Water Flow, Mass Flow through 5 Gallon Jug
The discussion focuses on calculating the minimum mass flow rate for a water system using a 5-gallon jug, aiming for a flow rate between 1 GPM and 4 GPM. The user calculated the velocity of water at atmospheric pressure to be 122.95 inches/sec, translating to 614.7 ft/min. Using the equation Q=VA, the required cross-sectional area was determined to be approximately 0.03024 in², leading to a minimum inner diameter of 0.19622 inches for the outlet. The user also noted that variations in water height would affect mass flow, suggesting the need for a differential equation (DE) to model the system accurately.
  • Understanding of fluid dynamics principles, specifically flow rate calculations.
  • Familiarity with the equation of continuity (Q=VA) in fluid mechanics.
  • Basic knowledge of unit conversions between imperial and SI units.
  • Ability to apply differential equations to varying flow scenarios.
  • Research "Fluid Dynamics and Flow Rate Calculations" for deeper insights into flow behavior.
  • Learn about "Differential Equations in Fluid Mechanics" to model varying mass flow rates.
  • Explore "Unit Conversion Techniques" for seamless transitions between measurement systems.
  • Investigate "Bernoulli's Principle" to understand pressure and velocity relationships in fluid flow.
Engineers, fluid dynamics students, and anyone involved in designing water flow systems or optimizing fluid transport in practical applications.
bhaarat316
Here is the run down first, I'm trying to find a min mass flow rate for my project which needs to be 1 GPM, and max 4 GPM. Now water is going out of a 5 gallon jug, that has the top cut off, and the water is flowing into a PVC pipe. The area is already set at 1.5 inches, which I know is to big. I need to find the velocity of water at atm pressure, and then the diameter of the circle which the water will funnel through. I did some work I just need help making sure I did it right, basically a check over. think of it as a Deer Park 5 gallon bottle, like the ones for water dispenser, but the top cut off, and it flowing out the nozzle.
Man how do I use the Latex thing?
So, I know V=[itex]\sqrt{2*19.5 inches * 387.6 inches/s^{2}}[/itex]
V=122.95 inches/sec, 10.245 ft/s = 614.7 ft/min
Now the simple equation of Q=VA
1 GPM->.13[itex]ft^{3}[/itex]/min = 614.7ft/min * A
.03024 in^2 = A(min)
sqrt(.03024/∏)= r(min) = .09811 inches
We would have to reduce our inner diameter to .19622 inches.
Now is this right? I can't believe that? I was initial thinking it would be a DE since our mass flow would be varying, depending the height of the water, gravity would be pushing it through the main system.
A sketch would help to understand your calculations.
In addition, SI units would make unit conversions much easier.
Based on your description of your system, I think this is true. Probably your 19.5 inches would vary.
gravity will force the water through the tank and I need to figure out what the diameter will be, to get 1 gpm.
  • · Replies 17 ·
  • · Replies 32 ·
14K
  • · Replies 19 ·
12K
