sophiecentaur
Homework Helper
- 30,534
- 7,516
There is a bit of confusion here. The article on the loop aerial that talks of the relative drop off of fields is, I think, referring to the characteristics of a transmitting monopole element (which is what is normally used for broadcasting). In that case the E field will dominate up close.
But I have to ask you why, if the near E field is inherently so much higher than the H field, why are magnetic circuits used for RF transformers? You could use electric coupling between two plates or wires for your system but it's easy to calculate the relative capacity between two distant wires and compare this with their capacity to ground. This corresponds to a considerable Capacitative 'pot-down'. The magnetic field around a coil surely dominates over the E field in the near field. Each turn of the coil adds to the H field but only one turn contributes to the E field - the others will be cancelling each other out.
I seriously suggest that you try a simple experiment with two coils and two wires and compare the effectiveness of the two systems. Easy done in an afternoon and it would point you in the right direction - and convince you, too!
Also, the SNR of your DAC is not what I refer to. I am referring to the ratio of your wanted, received signal (highly attenuated by the space between the terminals) and the receiver noise and external interference. That's what your receiver / demodulator has to deal with when it tries to extract the data from the received signal (as with all signal receiving equipment). The original DAC 'noise' (or rather distortion) is still 109dB below your wanted signal and is not a problem.
