Application of Maxwell Boltzmann velocity distribution to nanoscale systems
The discussion centers on the applicability of the Maxwell-Boltzmann velocity distribution in nanoscale systems, specifically regarding water molecules flowing through carbon nanotubes or graphene sheets. It is established that while a Maxwell-Boltzmann distribution is not expected in systems with fewer than 1000 molecules, it can still be approached under certain conditions, such as achieving thermal equilibrium. The key takeaway is that nanoscale systems can exhibit behaviors that approximate the ideal distribution despite being below the thermodynamic limit.
  • Understanding of Maxwell-Boltzmann statistics
  • Knowledge of nanoscale systems and their properties
  • Familiarity with thermal equilibrium concepts
  • Basic principles of fluid dynamics in confined spaces
  • Research the implications of nanoscale thermodynamics
  • Explore the behavior of fluids in carbon nanotubes
  • Study the conditions for achieving thermal equilibrium in small systems
  • Investigate alternative statistical distributions applicable to nanoscale systems
Researchers in nanotechnology, physicists studying statistical mechanics, and engineers working with nanoscale fluid dynamics will benefit from this discussion.
jeetu
Dear All
I have a question about the validity of Maxwell Boltzmann velocity distribution in the case of nanoscale systems.
When you consider a nanoscale system such as flow of water molecules (less than 100 molecules) through a carbon nanotube or graphene sheet, is it possible to expect a maxwell distribution for the water molecules?
or in other words
When the actual size of the system is much lesser than the thermodynamic limit (less than 1000 molecules), is it possible to obtain a maxwell velocity distribution for the molecules?
Thanking you
Jeetu
jeetu said:
Dear All
or in other words
Thanking you
Jeetu
Those are two different questions. Answers:
1) No, you would not expect a Maxwell-Boltzmann distribution.
2) Yes, it can obtain that distribution (translation: an ideal Maxwell-Boltzmann distribution can be approached by a system below the thermodynamic limit).
Reasons:
1) It's below the thermodynamic limit.
2) You can still have thermal equilibrium.
  • · Replies 17 ·
  • · Replies 25 ·
10K
