Quick question about interpretation of contravariant and covariant components
The discussion revolves around the interpretation of contravariant and covariant components of vectors, exploring their definitions, relationships, and mathematical representations. Participants examine these concepts in the context of tensors and coordinate systems, with a focus on the implications of using different bases and matrices.
  • One participant proposes that covariant components can be viewed as a vector multiplied by a matrix of linearly independent vectors, while contravariant components are the vector multiplied by the inverse of that matrix.
  • Another participant interprets the discussion in terms of the metric tensor, suggesting that covariant and contravariant components relate to the metric from different perspectives (A to B and B to A).
  • A later reply introduces the concept of mixed tensors and suggests that all tensors should have a matrix expansion through tensor product decomposition, which may involve an invertible matrix.
  • One participant notes that the definitions of contravariant and covariant components can vary and emphasizes the role of the Jacobian in defining these components in the context of tensors.
  • Another participant explains that when coordinate systems have perpendicular axes, the covariant and contravariant components are equivalent, but this equivalence does not hold in general cases.
Participants express differing interpretations of the relationships between covariant and contravariant components, particularly regarding the use of matrices and the role of the Jacobian. There is no consensus on a single interpretation, and multiple competing views remain present in the discussion.
Participants reference various mathematical constructs, such as the metric tensor and Jacobian matrices, but the discussion does not resolve the implications of these constructs on the definitions of vector components. The relationship between different bases and their effects on component representation remains an open question.
enfield
Can the covariant components of a vector, v, be thought of as v multiplied by a matrix of linearly independent vectors that span the vector space, and the contravariant components of the same vector, v, the vector v multiplied by the *inverse* of that same matrix?
thinking about it like that makes it easy to see why the covariant and contravariant components are equal when the basis is the normalized mutually orthogonal one, for example, because then the matrix is just the identity one, which is its own inverse.
that's what the definitions i read seem to imply.
Thanks!
Thanks!
Hey enfield.
At first I didn't get what you were getting at but I think I do now.
The way I interpret what you said is to think about the metric tensor and its conjugate. The metric tensor written in gij vs gij represents the metric from A to B vs B to A and in this context if we look at covariant vs contravariant then under this interpretation all we are doing is from A to B in one and from B to A in another.
But then I tried to think about the situation when you have a mixed tensor. In the metric situation it makes sense like you have alluded to with matrices but for the mixed tensor, my guess if all tensors are multilinear objects, then they should have a matrix expansion through finding the tensor product decomposition and then subsequently getting the matrix form of the multilinear representation which like other matrices, has a basis and if invertible has an inverse map.
I'd be interested to hear your reply on this if you don't mind.
thanks for the thoughtful response!
okay, i hadn't read about tensors yet when i posted this - just the definitions of contra- and co-variant vector components. now i have a bit though.
As I understand them, the contra- and co-variant components of a vector can be defined in many ways (as the result of multiplying any invertible matrix with the right dimensions by the vector). But with tensors, the matrix that is used to define the components is exclusively the Jacobian.
this pdf has an accessible section near the start on "Jacobian matrices and metric tensors": http://medlem.spray.se/gorgelo/tensors.pdf.
So using the Jacobian to define them you might have [tex]A_v = Jv[/tex] and [tex]B_v=J^{-1}v[/tex] (A would be the co-variant components of v here i think because they co-vary with the Jacobian), and then the the metric tensor could be interpreted as J^2 or the inverse of that, depending on which way you were relating the components, which is obviously the matrix that would relate A and B to each other.
Yes, if your coordinate system has perpendicular straight lines as coordinate lines "covariant" and "contravariant" components are the same.
Another way of looking at is is this. To identify a point in a coordinate system, we can drop perpendiculars from the point to each of the coordiate axes, then measure the distance from the foot of the perpendicular to the origin. Another way is, again, drop perpendiculars from the point to each of the coordinate axes and this time measure the distance, along that perpendicular, from the point to the foot of the perpendicular. As long as the coordinate axes are perpendicular straight lines, those are the same. But other wise, the first gives the "contravariant components" and the second the "covariant components".
  • · Replies 22 ·
  • · Replies 24 ·
9K
  • · Replies 23 ·
