Effects of propylene glycol on heat transfer efficiency
The discussion focuses on the impact of propylene glycol on heat transfer efficiency compared to water, which is considered to have a heat transfer efficiency of 100%. Participants seek reliable data points to formulate an equation that quantifies the heat loss associated with varying concentrations of propylene glycol in heat transfer fluids. Key resources, including a link to Dow's thermal conductivity data for aqueous solutions, are shared to aid in understanding the thermal properties of propylene glycol solutions.
  • Understanding of heat transfer principles
  • Familiarity with thermal conductivity concepts
  • Knowledge of propylene glycol properties
  • Basic skills in data analysis and equation formulation
  • Research the thermal conductivity of propylene glycol solutions using the provided Dow resource
  • Explore the effects of different concentrations of propylene glycol on heat transfer efficiency
  • Learn about the calculation methods for heat loss in fluid systems
  • Investigate alternative heat transfer fluids and their efficiencies
Engineers, thermal system designers, and researchers involved in fluid dynamics and heat transfer applications will benefit from this discussion.
MrDieselT
I'm trying to calculate the heat loss of efficiency due to increasing the mixture of propylene glycol in a heat transfer fluid compared to water.. For this I'm saying that water has a heat transfer efficiency of 100% (relative only)
Im looking for multiple data points to create an equation not just random numbers.
  • · Replies 34 ·
  • · Replies 40 ·
