About home made air conditioner
Homemade air conditioners using ice boxes can effectively cool air, but the fan will generate some heat during operation, which is typically negligible. The ice will melt as it absorbs heat from the ambient air, resulting in cooler air being blown out, but the duration of cooling depends on factors like room temperature and airflow. A homemade setup may not provide the same humidity control and filtration as a traditional air conditioner, which are essential for effective air conditioning. Instead, this DIY project is more akin to creating an air chiller, which is simpler to achieve. Proper wiring and airflow management are crucial to prevent overheating and ensure safety.
de$per@do
I am making homemade ac.
I am using an ice box for it. I found the link on the internet
http://www.instructables.com/id/Cheap-DIY-Air-Conditioner/
I want to ask is
1. The fan which is used must get heated by the operation
2. This will produce a lot of heat
3. This will melt the ice or take heat from bottles used at very large rate
4. How long will it sustain?
thank you
I'm not sure what you're asking.
1) The fan will heat because it will be running but it's negligible and it definitely won't overheat because fans are built to spin and it's drawing cool air through it. This is assuming the wiring and power supply are correct. Wire it wrong and you will have a fire hazard.
2) ?
3) The ice will melt because you are drawing ambient temperature air over it. Some energy from hot air is transferred to the chilled bottles and you get slightly cooler air blowing out.
4) It's hard to say without empirical data. Depends on room temperature and the flow through the box. A few hours?
What exactly are you trying to build ? - A full-scale air-conditioner ? - Or a machine to cool the air in your apartment down ? - The two devices are not quite the same.
An air conditioner controls the humidity and temperature, and ideally, removes smells from the air by filtration. Normally, a domestic air-con fails on the latter. An air-con in a vehicle can filter the air through a carbon filter.
You can air-condition the air and WARM it. Air-con and chilling are not the same thing.
An air CHILLER will be much easier to achieve and I suspect this is what you are actually after.
On the subject of your fan, if you don't impede the flow of air through it, it won't overheat.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
