What Factors Limit the Burn-Up of RBMK Reactor Fuel?
  • Thread starter Thread starter vifteovn
The discussion focuses on the factors that limit the burn-up of RBMK reactor fuel, exploring both technical and policy-related aspects. Participants examine the implications of fission product buildup, uranium-235 availability, and the influence of historical events such as the Chernobyl accident on fuel management strategies.
  • Some participants propose that limits to RBMK fuel burn-up may arise from the buildup of fission products or the depletion of sufficient uranium-235 for sustaining a chain reaction.
  • Others argue that burn-ups could potentially be increased to levels comparable to light water reactor (LWR) fuel by enhancing enrichment and extending fuel residence time, though technical issues related to dimensional stability and corrosion behavior may complicate this.
  • A participant notes that the average burn-up of RBMK is between 20 - 30 GWd/tU, and references policy and fuel cycle management as influencing factors.
  • There is mention of the addition of 0.4% erbium to RBMK fuel, which reportedly allowed for an increase in burn-up after it was reduced post-Chernobyl.
  • Concerns are raised regarding the need for modifications to the fuel assembly, such as thicker cladding, to accommodate increased burn-up, with discussions on the trade-offs involved.
  • One participant highlights that erbium has a lower residual poison effect compared to gadolinium, suggesting it may be more favorable for thermal conductivity in fuel.
  • Historical context is provided regarding LWR fuel cycles, including changes in discharge burn-ups and the impact of reprocessing policies on fuel management strategies.
Participants express multiple competing views regarding the factors limiting RBMK fuel burn-up, and the discussion remains unresolved with no consensus reached on the primary limiting factors.
Limitations include the dependence on specific definitions of burn-up, the unresolved technical challenges associated with increased burn-up, and the influence of historical events on current fuel management policies.
vifteovn
Hi
I'm wondering what puts the limits to the burn-up of RBMK fuel. Is it the build up of fission products or the fuel simply running out of sufficient u-235 to sustain a chain reaction?
The average burn-up of RBMK is between 20 - 30 GWd/tU, http://www.neimagazine.com/journals/Power/NEI/September_2004/attachments/NEISept04p26-35.pdf .
vifteovn said:
Hi
It is a matter of policy or fuel cycle management/strategy.
http://www.elemash.ru/en/production/Products/NFCP/RBMK/
Burnups could be increased to the range of LWR fuel by simply increasing the enrichment and increasing the residence time of the fuel. However, there are technical issues with respect to the dimensional stability and corrosion behavior that may play a role.
The lower burnups mean that there is less buildup of TU radionuclides beyond Pu, which is an issue for recycle of Pu from spent fuel.
Perhaps the Chernobyl accident influenced the policy regarding maximum burnup of RBMK fuel.
As far as I've read, the burnup was reduced after the Chernobyl accident, but after the addition of 0.4 % of erbium to the fuel the burnup was bumped up again.
Yeah, I was interested in the technical issues with increased burnup. If an increased burnup would not be possible without modifications to the fuel assembly, i.e. make the cladding thicker or something.
I'm not familiar with specific performance issues with RBMK fuel.
Erbium has a lower residual poison effect than gadolinium, and one can usually use less Er than Gd in fuel, so it's penalty on thermal conductivity of the fuel is less.
With regard to cladding material, if one thickens the cladding, this would be at the expense of the fuel material. One could compensate to some extent by increasing the density of the fuel.
Back in the earlier decades of LWR fuel, the cycles were annual and the discharge burnups were in the low 30 GWd/tHM. Reprocessing of LWR was part of the plan. However, fuel cycle strategies changed because reprocessing in the US was suspended indefinitely, and the industry was faced with no where to send the spent fuel which began accumulating in spent fuel pools. Cycle lengths were increased to improve capacity factor and eliminate refueling outages, which saved millions $. Also, the discharge burnup was increased to the high 50 or low 60 GWd/tU.
RBMK fuel cycle management is different than LWR fuel cycle management, and LWR fuel cycle management varies according to national policy and utility.
  • · Replies 83 ·
19K
13K
  • · Replies 57 ·
19K
29K
