Is it Total internal reflection, or something else?
The discussion centers on the optical phenomenon observed in acrylic materials, questioning whether it is classified as "total internal reflection." The user presents examples, including keychains and exit signs, where light applied from one side causes the entire object to illuminate. While Wikipedia defines total internal reflection as occurring at a critical angle, participants argue that the observed effect is due to a combination of partial reflection and refraction, particularly at rough edges of the material. The consensus suggests that the correct description of the phenomenon is that "the light refracts through the material, causing it to illuminate."
  • Understanding of optical phenomena, specifically refraction and reflection.
  • Familiarity with the concept of critical angle in optics.
  • Knowledge of acrylic materials and their light transmission properties.
  • Basic principles of light behavior in different mediums.
  • Research the principles of light refraction in acrylic materials.
  • Explore the differences between total internal reflection and partial reflection.
  • Study the impact of surface texture on light behavior in optical materials.
  • Investigate applications of light diffusion in design and safety signage.
Optics enthusiasts, materials scientists, designers working with acrylic, and anyone interested in the behavior of light in various mediums.
samak
Is this process known as "total internal reflection"? Or is it called something else? What is the name of this process that causes the entire material to light up even though the light is applied only to one side?
Take a look at the photos so you can see what I am asking about.
Notice how the light in the key chain is only applied from one direction, yet the entire keychain appears to "light up". Is that caused by total internal reflection?
I cannot post full links right now so find the picture on tinyurl:
tinyurl dot com/cu989ek
You also see it on some exit signs like this:
tinyurl dot com/dxl2jd2
A few other examples:
tinyurl dot com/c58oqsv
tinyurl dot com/cor6t22
Wikipedia defines total internal reflection as:"Total internal reflection is an optical phenomenon that happens when a ray of light strikes a medium boundary at an angle larger than a particular critical angle with respect to the normal to the surface."
But that does not seem to be what is happening in the photos I showed you above. From the photos above, the "critical angle with respect to the normal to the surface" does not seem to matter. Or am I missing something here?
Science news on Phys.org
I don't think you need total reflection for the light to spread around within the acrylic glass. Some of it is partial reflection, but you don't see much of the part that escapes because it is bend towards the surface and you look rather perpendicular to the surface. The edges glow because they are rough and reflect / refract in all directions.
So in order to describe the phenomenon that we see in those pictures, what is the way you would describe it?
Would this be accurate: "The light refracts through the material, causing it to illuminate."
