Accelerometer tilt error correction
The discussion focuses on correcting tilt errors in acceleration measurements using the MMA7341 accelerometer mounted on an oscillating metal table. It is established that a tilt angle (Q) affects the accuracy of acceleration readings in the x direction. To correct this error without physically adjusting the sensor, one must mathematically rotate the accelerometer's frame to align with the gravity frame by measuring the x-z and y-z tilt angles.
  • Understanding of accelerometer principles, specifically MMA7341 functionality
  • Basic knowledge of trigonometry for angle calculations
  • Familiarity with Arduino programming for sensor integration
  • Concept of coordinate transformation in 3D space
  • Research mathematical rotation techniques for sensor data correction
  • Learn how to implement angle measurements using Arduino
  • Explore sensor fusion algorithms for improved accuracy
  • Study the effects of tilt on accelerometer readings in various applications
Electronics enthusiasts, Arduino developers, and engineers working on motion detection and sensor calibration projects.
maheshcn
I am using arduino and accelerometer MMA7341 to measure the acceleration in x direction of an oscillating metal table. But the mounting of the accelerometer is tilted by a small angle (say Q) . Is it affect the acceleration?. If it is affect the acceleration in x direction , how can correct it without changing the tilt of the acceleration sensor.
You will have to mathematically rotate the accelerometer's frame to the gravity frame. You will have to measure the x-z and y-z angles that it is tilted by.
12K
  • · Replies 22 ·
24K
27K
