Magnetic field at center of half square
The discussion focuses on calculating the magnetic field at the center of a half square configuration created by a straight wire using the formula B = (μ/4∏)(I/R)(sinθ2 - sinθ1). The user initially struggles with determining the correct angles for the calculation, mistakenly considering angles of 45° and 135° for the top side. A participant clarifies that the correct angles should be ±45°, with the closest point angle being 0°. They recommend applying the Biot-Savart law for accurate results, referencing a specific formula from a physics resource.
  • Understanding of the Biot-Savart law
  • Familiarity with magnetic field calculations
  • Knowledge of trigonometric functions and angles
  • Basic concepts of electromagnetism
  • Review the Biot-Savart law in detail
  • Practice magnetic field calculations for different wire configurations
  • Explore the derivation of the magnetic field formula for straight wires
  • Study the impact of angle selection on magnetic field strength
Students and professionals in physics, electrical engineering, and anyone interested in understanding magnetic field calculations related to current-carrying wires.
HelpMeh
Hi, I am having some trouble understanding the formula for the magnetic field for a straight wire.
The equation is:
the picture looks like this:
...___
__| . |____
with the current coming in from the left. To find the magnetic field at the point (middle) You need two angle, which is where the issue comes up. I am not sure which two angles to use.
What i know:
im pretty sure to find the magnetic field generated by the vertical sides you would sweep out an angle from 0 to 45° (from bottom of the side to the top). then multiply by 2 since both sides will create the same B field, i have no idea what to use for the top side, possibly angle 1 being 45 and angle 2 being 135, but you get zero if this is done.any help is appreciated.
Hi HelpMeh! :smile:
The equation is:
You're using the wrong θ :redface:
θ for the closest point is 0, not 90° …
so your angles will be ±45° …
(and for an infinitely long wire would be ±90°)
i suggest you check this by applying the Biot-Savart law. :wink:
  • · Replies 28 ·
  • · Replies 16 ·
