# of elecron/sec in a 3 bulb circuit
  • Thread starter Thread starter iknowless
    Bulb Circuit
The discussion revolves around a circuit involving two types of bulbs connected in series with batteries, focusing on the flow of electrons per second through different bulb configurations. The participants explore the relationship between electric field, current, and the physical properties of the bulbs.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of Kirchhoff's rules and the relationship between current and electric field in the context of the circuit. There are attempts to derive relationships between the currents and areas of the bulbs, as well as questions about the role of resistance and Ohm's law in the analysis.
Some participants have offered insights into the relationships between the electric fields and currents in the circuit. There is an ongoing exploration of the implications of these relationships, with no explicit consensus reached on the best approach to solve the problem.
Participants note that they have not yet covered resistance or Ohm's law in their studies, which influences their approach to the problem. There is also mention of potential errors in the equations being used, indicating a need for careful consideration of the circuit's configuration.
iknowless
When a single round bulb of a particular kind and two batteries are connected in series, 5* 10^18 electrons pass through the bulb every second. When a single long bulb of a particular kind and two batteries are connected in series, only 2.5*10^18 electrons pass through the bulb every second, because the filament has a smaller cross section.Figure 18.68
In the circuit shown in Figure 18.68, how many electrons per second flow through the long bulb?
E is the electric field in the filament
A is the cross-sectional area of the filament
i is electron current
l is the length of the filament
n is the # of electrons per unit volume (unknown)
u is the electron mobility (unknown)
Circuit 1 is the main circuit, with long bulb A, and two identical round bulbs, both labeled B.
Circuit 2 is the circuit with 1 long bulb, C.
Circuit 3 is the circuit with 1 round bulb, D
[tex]i_1=nA_auE_a=n2A_buE_b[/tex]
[tex]i_2=nA_auE_c=2.5e18[/tex]
[tex]i_3=nA_buE_d=5e18[/tex]
[tex]2emf=l(E_a+2E_b)=E_c l=E_d l[/tex]
note: [itex]A_b>A_a[/itex]
[tex]E_c=E_d[/tex]
I am assuming that all the filaments have a length 'l.'
I have created fractions of current to produce some hopefully useful formulae.
From [itex]i_1[/itex], [itex]A_a E_a=2A_b E_b[/itex]
From [itex]\frac{i_1}{i_2}[/itex], [itex]E_a i_2 =2 E_b i_3[/itex]
Also, [itex]i_1=\frac{E_a i_2}{E_c}=\frac{2 E_b i_3}{E_c}[/itex]
And [itex]\frac{i_2}{i_3} = \frac{A_a}{A_b}[/itex]
[tex]E_a+2E_b=2E_b+E_b \frac{i_3}{i_2}=E_c[/tex]
Please just give me a nudge in the right direction. Thanks!
Isn't it just about voltage, current and combining resistances?
We haven't talked about resistance or Ohm's law yet. We can only use Kirchhoff's node rule,
"In the steady state, the electron current entering a node in a circuit is equal to the electron current leaving the node."
We can also use "i=nAuE" and the Loop Rule, where voltage around a closed path is zero in a circuit.
Is there an easier way to do it with resistance? Please help, but I would also like to know how to do it without Ohm's Law.
Wow, how did I not see it? In formula 4
Then [itex]A_b=2A_a[/itex] !
So now formula 1 can be written as [itex]E_a=4E_b[/itex]
There is an error in the 4th relevant equation. It should be [itex]2emf=l(E_a+E_b)=lE_c[/itex] because the closed path only travels through 1 round bulb, not 2.
and the rest is algebra
20K
