Solving Dynamics Problem: Inertia at Work?
  • Context: Undergrad
  • Thread starter Thread starter Bashyboy
    Inertia Work
The discussion revolves around a dynamics problem involving an elevator and the effects of acceleration on perceived weight. Participants explore concepts of inertia, normal force, and the implications of acceleration in both upward and downward movements of the elevator.
  • One participant suggests that when the elevator accelerates downward, the woman experiences a form of weightlessness due to inertia, leading to a lighter reading on the scale.
  • Another participant introduces the concept of General Relativity, stating that an object in freefall is equivalent to one under no acceleration, which complicates the understanding of gravity in this context.
  • A participant questions whether the feeling of weightlessness in a broken elevator is due to the absence of normal force from the elevator.
  • There is a clarification that when an elevator accelerates upwards, the scale reads heavier because the scale must exert a force greater than the person's weight to achieve the upward acceleration.
  • One participant emphasizes that while a falling person is technically weightless, this perspective may differ in a Newtonian context.
Participants express differing views on the interpretation of weightlessness and the role of normal force in various scenarios, indicating that multiple competing views remain without a consensus.
The discussion includes references to both Newtonian mechanics and General Relativity, highlighting the complexity of the concepts involved and the potential for differing interpretations based on the framework used.
Bashyboy
I am reading about dynamics, and I am looking at this example problem (it is attached as a file).
So, first I am imagining the elevator without the assisted downward acceleration. In this case, the acceleration due to gravity on the woman and the normal force provided by the scale cancel each other out. Now, as the elevator starts to accelerate downwards, the woman experiences her own inertia by the weightlessness, and the downward acceleration of the elevator can be thought to become the "new" or "pseudo" acceleration due to gravity. The scale reads her as being lighter because this "pseudo" acceleration due to gravity is weaker than the true acceleration due to gravity. Is this erroneous thinking? If not, could someone perhaps supply more elaboration--or clarity, if it not worded exactly eloquently--on this thought process?
Thank you
No, in fact, gravity itself does not accelerate. This sounds ridiculous, but it's the basis of General Relativity.
Basically, an object in freefall is equivalent to an object under no acceleration, there is no way for an observer in an elevator-like box drifting through space to tell if they're in an actual elevator in freefall.
Um. You probably didn't feel like an explanation of General Relativity. So if that's too much for you, remember that scales measure the NORMAL force and draw a free-body diagram for all the forces, after knowing the woman's acceleration. That should clear some stuff up.
On a website, I am reading more about this elevator physics. In the first paragraph, the author states that, "If the elevator cable broke, you would feel weightless since both you and the elevator would be accelerating downward at the same rate." Is this because the elevator would not be able to provide the normal force to push upwards on someone in an elevator under these circumstances?
Exactly.
Sorry for the stream of questions. So, the reason why a scale reads heavier than normal on a elevator accelerating upwards is because, since the elevator is accelerating, the scale must be accelerating, and I must be accelerating; but in order for an elevator to accelerate upwards, it has to exert a force greater than my weight, result in the scale having to exert a greater force than my weight and, therefore, reading a greater normal force. Is that right?
Yep.
Doc Al said:
Exactly.
Sorry, just feel like pointing this out. From a beginner's point of view, yes. But technically, the falling person truly is weightless. Sorry, love pointing out the finer errors in stuff.
Not in the Newtonian world, which is the context of the question.
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 46 ·
  • · Replies 48 ·
