know the business better than he.
I can see that he reckons he works harder doing faster lifts but I can't see how he can assume that he knows what his muscles are doing whilst he's lifting. That is what the EMG tries to do - but his interpretation of those seems a bit fanciful, to be honest (and polite).
I think his posts must qualify for a record for the consistently long yet vague posts I have read on PF.
  • #209
Ah, ok. That is a defined term in physics, called impulse:
http://en.wikipedia.org/wiki/Impulse_(physics )
Edit: I see sophiecentaur already mentioned it.
I just want to point out that impulse does not have units of force, it has units of momentum. Assuming that we are talking about the impulse over one full rep then the change in momentum is 0 so the impulse on the weight is 0.
The only two forces acting on the weight are gravity and the human, so the impulse provided by the human is equal and opposite to the impulse provided by gravity. So, the impulse is equal to the weight times the duration of the rep. Therefore the human provides a larger impulse on a slow rep than on a fast rep.
waynekx8, if by "total force" you mean "impulse" then it is greater for a slow rep than for a fast rep. If you mean some other quantity then please define it explicitly.
  • #210
That's the whole point of the discussion and it's been explained to Wayne many times.
Regardless if you lift the weight fast or slow for 30 seconds...the "total/overall" force is always the same and equal with gravity's impulse for that duration.
  • · Replies 28 ·
  • · Replies 69 ·
10K
  • · Replies 30 ·
  • · Replies 35 ·
  • · Replies 16 ·
12K
