Charges moving parallel to magnetic fields and direction of magnetic force
Moving a charge parallel to a magnetic field results in zero magnetic force due to the properties of the cross product in the magnetic force equation F = qv x B. This phenomenon is supported by experimental data rather than purely theoretical constructs. Additionally, the direction of magnetic forces for opposite charges of equal magnitude is influenced by the electric fields generated by these charges, with positive charges exhibiting isotropic properties while negative charges direct towards the negative charge. The discussion highlights the relationship between velocity-dependent forces and relativity, particularly in the context of Newtonian physics.
  • Understanding of the magnetic force equation F = qv x B
  • Basic knowledge of electric fields and charge interactions
  • Familiarity with concepts of relativity in physics
  • Ability to interpret vector cross products
  • Study the implications of the Lorentz force law in electromagnetic theory
  • Explore the relationship between electric fields and magnetic fields in electromagnetism
  • Investigate the principles of Newtonian relativity and its applications in physics
  • Learn about the behavior of charged particles in different reference frames
Physics students, educators, and anyone interested in understanding the fundamental principles of electromagnetism and the behavior of charged particles in magnetic fields.
nateja
I hope this isn't in the wrong forum, it's not a problem, just a conceptual question for physics 2.
I have a few questions that I cannot find answer for in my physics book or online.
1) Why does moving a charge parallel to the magnetic field result in zero magnetic force?
Is this quality based on experimental data like the magnetic force equation (something that the book mentions: says the mag-force equation was not developed theoretically, but experimentally)? F = qv x B. I know that due to the cross product, the force will just be 0, but is there another explanation besides just the math?
Why do opposite charges of equal magnitude result in different directions of magnetic forces? Is this a property of the electric fields from the oppositely charged masses (positive are isotropic and negative all point toward the negative charge)?
hi nateja! :smile:
nateja said:
1) Why does moving a charge parallel to the magnetic field result in zero magnetic force? … I know that due to the cross product, the force will just be 0, but is there another explanation besides just the math?
here's a conceptual answer …
a velocity-dependent force is an inevitable consequence of relativity (good old-fashioned Newtonian relativity, not the einsteinian sort) …
imagine a stationary line of negative charge, and a negatively-charged particle moving perpendicularly towards it
obviously, it is repelled, so it slows down, is momentarily stationary, then speeds up again, moving away, all on the same perpendicular line
now look at it from a frame of reference in which the line is moving along itself at speed v …
what happens to the moving charge? :wink:
Thanks! my professor explained this in class with the same frame of reference example. Pretty cool stuff!
  • · Replies 17 ·
  • · Replies 27 ·
