Confusion: computation of class number of K=Q(sqrt(30))
The discussion revolves around the computation of the class number of the number field K = \mathbb{Q}(\sqrt{30}). Participants explore the implications of the Minkowski bound and the behavior of prime ideals dividing 2, 3, and 5 within this context. The conversation includes technical reasoning and challenges related to the properties of ideal classes.
  • One participant states that the prime ideals dividing 2, 3, and 5 are given by (2) = \mathfrak{p}^2_2, (3) = \mathfrak{p}^2_3, and (5) = \mathfrak{p}^2_5, where \mathfrak{p}_n = (n, \sqrt{30}).
  • It is noted that none of the \mathfrak{p}_n for n = 2, 3, 5 is principal, as indicated by the use of Legendre symbols.
  • Another participant mentions a relation \mathfrak{p}_2 \mathfrak{p}_3 \mathfrak{p}_5 = (30), leading to the hypothesis that the class group is of order 4, generated by \mathfrak{p}_2 and \mathfrak{p}_3.
  • However, a participant expresses confusion, stating that they believe the class number should be 2, despite their calculations suggesting otherwise.
  • One participant proposes that since \mathfrak{p}_k^{-1} = \mathfrak{p}_k for k = 2, 3, 5, it suffices to show that the ideal cosets are the same, raising questions about the implications of their product being principal.
  • Another participant challenges the assertion that \mathfrak{p}_2 \mathfrak{p}_3 = 1 and \mathfrak{p}_2 \mathfrak{p}_3 \mathfrak{p}_5 = 1, questioning how these lead to the conclusion that \mathfrak{p}_5 = 1, given that \mathfrak{p}_5 is not principal.
  • A further participant points out a potential inconsistency in the equations presented, suggesting that the product of the left-hand side should not equal (30) if it is indeed the square of the left-hand side.
Participants express confusion and uncertainty regarding the computation of the class number, with no consensus reached on the correctness of the calculations or the implications of the relationships among the prime ideals.
Participants acknowledge potential mistakes in their reasoning but do not specify the exact nature of these errors. The discussion reflects a reliance on various mathematical properties and relationships that may not be fully resolved.
iccanobif
As an exercise, I'm trying to compute the class number of [itex]K = \mathbb{Q}(\sqrt{30})[/itex]. By the Minkowski bound, I just need to consider the prime ideals which divide 2,3,5.
I've found that
[itex](2) = \mathfrak{p}^2_2[/itex]
[itex](3) = \mathfrak{p}^2_3[/itex]
[itex](5) = \mathfrak{p}^2_5[/itex]
where [itex]\mathfrak{p}_n = (n, \sqrt{30})[/itex].
Also, using Legendre symbols it's easy to see that none of the [itex]\mathfrak{p}_n, n = 2,3,5[/itex], is principal.
Moreover, I've found the relation
[itex]\mathfrak{p}_2 \mathfrak{p}_3 \mathfrak{p}_5 = (30)[/itex].
Now, these relations make me think that the class group is of order 4 (generated by [itex]\mathfrak{p}_2, \mathfrak{p}_3[/itex], with the two generators in different ideal classes because of the last relation and the fact that [itex]\mathfrak{p}_5[/itex] is not principal).
BUT: I know that the class number should be 2.
Can anyone help me? I'm really confused!
Thanks!
I've found that
Thanks!
An idea: it's not hard to show that [itex]\mathfrak{p}_k^{-1}=\mathfrak{p}_k\,,\,\,k=2,3,5[/itex], so you'd only need to show
that all these ideal cosets are the in fact the same, and indeed [tex](2,\sqrt{30})(3,\sqrt{30})=(\sqrt{30}) \Longrightarrow \mathfrak{p}_2=\mathfrak{p}_3\,\,\,and\,\,\,etc.[/tex]
DonAntonio
that all these ideal cosets are the in fact the same, and indeed [tex](2,\sqrt{30})(3,\sqrt{30})=(30)\Longrightarrow \mathfrak{p}_2=\mathfrak{p}_3\,\,\,and\,\,\,etc.[/tex]
DonAntonio
My confusion comes from the fact that, although I know it's true what you said above (each [itex]\mathfrak{p}_n[/itex] is its inverse in [itex]Cl_K[/itex], and also [itex]\mathfrak{p}_n \mathfrak{p}_m[/itex] is principal), my problem is that
[itex]\mathfrak{p}_2 \mathfrak{p}_3 = 1[/itex]
and
[itex]\mathfrak{p}_2 \mathfrak{p}_3 \mathfrak{p}_5 = 1[/itex]
imply that
[itex]\mathfrak{p}_5 = 1[/itex]
which it's not true, as [itex]\mathfrak{p}_5[/itex] is not principal.
I must have made a mistake somewhere, but I don't know where!
and
imply that
Well, can you describe why you thin [itex]\,\,\mathfrak{p}_2\mathfrak{p}_3\mathfrak{p}_5=1\,\,[/itex] ? As far as I can see, the product of the first
two already is 1, so how come when the third one comes you still get 1?
DonAntonio
That can't be right. Your equations above say that (30) is the square of the left hand side.
  • · Replies 40 ·
  • · Replies 93 ·
17K
  • · Replies 55 ·
11K
  • · Replies 28 ·
  • · Replies 175 ·
29K
  • · Replies 16 ·
