College Physics Problem Capacitor / Inductor
The discussion revolves around a physics problem involving a capacitor and an inductor. The capacitor has a capacitance of 10.0 microfarads and is charged to 170 microcoulombs before being connected to a 4.00 mH inductor. Participants are exploring various aspects of the energy transfer and oscillation between the two components.
  • Participants discuss the conservation of energy in the system, considering how energy is stored in both the capacitor and the inductor. Questions arise regarding the calculations for maximum current, voltage, and energy stored in the components. Some participants attempt to derive formulas and values for different parts of the problem, while others question the validity of these approaches.
The discussion is ongoing, with some participants providing insights into the energy dynamics of the circuit. There is a recognition that the problem involves oscillations between the capacitor and inductor, and guidance has been offered regarding the energy perspective. However, there is no explicit consensus on the correctness of the calculations presented.
Participants are navigating the complexities of transient analysis versus steady-state conditions, and there are indications of confusion regarding the application of formulas and the interpretation of instantaneous values in the context of the problem.
aamartineng17
A 10.0 Microfarad Capacitor is charged to 170 Micro Coulombs then connected across the ends of a 4.00mH inductor.
(a) Find the maximum current in the inductor.
(b) At the instant the current in the inductor is maximum. How much charge is on the capacitor parallel plates?
(c) Find the maximum potential across the capacitor.
(d) At the instant the potential across the capacitor is maximum. What is the current in the inductor?
(e) Find the maximum energy stored in the inductor.
(f) At the instance the energy stored in the inductor is maximum. what is the current in the circuit?
I am really stuck on calculating this physics problem, especially part a. Could someone please give me some assistance in calculating this Physics Problem. I really appreciate your help. Thanks
Hi aamartineng17, Welcome to Physics Forums.
These kinds of problems are often easier if you think in terms of conservation laws. Here there are two energy storage devices (a Capacitor and an Inductor) which are going to trade energy back and forth. The result is oscillations of current and voltage.
When the circuit begins operation, only the capacitor has any energy stored since it has an initial voltage; There's no current flowing so the inductor has no stored energy.
What do you know about energy for these devices? Do you have formulas?
Hello Everyone,
For the Following Physics Problem listed below:
I tried solving the problem, here were my results:
(Part a)
*Note: That the charged Capacitor is connected across an inductor.
The Equation for the voltage of a capacitor is the following: V = Q / C
For this problem Q = 1.7 x 10^-4 C, C = 1 x 10^-5 F
I calculated the Voltage of Capacitor to be:
V = Q / C = 1.7 x 10^-4 C / 1 x 10^-5 F = 17 Volts
I know that since the Capacitor is connected across the inductor I know that the inductor will then have a potential difference of 17 Volts.
**Note: At the instant when the charge on the capacitor reaches zero, Q = 0, the current in the Inductor has reached its max value, but at this instant the current in the Inductor is not changing, [-L (Delta I / Delta t) = Q / C = 0). At this moment, the magnetic field B in the inductor is also a maximum.
*** Note: I then calculated the Resonance Frequency using the following equation:
f = fo = (1 / 2* pie) * sqrt (1 / L * C)
f = fo = (1 / 2 * pie) * sqrt ( 1 / (4 x 10^-2 H) * (1.7 x 10^-4 C)
f = fo = 193 Hz
I then used the following equation
XL = 2 * pie*f* L = 4.851 ohms (the reactance for inductor)
I then used the Equation V = I * XL , to calculate the max current in inductor:
I = V / XL = 17 V / 4.851 ohms = 3.50 A (Calculated Max Current of Inductor)
I would really appreciate it if someone could please tell me if this is the correct way to solve (Part A) of this problem. Thanks Again for your time and help. I really appreciate and value your time and help!
When the charge reaches zero on the capacitor and the inductor has its maximum current, the voltage across the capacitor (and thus the inductor, too) will be zero. So your solution method for the current doesn't look right. (Also, it implies a steady-state AC situation, and you're looking for an instantaneous value in a transient situation).
Also, you appear to have plugged in the charge on the capacitor rather than the capacitance in your workings for the resonance frequency.
I might suggest that you look at it from an energy point of view. Capacitors store energy in electric fields, so their maximum energy stored corresponds to when they have a maximum potential difference across them. Inductors store energy in magnetic fields, and have maximal energy stored when their currents are maximum...
  • · Replies 16 ·
9K
  • · Replies 18 ·
10K
