Refuting the Anti-Cantor Cranks
  • Context: Graduate
  • Thread starter Thread starter lugita15
The discussion centers around the validity of Cantor's diagonalization proof of the uncountability of the real numbers, particularly in the context of arguments made by individuals who reject this proof, often referred to as "anti-Cantor cranks." Participants explore the challenges faced when attempting to engage with these individuals and the nature of their arguments.
  • One participant describes a typical exchange with anti-Cantor cranks, highlighting their insistence that a proposed number constructed via diagonalization is not well-defined.
  • Another participant argues that the construction of a real number differing from each number in a list is valid regardless of whether the list is complete or not.
  • Some participants assert that the contradiction arises from the assumption of a complete list of real numbers, rather than from the proposed definition itself.
  • There is a suggestion that anti-Cantor cranks may lack the mathematical background to engage with more complex concepts, leading to their focus on simpler, more accessible mathematical statements.
  • One participant expresses frustration at the inability to convince anti-Cantor cranks, suggesting that some individuals may be resistant to change their views regardless of the arguments presented.
Participants generally agree on the challenges posed by anti-Cantor cranks and the nature of their arguments, but there is no consensus on how to effectively engage or convince them of the validity of Cantor's proof.
The discussion reflects a range of assumptions about the nature of mathematical understanding and the motivations behind the rejection of established mathematical proofs. There are unresolved tensions regarding the definitions and implications of Cantor's diagonalization proof.
  • #31
Antiphon said:
Ok. I'll arrive at the situation you describe by repeating the diagonal algorithm over and over. This procedure, taken in the infinite limit, approches your construction as closely as desired.
You begin here to enter deep waters: what exactly is "this procedure, taken in the infinite limit"? Whose "infinite limit"?
The construction is plainly simple: you suppose you're given any list (=countable infinite set) of real numbers, preferably in
the interval (0,1) to make things less messier, and then a number is constructed as to make it impossible to belong to that
list, thus showing no list can contain ALL the real numbers.
Now, stick to the above and tell us how whatever doesn't go well...
It also reinforces the one-to-one correspondence between the natural and real numbers. Each time I extend the list with a new real member, the natural numbers also go up by one.
Unless you give a reasonable, mathematical definition of what you mean by "extending by one an infinite list" (see def. above), what you
wrote is just meaningless (not to mention that weird "the naturals numbers go up by one" thingy...)
DonAntonio
  • #32
Antiphon said:
Sure. Let me rephrase what I'm hearing you say.
Here's an initial list of real numbers along with a correspondence to the first few natural numbers.
1 0.000
2 0.100
3 0.200
You then give a prescription, an algorithm actually, for creating a number which can't be in the list above, as follows:
0.111, a number which differs as you describe, in diagonal fashion.
So your modified list is now:
1 0.000
2 0.100
3 0.111
4 0.200
I assert that you have expanded the list by one member and extended the range of the one-to-one correspondence between the natural numbers and the real numbers.
Your turn.
That violates the basic idea of the Cantor proof that we already have a list that includes all real numbers- that is, that the set of all real numbers (between 0 and 1) is countable. You cannot add new numbers.
  • #33
DonAntonio
I was trying to lead the horse to water. The infinite limit I presented is an algorithmic construction that in principle is no different from the way one might sum an infinite series. The point of it was to show that one simply cannot arrive at Cantor's result without starting off with unbounded sets as you pointed out. That you cannot approach the result the way you might show that .999... is the same as 1.0. But let's move on because this doesn't invalidate the Cantor result.
A couple of posts back I did exactly give you as requested "any list of real numbers". It was in fact the first three entries of an infinite countable list exactly as you specified, and between 0 and 1 to keep things from getting messy.
But that's not good enough apparently. So it looks like you need to tighten up your specs before we can go to the next step.
Is your objection to my list the fact that it excluded 0.05? Because perhaps that was the very Cantor number that would be added by diagonolization.
Next you're going to say that I'm not getting it, that the first entry corresponding to natural number 1 is all zeros (say) and the second entry which corresponds to natural number 2 is "the next real number after 0.000..." so that I haven't skipped any.
Which brings us full circle to my very first post. It seems the point of the constructed proof is to arrive at the contradiction that by adding one more real, I wasn't able to enumerate them all after all. But one doesn't need to add the diagonalized real to arrive at this conclusion. You arrived at it YOURSELF when you kept saying that my finite, truncated, first few entries of the countably infinite list I provided aren't good enough because why? Because they didn't contain all the real numbers!
That's like saying sin(x) does not equal x+x^3/6+... because I didn't start the series with all the terms already there.
  • #34
Let me further add (because I don't want to fly off on a tangent here) that I understand the result but disagree so far with the soundness of the diagonalization proof as its been presented.
I get it if you say that the terms in a series like sin(x) are given by x^n/n! and clearly you can't "shoehorn in" a new term between the nth and n+1th. Cantor does exactly this, shoehorns in another term thus showing there is not the one to one association as in the series for sin(x). I get it.
The gist of what I'm trying to say (as a non-mathematician) is this: why is it that I can enumerate the first 3 natural numbers in an ordered set of them beginning with 0, but the same cannot be done with the reals beyond the first entry? If Cantor or anyone wants to start there and work toward the idea these sets are fundamentally different in nature, there'd be no Cantor Cranks.
Cantor forms this very list that can't be formed and then a step *later* brings us to a contradiction?
Sorry but that's a little too much like Morpheous jumping from building to building. Telling me to "free my mind" isn't going to cut it.
  • #35
First of all, you should know that in Cantor's proof, the list of real numbers doesn't have to be ordered from least to greatest. In fact, if a list WAS ordered from least to greatest, you don't even need Cantor's proof to show that it's incomplete. You can just take, say, the average of the first and second entry, and it won't be on the list.
  • #36
No, Cantor is saying "suppose there is a complete list of real numbers". Then he is using the diagonal construction to show that there is a real number not on the list. Thus, he is concluding that the assumption that there is a complete list of real numbers is wrong.
  • #37
I'm not trying to split the hair that finely. Nothing I'm saying changes if you say "suppose there is a complete list of real numbers". I think we're ok here as long as everyone agrees that the phrase in quotes is the obvious contradiction and that the diagonal construction of a new real is unnecessary.
  • #38
No, it is not such an obvious fact that you get a contradiction if you assume that there exists a complete list of real numbers. It takes a nontrivial proof like Cantor's.
  • #39
Check this: as already noted, by "list" one has to understand "elements of an infinite countable set".
Next: nobody adds anything to anything. Upon getting any list, one can construct a number which is not in that specific list.
Next: perhaps you think you've arrived to a great insight when you use exclamation marks, but I honestly can't see it. Your example
of a finite list with three elements shows nothing as I can construct easily a number not in it without even using the diagonal trick.
Next: I don't care, nor any other mathematician would, what's the first element in such a list. It can be 0, 1, 0.5 or whatever. Anyway, after
you're done with your list, I can always construct a number not in it.
DonAntonio
  • #40
This is what Cantor's theorem states: the set of real numbers is infinite yet uncountable, i.e. it cannot be ennumerated. That's why.
Either you're addressing something else or you're completely lost in this matter: neither Cantor nor anyone else trying to prove this theorem
"forms" any list at all. We assume such a list exists AND THEN we prove that there's always a real number not belonging to the list.
I would never tell you to free your mind, but I' definitely tell you to learn some mathematics. If you want to understand this stuff, that is.
DonAntonio
  • #41
Fascinating to see the thread degeneration here. Any discussion of anti-Cantor cranks draws anti-Cantor cranks.
Purely from a behavioral point of view, the Cantor deniers and the Cantor denier refutors seem equally obsessive. The fact that one group is mathematically correct and the other not, is irrelevant. Because after all, most people manage to avoid these discussions altogether. And now you can see why. They always, always, always end up in exactly the same place.
What I used to like about sci.math on Usenet was that at least there, you could toss in gratuitous personal insults. Here you can't do that. So it's much less fun to tease and torment the deniers.
  • #42
He doesn't do that at all. Plus, you can replace any term in that series and it will still converge to some real number. It just will no longer be sin(x).
Similarly any decimal expansion 0.a1a2a3... where a1, a2, a3,... are digits 0-9 is short for the series a1*10^-1 + a2*10^-2 + ... which converges to a real number between zero and one no matter what the digits are chosen to be.
Because well-ordered-ness is a completely separate issue from cardinality. The rational numbers are also not well ordered, yet the rational numbers can be put into 1-1 correspondence with the natural numbers and thus the Cantor diagonal argument fails. The existence of irrational numbers with non-terminating decimal expansions is necessary for the Cantor diagonal argument to work.
The list is hypothetical. That's the essence of proof by contradiction. Do you have a problem with other proofs by contradiction? What about the proof that the square root of two is irrational? It's normal to assume there are some natural numbers n and m such that n^2 / m^2 = 2 and then show that the existence of such numbers leads to an absurdity. Do you also question the proof that the square root of 2 is irrational? If not, then what is fundamentally different about Cantor's diagonal argument?
  • #43
Indeed. For the time being the thread hasn't degenerated that much, imo. I won't get into any crank-bashing or
crank-educating rant here. For that we have sci.math. So far, though, Antiphon is not a crank but someone with
some doubts and some rather deserted areas in his/her mathematical education...for
now. If and when he, or anyone else, slip into crankhood I, for one, shall bail out of the thread.
DonAntonio
  • #44
DonAntonio
I agree Antiphon does not appear to be a "crank". I certainly hope he's not scared off by the implications and condescension being tossed around in this thread. Also if someone is honestly questioning at least give them credit for having the curiosity to want to learn rather than knocking them on their lack of current education.
  • #45
Sorry. I officially apologize for implying that doubters are the same as cranks. Antiphon, come back.
  • #46
I'm still here. Been traveling coast to coast.
I'm quite sure I'll never become a crank on this issue. As a non-mathematician though I can see how someone would become one. Maybe if this issue can be zoomed in on, many future cranks-in-waiting might be saved. Please lead me down the reasoning path.
I'll do my best to explain using the language I have available.
Proofs by contradiction make sense. You make an assertion or assumption that may or may not be true, then you follow up with some valid deductions based on the assumption. If your subsequent deductions are valid but you arrive at a contradiction or falsehood, then the original assumption was false. This is proof by contradiction as I understand it.
For example (and I'm making this up on the fly) let's suppose that division by zero were legitimate arithmetic. I can probably form some simple algebraic expessions which would result in a statement like 1=2. Nobody should have a problem with such a proof.
But if you start a proof with 1=2 and then proceed to do valid algebra with it, the contradiction doesn't arise from the proof but is built in at the beginning.
I can't speak for any Anti-Cantor cranks but for me this is an issue.
A few posts back MBS says that the proof of the irrationality of sqrt(2) can begin by assuming the existence of two integers m and n such that n^2/m^2=2. You then perform valid reasoning on this and arrive at absurd conclusions. That's great. I don't have trouble with that because the expression above is legitimate algebra, it just so happens that no two integers will satisfy it.
But I'd bet it's not legitimate logic to start with the absurd result and reason your way backward to the expression above.
What am I missing?
  • #47
What am I missing?
That is the best way to prove something IMO because you in doing so, you are accepting the premise that what you are trying to disprove is in fact true and from this a contradiction (if it's not true under some axiomatic system) is found and thus you have shown it's false.
This is important not just mathematically but also psychologically because when most people start off disproving something, in the back of their mind they assume that what they are proving is undoubtedly true which ends up screwing up their analysis, proof and way of thinking whereas the above method psychologically says "OK this is what you said, let's go along with this and see what happens" which is a much better approach because mentally you are saying "I'm going to disregard my own prejudices for the moment and I'm going to assume that you are right". It's very subtle, but it's so important as a logical tool and I'm afraid it's not used as much as it could (and should) be.
You definitely have the right approach and mindset for analyzing things not only mathematically, but in general situations overall.
  • #48
Whenever you do a proof by contradiction you are starting with an absurd result (by definition), so I don't really understand your objection here.
What am I missing?
Assuming that the real numbers are countable is exactly akin to assuming that [itex]\sqrt{2} = \frac{p}{q}[/itex] where [itex]p,q \in \mathbb{Z}[/itex] are relatively prime. Constructing a real number not on the list is exactly like showing that 2 divides both [itex]p[/itex] and [itex]q[/itex]. The type of reasoning is identical.
  • #49
  • #50
viraltux said:
Is this a closed subject in the mathematical world? I ask because I have found this
http://en.wikipedia.org/wiki/Controversy_over_Cantor's_theory
And sure everyone is entitled to have an opinion but I'd like to know if experts logicians have reached an agreement on this.
This is one of the instances where Wiki, a very good source of immediate though generally not deep and sometimes
even unreliable knowledge, can mislead. This article begins with the following:
"In mathematical logic, the theory of infinite sets was first developed by Georg Cantor. Although this work has found some acceptance
in the mathematics community, it has been criticized in several areas by mathematicians and philosophers."
The words "some acceptance" are unduly and unjustly misleading: infinite sets, in this or that acception, are widel accepted by an
overwhelming majority of mathematicians. Period.
Now, the controversy exists within very narrow and, if may I add, unimportant frames and individuals, and it surely isn't something
that, as far as we know right now, would affect in some dramatic way neither the development of most of mathematics nor
most of its applications to other sciences, technology and/or the "real" world, whatever that is.
Back again with cranks: these persons are characterised by an inner and utterly unjustified certainty that they are right and ALL
the others are wrong, even when they are NOT mathematicians (99% of the cases) and the others are.
DonAntonio
  • #51
OK, I just thought up this counter-argument
Let's imaging it does exist a list of all real numbers such that they have only zeros in the decimal part. The list will look something like:
S
1 xxxxxxxxxxxxxxxxxxx.00000000000000000
2 yyyyyyyyyyyyyyyyyyy.00000000000000000
3 xyxyxyxyxyxyxyxyxyx.00000000000000000
4 yxyxyxyxyxyxyxyxyxy.00000000000000000
Then we try to construct S0 using a different digit from the Diagonal
yxyy... .00000000000000000
Then S0 cannot possibly be in that list, therefore that list cannot exist... but since the list have only zeros in the decimal places that list is equivalent to the Natural numbers which we know we can count, therefore the diagonal argument makes no sense.
What is it that I did wrong?
  • #52
As an aside, you don't need to phrase the diagonal argument as a contradiction, you can just use it to show that any function from the naturals to the reals must fail to be onto.
  • #53
S
S0, even if you can define it at each step, which you may not be able to do, will have an infinite number of digits before the decimal point, and so will not be a real number at all.
  • #54
S
In order that the result be an integer, it has to have only a finite number of digits. Your method does not guarantee that the "number" created by the diagonal argument does not just keep going and have an infinite number of digits.
  • #55
Oh I see... thank you HallsofIvy and dcpo, so the problem is that Integer numbers must be finite and so it goes to the left side of a real number. I understand. Yet, it seems now more a definition problem rather than anything else.
But that raises one interesting question I think, what kind of number would be the number Pi without the decimal dot?? 314159...
Because I can construct this number yet it does not fit the definition of Integer or Real.
  • #56
It is worth noting that the "controversy" over Cantor's argument presented in that article actually has nothing to do with controversy about the validity of his argument; the controversy lies in the axioms needed to make the argument work. So the title of that page is kind of a misnomer.
Back when Cantor first presented his argument for the uncountability of the real numbers, the axiomatic framework for mathematics was not well-developed, so mathematicians had varying opinions on whether or not you could talk about things like the collection of all natural numbers, the collection of all real numbers, etc. In the mathematics of today, the axiomatic framework is fairly well-developed, and using the usual axioms of set theory, Cantor's argument is completely valid.
  • #57
It does not belong to any conventional number systems and is probably meaningless to discuss. You could try to define specific properties that the infinite sequence of digits might have, but I doubt the theory you could derive would be particularly fruitful.
In any case, this is not relevant for Cantor's argument. The diagonalization argument is usually applied to the real numbers between 0 and 1. This prevents having to worry about the placement of the decimal.
  • #58
Thank you jgens for your answer, but as much as I'd like to believe that I just discovered a new kind of numbers I think other possibilities are more likely.
I am surprised though you say is probably meaningless to discuss that kind of numbers, particularly considering all the arcane concepts mathematicians end up working with, but anyway.
  • #59
You are free to feel however you like and if you want to research these sorts of things, then you are more than welcome. I can say with a reasonable amount of certainty, however, that most members of the forum will probably agree with my position on the matter.
Think about it this way: We already do this with decimal representations of real numbers and with p-adics, so presumably you plan on endowing them with some structure which makes them distinct from either of these; otherwise, the theory of your new numbers will be no different than the theory of the real numbers between 0 and 1 essentially. The problem is that this idea is nowhere near novel. I am pretty sure I had a similar idea back in grade school when I was thinking about decimal representations of numbers and I am sure many mathematicians have had similar ideas over the past several hundred years. Don't you think it is likely that if they couldn't work out a structure on infinite strings of digits that is entirely distinct from the theory of real numbers between 0 and 1, it would be a well researched field by now?
  • #60
I am an statistician and this is far away from my field/interest of research.
Well, actually when I said "I think other possibilities are more likely." I was referring exactly to the kind you mention now. I find hard to believe there is no a theory already in place that fully explain this kind of numbers which, obviously, not me nor you are aware of.
  • · Replies 55 ·
11K
  • · Replies 43 ·
  • · Replies 17 ·
  • · Replies 32 ·
