Is the Degree of Q(a) Over Q Correctly Understood?
  • Context: Graduate
  • Thread starter Thread starter Ad123q
    Degree Fields
The degree of the field extension Q(a) over Q, where a = e^(2πi/5), is correctly determined to be 4, not 5. The basis for Q(a) as a vector space over Q consists of {1, a, a^2, a^3}, confirming that the minimal polynomial x^4 + x^3 + x^2 + x + 1 has a degree of 4. The Euler's totient function φ(5) also supports this conclusion, indicating that the dimension of the extension is indeed 4.
  • Understanding of field extensions in algebra
  • Familiarity with minimal polynomials
  • Knowledge of the Euler's totient function
  • Basic concepts of vector spaces over fields
  • Study the properties of minimal polynomials in field theory
  • Learn about the Euler's totient function and its applications in algebra
  • Explore vector spaces and their bases in the context of field extensions
  • Investigate cyclotomic fields and their significance in number theory
Mathematicians, algebra students, and anyone studying field theory and polynomial equations will benefit from this discussion.
Ad123q
I'm not sure if my reasoning below is correct or not.
If a=e[itex]\stackrel{\underline{2πi}}{5}[/itex], then Q(a) = {r + sa + ta2 + ua3 +va4 : r,s,t,u,v [itex]\in[/itex] Q} . [Is this correct?]
Then [Q(a):Q] = 5 as {1, a, a2, a3, a4} form a basis for Q(a) as a vector space over Q.
However I am not sure if my reasoning above is correct as I have just seen a proof that [Q(a):Q] = 4 for the same a above.
Thanks for your help.
*** No, because [itex]\deg_{\mathbb Q}\mathbb Q(a)=\phi(5)=4[/itex] , so any basis has only 4 elements and not 5, as you wrote.
The minimal pol. of [itex]a[/itex] over the rationals is [itex]x^4+x^3+x^2+x+1[/itex] .
DonAntonio
  • · Replies 0 ·
  • · Replies 28 ·
