Love's equivalence principle for a perfect electric conductor
The discussion revolves around Love's equivalence principle as it pertains to perfect electric conductors, specifically in the context of electromagnetic field theory and antenna design. Participants explore the implications of the principle on electric current density and potential differences in conductors.
  • One participant seeks clarification on why the electric current density Js is considered short-circuited on the surface of a perfect electric conductor.
  • Another participant explains that the tangential component of the current density generates no potential difference on a perfect conductor.
  • A participant questions how to compute the potential difference, specifically asking for the second point of reference and the reasoning behind it being null.
  • A later reply discusses the modeling of far field radiation using equivalence methods, emphasizing that tangential electric fields do not contribute to radiation and thus simplify calculations.
  • One participant expresses a preference for equivalence methods in theoretical physics but critiques their application in antenna design due to assumptions about perfect conductors.
  • Additional resources are suggested for further reading on the topic.
Participants express varying levels of understanding and interpretation of Love's equivalence principle, with no consensus reached on the implications for practical applications in antenna design.
Participants note limitations in the assumptions made regarding perfect conductors and the challenges in transitioning to real-world scenarios involving resistive materials.
eliotsbowe
Hello, I'm having some issues with Love's equivalence principle.
I'm studying Balanis' "Antenna theory" (1997), here's a (legal) fragment of the section in question:
http://www.uniroma2.it/didattica/ap1/deposito/02_2-Balanis-Equivalence_Theorems.pdf
I'm trying to understand the following statement (page 331, figure 7-8 b):
"The electric current density Js, which is tangent to the surface S, is short-circuited by the electric conductor."
May someone explain the reason for Js to be considered short-circuited on the surface of the perfect electric conductor?
Thanks in advance.
The tangential component tries to flow along the surface of the conductor so is 'short circuited' ie on a perfect conductor it generates no potential difference.
What points should I pick to compute that potential difference? I mean, one is on the surface S, but what's the second one? Besides, why is that potential difference null?
Thanks
OK don’t get blocked by this, don't fear it. It is just a technique to solve a generalised situation in EM field theory.
So what you are trying to do is to model the far field radiation of a complicated system of currents and EM fields by replacing them with a simpler system which gives the same radiation far from the source.
The integrals involved often can't be solved in closed form.
The raison d’etre of Love et al is to replace the system with a perfectly conducting surface and an EM field. Any electric fields along (tangential) to the surface vanish as they can't generate any current so can't radiate so their contribution is zero hence reducing the number of integrations. Any normal to the surface do contribute and must be calculated.
You start with the electric field and compute the current density and if you have chosen you surface well elements of the current density don't contribute.
I will also 'nail my colours to the mast' by saying I am a big fan of using equivalence methods in theoretical physics as they often reveal beautiful symmetries and give real insight but I am not a big fan of their use in areas such as antennae design because they assume things such as a perfect conductor (i.e. one which will kill any electric current on the surface) or worse a surface which will kill any magnetic field on the surface. Thus to transition to the real world (conductors with resistance etc.) takes as much work as solving the problem directly.
You may find chapters 5 & 6 of http://www.plasma.uu.se/CED/Book/EMFT_Book.pdf a better text
for the more practical approach, if that suits you, try the IEEE Antennas and Propagation Mag report reproduced at http://www.csun.edu/~hceen002/paper1.pdf
Hope this helps
Regards
Sam
That was helpful, thanks a lot!
  • · Replies 46 ·
  • Poll Poll
