Difference between force and energy.
The discussion explores the differences between force and energy, particularly in the context of electromagnetism. Participants examine the definitions and relationships between these concepts, as well as the implications for phenomena like photons.
  • One participant questions the concept of energy as merely the "ability to do anything" and seeks clarification on why electromagnetism is sometimes referred to as energy.
  • Another participant explains that electromagnetism involves momentum, force, energy, space, and time, emphasizing that energy and force have specific meanings and relationships.
  • A detailed explanation is provided regarding how force relates to energy, including the mathematical relationship between force, distance, and kinetic energy.
  • The distinction between scalar energy and vector force is highlighted, noting that energy does not have direction while force does.
  • Momentum is introduced as a related concept, with its dependence on velocity and its role in the relationship between kinetic energy and changes in velocity.
  • A participant expresses confusion about the momentum of photons, questioning how a massless particle can have momentum and energy related to its wavelength and frequency.
  • Another participant responds by clarifying that a photon's energy and momentum are not determined by mass, suggesting that it is due to its nature as an electromagnetic wave.
The discussion contains multiple viewpoints and some confusion regarding the relationship between mass, momentum, and energy, particularly in the case of photons. No consensus is reached on these points.
Participants reference specific formulas and concepts, but there are unresolved questions about the implications of these relationships, particularly concerning massless particles and their properties.
suchal
I guess my tittle is self explanatory, but I see energy's concept of relativity not of "ability to do anything".
if electromagnetism a force, then why some people say it is energy?
Electromagnetism is a phenomenon. It involves momentum, force, energy, space and time. Energy and force have very specific meanings.
In most general terms when a system can move or change (translate through space, rotate, deform, etc.) A force relates the amount of energy expended (or gained) when one moves the system a given (small) distance. If you push on an object with a certain force [itex]F[/itex] over a certain distance [itex]\Delta x[/itex] the object gains Kinetic energy by the amount [itex]F\cdot \Delta x[/itex]. Note direction and +/- signs matter here. Throw a rock up (positive direction) and the downward (negative) force is opposite the upward motion so it gains negative kinetic energy (looses kinetic energy) and slows.
If you can move an object in many directions it is easier to express the components of force in each direction as a single vector force with direction and magnitude. This vector will point in the direction in which the object gains the most energy for a given amount of motion and the magnitude corresponds to the energy per distance in that direction.
Note that while force can have a direction, energy does not. Energy is a scalar while force is a vector quantity.
Another important quantity is momentum. Momentum relates a (small) change in kinetic energy to a small change in velocity when considering a system changing position over time. Now momentum itself depends on velocity so you'll see a factor of 1/2 in formulas for kinetic energy.
[itex]KE = \frac{1}{2} m v^2=\frac{1}{2}pv[/itex], where [itex]p = mv[/itex]
[itex]\Delta KE = \frac{1}{2}\Delta p \cdot v + \frac{1}{2}p\cdot \Delta v = \frac{1}{2}(2 m v \Delta v) = p\Delta v[/itex]
(here the [itex]\Delta[/itex] symbol means "change in").
Note that again momentum is a vector quantity as is velocity.
This gives another interpretation of a force as the rate of change of momentum of an object. When momentum is velocity times (a constant) mass you get Newton's F = ma where a is the acceleration (rate of change of velocity).
We can generalize these to rotary motion and speak of rotary force (torque) as the amount of work done per angle we turn an object and the rotary momentum (angular momentum) as the rate of change in kinetic energy as we change speed of rotation.
thank you very much. I got it. Just one confusion is there, when p=mv2 then why a photon for which m=0 has p>0 and it's E==KE but depends on it's wavelength and frequency?
The photon's energy and momentum are not determined by it's mass. Instead see here for how to determine the photons energy and momentum: http://en.wikipedia.org/wiki/Photon#Physical_properties
As for the why, I believe it is because it is an electromagnetic wave, not a particle with mass.
  • · Replies 55 ·
  • · Replies 54 ·
