Required to prove that ∫f(x)dx[b, a] =∫f(x−c)dx [b+c, a+c]
  • Thread starter Thread starter jodecy
The discussion revolves around proving the equality of two definite integrals involving a function f and a constant shift c. The original poster presents a statement requiring proof that the integral of f over the interval [b, a] is equal to the integral of f shifted by c over the interval [b+c, a+c].
  • Exploratory, Assumption checking
  • The original poster attempts to demonstrate the equality using the properties of antiderivatives and definite integrals. Some participants question the validity of assuming that the antiderivative of f(x-c) is simply F(x-c) without further justification. Others suggest that this assumption needs to be proven, particularly by applying the chain rule and considering a substitution.
The discussion is ongoing, with participants exploring the assumptions made regarding the antiderivative and the implications of the chain rule. There is no explicit consensus yet, but guidance has been offered regarding the need for a proof of the assumption made by the original poster.
Participants note that the original poster's formatting may hinder readability for some users, which could affect engagement in the discussion.
jodecy
required to prove that
where f is a real valued function integrable over the interval [a, b]
∫() [b, a]=()−()
right i placed the interval in the [] brackets
is this correct?
You just assumed that the antiderivative of f(x-c) is F(x-c). Why is that true?
i believe it was given in a lecture i had so i assumed is that a wrong assumption?
It's not a wrong assumption. It just needs to be proved. If F'(x)=f(x), why is F'(x-c)=f(x-c)? It's easy, but you should say why. Use the chain rule. In other language, they may expect you to prove this using the substitution u=x-c. Why is dx=du?
You are probably not aware, but the way you posted makes your post unreadable to at least XP Windows users using Chrome, IE & Opera, attachment shows what they see. It looks little bit better under Vista, but is still barely readable.
I have corrected thread subject.
  • · Replies 26 ·
