What is the relationship between torque and angular momentum in a rigid body?
The relationship between torque and angular momentum in a rigid body is defined by the equation Torque(ext) = dL/dt, where L represents angular momentum. For a stationary point S, angular momentum is calculated as L(s, cm) = Ʃ(ρi x mivi), and the external torque is given by dL(cm)/dt = Ʃτ(ext, CM). When considering an accelerating point P, the equation modifies to include additional terms related to the center of mass, specifically Ʃτ(ext, p) = dL(rel_p)/dt + ρ(cm) x Ma(p), illustrating the dependency of torque on both the angular momentum and the acceleration of the center of mass.
  • Understanding of rigid body dynamics
  • Familiarity with angular momentum concepts
  • Knowledge of torque and its calculation
  • Basic principles of acceleration and center of mass
  • Study the derivation of angular momentum equations in rigid body dynamics
  • Learn about the role of the center of mass in torque calculations
  • Explore the relationship between linear and angular acceleration
  • Investigate applications of torque in real-world rigid body systems
Physics students, mechanical engineers, and anyone studying the dynamics of rigid bodies will benefit from this discussion.
naestibill
Considering a Rigid Body/Angular Momentum/Torque
We know that Torque(ext) = dL/dt
Now with respect to stationary point S:
and that dL(cm)/dt = Ʃτ(ext, CM)
Now with respect to ANY point, P, that is accelerating:
L(s,p) = L(cm) + ρ(cm) x Mv(cm)
And hence,
Ʃτ(ext, p) = dL(rel_cm)/dt + ρ(cm) x Ma(cm)
Can someone explain to me why this happens?:
Why this happens? : Ʃτ(ext, p) = dL(rel_p)/dt + ρ(cm) x Ma(p)
Thanks
If you would take the trouble to describe all your variables you've a better chance of a response.
  • · Replies 34 ·
  • · Replies 31 ·
