Why is enthelpy a function of Temperature and Pressure?
Enthalpy is fundamentally a function of temperature and pressure due to its relationship with internal energy and the work done by the system. The equation dH = (∂H/∂T)dT + (∂H/∂p)dp illustrates how changes in temperature and pressure directly affect enthalpy. The discussion references key thermodynamic principles, including the first law of thermodynamics and the definitions of internal energy (U) and work (W). Understanding these relationships is crucial for analyzing thermodynamic processes.
  • Understanding of the first law of thermodynamics
  • Familiarity with the concepts of internal energy (U) and work (W)
  • Knowledge of differential calculus in thermodynamic contexts
  • Basic grasp of the ideal gas law (PV = nRT)
  • Study the derivation of the enthalpy equation dH = dU + PdV
  • Learn about the implications of constant pressure processes in thermodynamics
  • Explore the relationship between heat (Q) and work (W) in thermodynamic systems
  • Investigate the total differential of thermodynamic potentials
Students and professionals in thermodynamics, chemical engineers, and anyone studying the principles of energy transfer and state functions in physical chemistry.
tkdiscoverer
right now, I'm following the MIT thermodynamics video lecture.
I've gone thru
dU = [STRIKE]d[/STRIKE]w + [STRIKE]d[/STRIKE]q
([STRIKE]d[/STRIKE] for "is path dependent")
and
H = U + pV
But why is enthalpy a function of temperature and pressure?
is it because pV = nRT and thus, V = nRT/p, so we only need p and T to get V?
dH = ( [itex]\delta[/itex] H/ [itex]\delta[/itex] )TdT + ( [itex]\delta[/itex] H/ [itex]\delta[/itex] p)dp
but why not:
dH = ([itex]\delta[/itex]H/[itex]\delta[/itex] T)dT + ([itex]\delta[/itex]H/[itex]\delta[/itex]V)dV ?
Thanks! : D
Science news on Phys.org
You have (I won't write the path-dependent parts explicitly; just assume they are there :D ):
[tex] \mathrm{d}E = T\mathrm{d}S - P\mathrm{d}V[/tex]
We know that [itex]\mathrm{d}Q = T\mathrm{d}T[/itex], so that for a process at constant pressure we can rewrite the quantity of heat as the differential:
[tex] \mathrm{d}Q = \mathrm{d}E + P\mathrm{d}V = \mathrm{d}(E + PV) = \mathrm{d}W [/tex]
of some quantity
[tex]W = E+PV[/tex]
If you now want to find the total differential of the heat function itself (now no longer assuming constant pressure), you can easily get:
[tex] \mathrm{d}W = T\mathrm{d}S + V\mathrm{d}P[/tex]
For your notation: look at the definition of your [itex]U[/itex]. When you make the total differential of the heat function, you have to write explicitly the terms for the energy, where [itex]-P\mathrm{d}V[/itex] cancels with one of the differential you get from [itex]\mathrm{d}(PV)[/itex] in the heat function.
  • · Replies 35 ·
  • · Replies 31 ·
  • · Replies 19 ·
