Regarding Heat Transfer and Heat Exchangers
This discussion focuses on heat transfer dynamics involving a cubic block suspended in stagnant air and the behavior of fluids in heat exchangers. It concludes that the rate of heat transfer from the top surface of the block is greater than from the bottom surface due to natural convection effects. Additionally, it confirms that in a counterflow heat exchanger, the exit temperature of the cold fluid can exceed that of the hot fluid, provided the log mean temperature difference (LMTD) is calculated correctly by subtracting the appropriate temperatures.
  • Understanding of heat transfer mechanisms: conduction, convection, and radiation
  • Knowledge of heat exchanger types, specifically counterflow and cocurrent configurations
  • Familiarity with the concept of log mean temperature difference (LMTD)
  • Basic principles of fluid dynamics in thermal systems
  • Study the principles of natural convection and its effects on heat transfer rates
  • Learn about the calculations involved in log mean temperature difference (LMTD) for heat exchangers
  • Explore the differences between cocurrent and counterflow heat exchangers
  • Investigate the impact of stagnant air on heat transfer and the formation of air currents
Engineers, thermal system designers, and students studying heat transfer and fluid dynamics will benefit from this discussion, particularly those involved in the design and analysis of heat exchangers.
AthlonFX
Hi folks,
Just a few general questions I have here.
1) The situation: A cubic block is taken from an oven and suspended so that both its top and bottom surfaces are exposed to the room air.
Would the rate of heat transfer from the top surface be greater, equal to, or less than the rate of transfer from the bottom surface? Why?
2) Is it possible for the exit temperature of the cold fluid to be greater than the exit temperature of the hot fluid in a heat exchanger? (simple scenario, let's assume it's a 1-1, and that both fluids are single phase fluids)
For 1) it's stagnant air, there is no movement of air. Of course, the only thing I could think of was that the top surface > bottom surface, due to natural convection. I'm just not sure if the same principle would apply on the bottom surface.
For 2) I didn't think it was possible if it was a cocurrent heat exchanger, since the log mean temperature difference would be undefinable. It could be applicable in a countercurrent heat exchanger though.
What are your thoughts?
The mechanisms are radiation, convection, and conduction. It sounds like conduction is zero. Radiation should depend on the temperatures of what the block is facing. The floor, ceiling and so on. Convection is complicated. You say stagnant air, but the block itself will heat the air and cause air currents. Bottom line, I don't know.
Yes, in a counter flow heat exchanger. LMTD can be calculated but you must be careful to subtract temperatures at the left/right sides, not the in/out temps.
  • · Replies 34 ·
  • · Replies 34 ·
