What is the way to determine the current in DC circuit with R,L,C
The discussion focuses on determining the initial current in a DC circuit containing a resistor (R), inductor (L), and capacitor (C) connected in parallel to a constant electromotive force (emf). When the switch is closed, the voltage across L and C remains equal, but the initial current is not simply E/R due to the presence of the uncharged capacitor acting as a short circuit. The initial current through the resistor and capacitor is E/R, while the inductor's current remains zero immediately after the switch is closed, preventing any sudden changes in current that would generate infinite back EMF. Ultimately, the circuit will oscillate before settling to a steady state current of E/(R + R').
  • Understanding of DC circuit theory
  • Familiarity with the behavior of resistors, inductors, and capacitors in parallel
  • Knowledge of electromotive force (emf) and its application in circuits
  • Concept of back EMF and its implications in inductive circuits
  • Study the transient response of RLC circuits using differential equations
  • Learn about the concept of back EMF in inductors and its effects on circuit behavior
  • Explore the oscillatory behavior of LC circuits and damping effects due to resistance
  • Investigate the use of simulation tools like LTspice for analyzing RLC circuits
Electrical engineers, physics students, and anyone interested in understanding the dynamics of RLC circuits and their transient responses.
tsw99
If I have a constant emf, then connect it to a resistor and an inductor and capacitor in parallel.
At the time when the switch is closed (I haven't drawn it), the voltage across L and across C should be the same since they are in parallel(?) (in fact it should be in any time later)
But there will be an induced emf across L, so the voltage across C should not be zero (but there is no charge on C! By V=Q/C, the voltage should be zero!).
So the initial current should not be E/R right? But from textbook, an uncharged cap should act as a short circuit, so no current passes through L. So what is the way to determine the initial current? (I believe the final current should be E/R because the fully charged cap acts as a open circuit)
I hope you understand what I am asking about.
I agree withe your expression for the final current, the inductance acts a short circuit.
at switch on. Think that L and C will oscillate and eventually setle to your final values
For a physically sensible solution, you can't have a sudden jump in the current through the inductor, because that would generate an "infiinite" back EMF.
So immediately after you close the switch, the current through L must be the same as it was before, i.e. zero. Therefore you have an RC circuit connected to the battery, the initial current through R and C will be E/R, and the initial voltage across the capacitor (and the inductor) will be 0.
The same logic applies if you open the switch again. The current through L can't instantly change its value. Since no current will be flowing in R, for an ideal inductor and capacitor the current in the LC circuit would continue to oscillate for ever.
Of course that would not happen with real components, because there would always be some resistance R' in series with L. In that case, the initial oscillations would decay and leave a steady current of E/(R+ R') flowing through the resistor and the inductor.
9K
  • · Replies 22 ·
  • · Replies 17 ·
